12-10-2016, 07:37 AM | #1 |
1988 Crew Cab shortbed overhaul
Hey guys, Im new to the board but lurked on here for years. I have wanted a crew cab for years and just never found the right truck to restore. I pulled the trigger a few weeks ago and bout this truck. Its a 1988 7.4L, turbo 400 truck with dana 60's. The structure of the truck is very solid and all the cab and bed mounts a re in really good shape. One rocker has some rust and it needs a little mechanical work but runs out ok. I think the truck was restored once before and someone put a later front clip on it. I gave $6200(hope that was a decent deal). I drove it back 4 hrs from middle ohio.
The plan is to short bed, 4l80e, and do a frame off in some fashion. I don't know the in's and out's of the square bodies so feel free to correct me if I post dumb info, its just because I don't know the difference. I have already asked carboncrew a ton of questions and I really appreciate his helpfulness. |
12-10-2016, 07:44 AM | #2 |
Re: 1988 Crew Cab shortbed overhaul
I did add some 35's and wheels I had on my quigley just to give it a different look for short term. These are not permanent. The bed, front fenders, and front bumper are all for sale also.
I drove a couple hours away on thursday and bought a clean short bed, four power doors with clean panels and a wiring harness from a suburban since mine has aftermarket power windows. I also picked up a late model column and instrument cluster. |
12-10-2016, 07:51 PM | #3 |
nice find and a good deal IMO..
12-12-2016, 10:30 AM | #4 |
Ha!...no problem man, glad I can help a little. Nice truck. Good luck on the project!
12-12-2016, 02:05 PM | #5 |
Looks like a real nice truck to start out with. Good call on selling off that front bumper.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-12-2016, 08:53 PM | #6 |
We pulled the bed, bumpers, front fenders, and all 4 doors today. Someone glued the carpet padding down so thats taking some time.
12-12-2016, 08:55 PM | #7 |
The rear springs already had an Off-road Design shackle flip kit. The truck sits a little to high for me, I may contact deavers for springs. I'm trying to have frame at sand blasting by end of week
12-12-2016, 10:52 PM | #8 |
Sweet truck and seems like a fair deal to me. Probably has a 14 bolt rear. I'll be watching.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
12-13-2016, 07:12 AM | #9 |
Question-Whats the fuel injected 454 worth? Motor runs good, has new distributor and only has 120K miles. Im going to swap to LS 6.0L
12-13-2016, 11:48 AM | #10 |
Not trying to be a smart ass but whatever someone will give you for it. TBI peanut port head isn't really a motor people seek out for swaps. Your market is probably someone replacing a like-kind motor. Around here I would guess $800-1200.
12-13-2016, 06:13 PM | #11 |
Yep, it's getting serious!
12-13-2016, 06:23 PM | #12 |
Its an eerie feeling when you make that first cut!!
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
12-13-2016, 07:19 PM | #13 |
is this type of cut stronger when completed? i know some that have 'step cut' the frame but also heard that a horizontal weld on a frame isnt desirable. just curious, cool build. i have a lowered ccsb but mine was already cut down when i got it. good luck with the project!
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
12-13-2016, 07:29 PM | #14 |
I'm interested in that 454, my dad and I are in Richmond quite a bit. I'm not looking for a high dollar motor though.
1978 Hawaiian Blue GMC 454/Tremec TKO 500 BUILD THREAD |
12-13-2016, 10:54 PM | #15 |
For a minute I thought you took a picture from my build. My frame had the same mark in the same white crayon a couple months ago. I did a ton of reading on different forums and articles about the best cut and from what I gathered the 45 is the way to go.
12-13-2016, 11:52 PM | #16 |
Looks like a nice solid truck!
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
12-14-2016, 06:32 AM | #17 | |
Just for guys looking to cut the frame, it is exactly 14" in the front. The front two bed holes need to 10 3/8" apart. The holes were originally 24 3/8" apart. |
12-14-2016, 06:33 AM | #18 |
Id sell it complete for $800. i just listed it locally yesterday and should have it out today. I own a transmission shop and Im using the TH400 for an off road desert truck build for a local customer.
12-14-2016, 10:51 PM | #19 |
Front clip off, drivetrain tomorrow.
12-14-2016, 10:54 PM | #20 |
I'm really surprised how clean the floor was after we got the padding removed. I'm gonna start dynamatting Monday.
12-15-2016, 08:53 AM | #21 |
Keep us posted on how much dynamat it is going to take. I plan to do my crew cab soon.
12-20-2016, 07:49 AM | #22 |
We got the cab off yesterday then pulled drivetrain. Frame is going to sandblasting on Thursday.
12-20-2016, 12:10 PM | #23 |
100 sf will get all the floor, most of the roof and a good bit inside each door.
12-20-2016, 06:27 PM | #24 |
6>8 Plugless........
Nice truck to start with! You're making some killer progress on it too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-21-2016, 06:41 AM | #25 |
We got it down to the frame now. I'm gonna keep the axles under it till he can sandblast it next week. I'm surprised how at how clean the frame was around the body mounts.
