12-23-2016, 01:41 PM | #1 |
Old member
Re: What did you do to your truck today? Chapter II
The Rat Ramp!
Yesterday and today I worked on the rat ramp for a few hrs since the temps where nice. I got the heater all cleaned out and all 3 speeds of the fan working nicely! The ash tray was stuck and I had a heck of a time getting it out but once out I got the bearings cleaned up and greased up she is sliding in & out nicly now! I had installed the new radiator about a month ago so I got the over flow tank installed yesterday as well. I swapped steering wheel out and took the master cylinder loose for the booster install. Have to order a new rod for it. The old 67 horn cap cleaned up pretty nice. A friend came by yesterday as I was working on it and said you know I have a few parts stashed for these old trucks, so I asked what he had...factory tilt wheel new dash cover RED and a seat cover! So in a few weeks I'm getting it all for the RAT! I think I'll even order the digital gauges for it later on after we get over Christmas.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-23-2016 at 01:49 PM. |
12-23-2016, 09:00 PM | #2 |
Just doing a lot of fitting and mock up on the new bed sills, front, and wood kit... Lots and lots to do yet. The above frame rear sway bar gets in the way so that needs to be addressed and 2 holes in the new front dont match up with the holes in the sides on the driver side as well, buts no biggie since the sides still need lots of work as you can see. Lots of trouble trying to save the sides...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
12-23-2016, 09:52 PM | #3 |
That thing is pretty cool.. I could really use something like that
12-24-2016, 09:54 AM | #4 |
Old member
Thanks, I had my eye on it for several years. It was about 20 minutes from the house and finally this past July I got it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-24-2016, 12:08 AM | #5 |
[QUOTE=Andy4639;7803439][B][COLOR="Red"]The Rat Ramp!
Yesterday and today I worked on the rat ramp for a few hrs since the temps where nice. I got the heater all cleaned out and all 3 speeds of the fan working nicely! The ash tray was stuck and I had a heck of a time getting it out but once out I got the bearings cleaned up and greased up she is sliding in & out nicly now! I had installed the new radiator about a month ago so I got the over flow tank installed yesterday as well. I swapped steering wheel out and took the master cylinder loose for the booster install. Have to order a new rod for it. The old 67 horn cap cleaned up pretty nice. A friend came by yesterday as I was working on it and said you know I have a few parts stashed for these old trucks, so I asked what he had...factory tilt wheel new dash cover RED and a seat cover! So in a few weeks I'm getting it all for the RAT! I think I'll even order the digital gauges for it later on after we get over Christmas. Andy4639 when did you get the rat trap , i have not seen it before....Don |
12-24-2016, 02:26 AM | #6 |
Inner fenders photo from the painter.
12-24-2016, 02:28 AM | #7 |
Can only post one photo at a time from my iPad.
Tailgate painted also. |
12-24-2016, 09:56 AM | #8 | |
Old member
[quote=ole dollor;7804150]
I got it right after we bought the 64 SS Impala. We decided we needed something to haul the 56 Bel Air and the 64 SS Impala along with my truck to shows!
12-24-2016, 01:47 PM | #9 |
Getting some freshtoration done on the '72. Here are before and after pics of the seat. Time of day and sun make the color look different, but it's not, it's original vinyl in the original color.
12-25-2016, 03:57 PM | #10 |
Yesterday, I finally finished up under the dash, and installed my "new" glovebox insert (I've had it in the garage for about six years, so it was time ). For those wonderinding "how difficult was it?, not at all, it just takes a little patience to get the screws to start. I also changed out my window seals. Makes all the difference in the world.
12-25-2016, 09:14 PM | #11 |
Started running all the new SS brake lines.. Not sure why they all came out on the OUTSIDE of the frame at the front where the all meat up to go up to the MC... but I guess i can fix that easy enough...
12-25-2016, 09:31 PM | #12 |
I recently redid my brake lines and remember reading that there were some trucks in '67 that had the brake lines run to the outside of the frame like this, and there were kits available that replicated this. For the kit I used, I remember there being an option to choose inside or outside the frame. Looks like you ended up with the kit that goes outside.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
12-30-2016, 09:56 PM | #13 |
More body work
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
01-02-2017, 03:48 PM | #14 |
Swapped the cast iron intake and qjet now I need newer kick down and probably swap to cable throttle while I am at it. Truck barely got out of it's own way before. Feels like it flies now
