Old 01-28-2017, 07:43 PM   #126
ChuckLee
Re: 1970 C10 LWB "Blu"
Awesome! Good to see an update
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-29-2017, 10:08 AM   #127
NC_John
NC_John's Avatar
Thanks Chuck. I'm trying to do what I can while the block and heads are out getting their magic. I'm very, VERY anxious to at least get the engine and transmission back in for good so I can reassemble the interior, get the front clip back on and do my underbed fuel tank.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 01-29-2017, 10:19 AM   #128
NC_John
NC_John's Avatar
I got my vintage air main section assembled and installed in the truck.
Turns out I installed the blower motor (round) cap on backwards... Didn't notice until I was looking at hardware assembly on the big flat cover. Painted and caulked so its too late now. I used a stainless button head screw on it too which now I wish I didn't (since everything else is black). I'll have to use some black touch up paint on it.
I eliminated all the self-tapping screws on the flat cover and replaced them with flat black button head 1/2-20 bolts. Painted the two 1/2-20 bolts that support the unit inside to tone them down a bit. The hardware vintage air supplies just looks cheap. My firewall is completely full of holes not from original equipment/harnesses that are no longer there. Its going to have to wait to get cleaned up and smoothed properly for another time. I hate to think of the can of worms I will open up if I start spiffing it up now. The dang cab will probably come off the frame and I'll get sucked into doing a full frame off.
1970 C-10 LWB "Blu"
Old 01-29-2017, 10:49 AM   #129
GR8-68
GR8-68's Avatar
Looks great John, with the necessary working liquid the install went smoothly
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-29-2017, 11:35 AM   #130
NC_John
NC_John's Avatar
Thanks Larry. It took two beers and one cup of coffee to finish (the beer was making me sleepy so I needed the coffee..... it was kind of chilly in the garage once I turned off the heat too).
1970 C-10 LWB "Blu"
Old 01-29-2017, 01:10 PM   #131
GR8-68
GR8-68's Avatar
I feel the pain
Larry
"Project 68"
paypal.me/ldgrant
Old 01-29-2017, 02:37 PM   #132
NC_John
NC_John's Avatar
Didn't want to turn on the heat in the garage for just a little bit of work so brought some stuff inside. Converted my control panel over to the vintage air controls. Went OK but I hope it will be more durable than it looks.
1970 C-10 LWB "Blu"
Old 01-29-2017, 03:05 PM   #133
ChuckLee
You running your fan controls off ls pcm or what?
Old 01-29-2017, 03:15 PM   #134
NC_John
NC_John's Avatar
Not sure yet. Going to jump into the harness and controls after I have the engine build sorted out. I don't think my brain can handle much more right now.
1970 C-10 LWB "Blu"
Old 01-29-2017, 03:27 PM   #135
ChuckLee
Painless makes nice relay kits for stuff like that if you don't want to build your own. Something like this will make it pretty easy. This way you can have tuner still keep AC rpm adjustment on and things like that so it's drives nice and idles nice with AC on and also will have the high rpm shut off feature to protect your compressor.
http://www.painlessperformance.com/webcat/30109
Old 01-29-2017, 03:36 PM   #136
NC_John
NC_John's Avatar
I just realized that my pcm will not have fan controls as the donor truck had an engine driven fan. I guess I will have to go off of temp switches/relays and tie the A/C in there.
1970 C-10 LWB "Blu"
Old 01-29-2017, 10:42 PM   #137
David12460
Following. Great work!
David12460 is offline   Reply With Quote
Old 01-30-2017, 01:19 AM   #138
Jason7121
Jason7121's Avatar
You can have your ecm reflashed for fan controls. Mine was also a mechanical fan with clutch and I converted to 2 electric fans controlled by ecm .
Jason7121 is offline   Reply With Quote
Old 01-30-2017, 01:22 AM   #139
ChuckLee
Yup.
Old 01-30-2017, 07:19 AM   #140
NC_John
NC_John's Avatar
Yup.
Yes, I did see that I could add fan outputs to my PCM harness last night on lt1swap.com. I believe there is an AC on/request signal input too that I should be able to wire in to tie in the vintage air. Need to do something more research but looks good so far. Thanks gents.
1970 C-10 LWB "Blu"
Old 01-30-2017, 07:20 AM   #141
NC_John
NC_John's Avatar
Thanks.
1970 C-10 LWB "Blu"
Old 01-30-2017, 08:51 AM   #142
Hart_Rod
Hart_Rod's Avatar
Got my DBW accelerator pedal with the Hart_Rod supplied bracket mounted today. I'll have to find a good spot where I can mount the TAC module.
That came out nice! You can change the DBW pedal pad to a 71/72 pad fairly easily. Here's one with the CST trim on it.
Hart_Rod is offline   Reply With Quote
Old 01-30-2017, 09:55 AM   #143
NC_John
NC_John's Avatar
That looks good Rob. I spent the extra money to get a new pedal assembly too- the used stuff I saw looked too used to put in the truck.
Where did you mount the TAC module on your hot-rod bus?
1970 C-10 LWB "Blu"
Old 01-30-2017, 10:25 AM   #144
Jason7121
Jason7121's Avatar
I talked with Lt1.com about ac request also. I was told on dbw setup ac request doesn't need to be setup only dbc need that. My neighbor has dbw with no ac request.
Old 01-30-2017, 10:28 AM   #145
NC_John
NC_John's Avatar
I know that the pcm will automatically bump up the idle when it senses the load change but I think I need the AC request to turn the fans on and off. Your neighbor might have controls for his fans independent of the PCM?
1970 C-10 LWB "Blu"
Old 01-30-2017, 10:33 AM   #146
Hart_Rod
Hart_Rod's Avatar
Thanks John. Due to the way my harness was laid out (Speartech), I mounted my tach module underneath my computer on the core support.
Old 01-30-2017, 10:37 AM   #147
NC_John
NC_John's Avatar
The TAC (throttle control module?) way up there? Dang... that's a long wire extension...
1970 C-10 LWB "Blu"
Old 01-30-2017, 10:47 AM   #148
Hart_Rod
Hart_Rod's Avatar
Yes it is....
Old 01-30-2017, 01:23 PM   #149
IronHaven
I can't wait to see how this turns out. Subscribed
IronHaven is offline   Reply With Quote
Old 01-30-2017, 02:05 PM   #150
NC_John
NC_John's Avatar
that makes two of us!
1970 C-10 LWB "Blu"
