Old 02-03-2017, 08:40 PM   #1
mattfranklin
mattfranklin's Avatar
Who makes a good quality OEM performance clutch kit?
When my truck came apart it had an 11" clutch. The disk actually looked fine, but the pressure plate had a few bent diaphragm fingers, so at least the pressure plate needs to be replaced.
I'd like to get a good stock clutch. Not anything fancy for racing, but I'd like to find something of equivalent quality that GM might have installed in a stock '70 Corvette or Z-28 Camaro with an LT-1.
I went to RockAuto to look for clutch kits and I saw them anywhere from $35 to $170. For brands like "Brute Power," "M-Pact," and "AMS Automotive." I have never heard of these brands. I usually prefer AC Delco to "keep my GM car all GM," but Rock didn't list them.
Does anyone have recommendations for 11" clutch/pressure plate kits?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 02-03-2017, 09:16 PM   #2
johnthegreat508
Re: Who makes a good quality OEM performance clutch kit?
I would go with the zoom clutch kits from summit racing.
1973 Chevrolet C10 Stepside 454
johnthegreat508 is offline   Reply With Quote
Old 02-04-2017, 12:27 AM   #3
Captainfab
60-66 Nut
It's been a long time since I have bought a clutch but Luk clutches used to be one of the best.
Old 02-04-2017, 09:10 AM   #4
truckdude239
truckdude239's Avatar
Luk clutchs ac delco center force, stay away from zoom or perfection clutchs zooms made by perfection i tried both in my c10 and both went south after couple thousand miles the ac delco had over 15k on it when i pulled for an automatic swap and still looked new guy i sold it too has over 45k on it so far still doing good im told
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-04-2017, 09:30 AM   #5
cadillac_al
Speedway motors has some good prices on clutches. I was shopping for my Camaro and didn't pull the trigger yet but leaning toward saving money at Speedway.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-04-2017, 02:14 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Centerforce... period. Best clutches made.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-05-2017, 01:42 PM   #7
MikeB
MikeB's Avatar
I used one of Zoom's 3000-series kits several years ago behind a mild performance 327. Had no problems at all with it handling aggressive starts and shifts. But I have to say the same is true for a $100 Pioneer kit I used behind a mild 350.
Unless you do a lot of speed shifting and clutch slipping, I'd get a stock replacement kit, or maybe one step up. I say that because I once used a street/strip kit from RAM, but it took a lot of force to push in the pedal, and it was a little too "grabby" on release.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-09-2017, 06:04 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Gary
I like the Centerforce II's. Have one in my '68 C/10 L6 292 and had one in my '71 GMC Jimmy w/V8 350.
Old 02-10-2017, 06:49 PM   #9
Husker
Husker's Avatar
I am going to need one in my 68 6 Cyl. I want a easy to push but reliable. The one in there now pressure plate going bad. Not sure what brand it is. Which AC Delco one would be best?
Sorry if I hijacked.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-10-2017, 08:17 PM   #10
'68OrangeSunshine
Ron
I use a Center Force II on my L6 292/SM465 in a '68 C/10 Stepside, not too stiff.
They are American-made.
Old 02-15-2017, 07:45 PM   #11
crazy longhorn
Fabricate till you "puke"
I also ran a Center Force clutch set up....good stuff, & easy peddle , as orange stated Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-19-2017, 12:19 AM   #12
MikeB
MikeB's Avatar
Ron
Frankly, just about any OEM replacement kit, Pioneer, Luk, etc, will work well behind a 6 cylinder or stock V-8. AC Delco parts are imported like most others, but usually cost a little more. Just make sure you know what size you need -- 10.5" for 153 tooth flywheel or 11" for 168 tooth flywheel. There's a good chance you'll need to have the flywheel re-surfaced on a dedicated flywheel grinding machine, NOT turned on a lathe. That along with a new pressure plate and disc will work smooth as silk.
https://www.youtube.com/watch?v=f7AjwdIWh4c
Mike
Old 02-19-2017, 11:05 AM   #13
Husker
Husker's Avatar
Nice Video, Thanks.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
clutch, corvette, lt-1, z-28
