Old 10-11-2016, 01:44 PM   #2876
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by EightiesOnly View Post
If you have connected the Tach and its not working at all (same thing happened to me) you should try connecting a pull-up resistor from the tach signal to +12V key on. I don't remember what tach output that our computer was programmed to, but I believe it can be set by the programmer (lt1swap.com in our case).
See the link below for a diagram:
http://lt1swap.com/lsx_tach.htm
Thanks LC for the explanation. I vaguely remember that now.
Originally Posted by Hart_Rod View Post
Thanks for posting all the pictures Mike!
You're welcome. My pleasure Rod.
Old 10-11-2016, 01:45 PM   #2877
Low Elco
Re: 1969 Short Wide
Ha, I didn't know you knew Eric! He's a great guy, I just saw him this weekend. Yeller would not be nearly as nice as it is without him. Glad you had fun, I gotta get down there one day.
Low Elco is offline   Reply With Quote
Old 10-11-2016, 03:34 PM   #2878
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Yeah, he's good people. I wish we would have had more time to visit. He has forgotten more about LS motors and swap than most will ever know.
We need to meet up when you get down this way or me up that way.
Old 10-11-2016, 04:59 PM   #2879
Low Elco
Re: 1969 Short Wide
Bring it on, we got a bbq place just down the road with a 65 Impala for a bar and a Comp dragster hanging from the ceiling. First round's on me!
Old 10-12-2016, 12:00 AM   #2880
boynton
boynton's Avatar
Re: 1969 Short Wide
Thanks for the link. I put in the resister but it seems to be reading a little low. How accurate is your gauge? mine reads fine at 100-1,000 RPM but seems to be falling behind after that. I am assuming this is the difference between the pcm being programmed at 4cyl mode vs. 8cyl mode?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 10-12-2016, 08:03 AM   #2881
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I'm always down for some BBQ.
Mine seems pretty accurate. We have a Bluetooth scan tool code reader that gives live engine data. The tach on mine stays pretty close to it.
Old 10-12-2016, 06:54 PM   #2882
EightiesOnly
EightiesOnly's Avatar
Re: 1969 Short Wide
I just browsed through lt1swap.com and he does in fact set the tach signal to 8 cylinder mode when he does a reflash. This means that mcbassin's tach signal IS in fact 8 cylinder mode.
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 10-13-2016, 01:44 PM   #2883
boynton
boynton's Avatar
Re: 1969 Short Wide
awesome. this is my issue then. I thought it would be but wasn't sure. thank you so much for the info!!!
1970 SWB Step-Side
Old 10-13-2016, 02:04 PM   #2884
EightiesOnly
Re: 1969 Short Wide
No problem!
LC.
Old 11-14-2016, 08:03 PM   #2885
DeepOceanStepside
DeepOceanStepside's Avatar
Re: 1969 Short Wide
Just read thru your build thread...Awesome truck!!
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 11-15-2016, 09:16 AM   #2886
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks for the positive feedback and for checking out my build.
Old 02-28-2017, 09:41 AM   #2887
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Just a quick update, I have been driving my old truck when weather allows. My wife and I just made the 810 mile round trip to Conroe, Texas for the Lonestar Throwdown. It was a great show. Got to meet up with a bunch of new and old friends.
The truck performed great. Only one little hiccup when the fuel pump gulped a little air going up a long steep hill. A short delay and we were back on the road.
I plan to change a few things on the fuel setup that should prevent that from happening again.
Here's a few pictures from the trip.
Old 02-28-2017, 09:48 AM   #2888
Hart_Rod
Hart_Rod's Avatar
Re: 1969 Short Wide
Awesome pics Mike! Is your tank baffled or were you just a little low on fuel?
Hart_Rod is offline   Reply With Quote
Old 02-28-2017, 10:07 AM   #2889
MMcMasters
MMcMasters's Avatar
Re: 1969 Short Wide
Mike,
Your truck is one of my all time favorites!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 02-28-2017, 10:42 AM   #2890
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1969 Short Wide
Such a very nice truck!
Keith
Convert to disc brakes.
Old 02-28-2017, 11:06 AM   #2891
SCOTI
SCOTI's Avatar
Re: 1969 Short Wide
Originally Posted by MMcMasters View Post
Mike,
x2. The driver is ok too
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-28-2017, 11:13 AM   #2892
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
Awesome pics Mike, your truck always looks amazing!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-28-2017, 01:31 PM   #2893
Low Elco
Re: 1969 Short Wide
Been watching the coverage on ig. Truck still looks great!
Old 02-28-2017, 01:46 PM   #2894
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Rob, the tank is a standard blazer tank, so no baffles. It's the first time I've ever had this happen. I will be changing the tank and pump setup before I drive that series of hills in southern OK.
Mike,
Thanks MMcMasters
Thanks Keith, I thought we might meet up down there. I hope you are in good health. Eventually, I will see your Blazer in person. Even if it's just at Keith's shop.
Thanks Scoti, good to see you again.
Thanks Keith. It's always amazing when you cruise these trucks how folks come right up and visit about them. It usually starts with "my dad had one of these" or "my grandpa had one of these.....
Thanks Chip. I followed along last year on IG....
Old 02-28-2017, 04:37 PM   #2895
boostedc10
boostedc10's Avatar
Re: 1969 Short Wide
Nice pics Mike. Thanks for making all of us with incomplete trucks jealous
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 02-28-2017, 04:46 PM   #2896
MMcMasters
MMcMasters's Avatar
Re: 1969 Short Wide
hahaha, glad someone else said it
Mike
Old 02-28-2017, 04:59 PM   #2897
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 Short Wide
Very cool on making the trip and the truck still looks awesome! It's nice to hear you only had minor hiccup and were able to keep going.
Ryan
1969 Chevy milk truck
Old 02-28-2017, 05:09 PM   #2898
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Brandon. I have no problem providing inspiration.
Anytime
Thanks Ryan. It's fun to drive but I'm not sure I want to make the long journey again....
Old 02-28-2017, 06:50 PM   #2899
knomadd
knomadd's Avatar
Re: 1969 Short Wide
Well Mike, I looked for you a few times on Saturday, but you weren't ever around your truck (when I was). I rode with a friend and hung out all day. You're truck looks even better in person. Maybe we'll meet at another show this year, or next year at LST.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-01-2017, 01:09 PM   #2900
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks and Sorry Duane, I didn't spend much time around my truck. Hopefully we can meet up at c/10s in the park or goodguys in the fall.
