Old 03-05-2017, 07:42 PM   #151
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1970 Med Olive Project
Looks great!
ChuckDriver is offline   Reply With Quote
Old 03-05-2017, 08:18 PM   #152
Jason7121
Jason7121's Avatar
Wow nice looking exhaust!
Jason7121 is offline   Reply With Quote
Old 03-05-2017, 08:30 PM   #153
mooseknuckles
mooseknuckles's Avatar
exhaust turned out great!
mooseknuckles is offline   Reply With Quote
Old 03-05-2017, 09:43 PM   #154
MMcMasters
MMcMasters's Avatar
Originally Posted by ChuckDriver View Post
Awesome detail work on the entire rolling chassis!
Looking forward to seeing the body swap too!
Originally Posted by GR8-68 View Post
Wow !!! That is one of the nicest looking builds I have seen
Thank you !!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 03-05-2017, 09:44 PM   #155
MMcMasters
MMcMasters's Avatar
Looks great!
Thank you guys, your too nice!
Mike
Old 03-05-2017, 10:13 PM   #156
Bennett68C10
Bennett68C10's Avatar
Wow, the exhaust turned out awesome Mike!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-05-2017, 10:36 PM   #157
MMcMasters
MMcMasters's Avatar
Thanks brother!
Mike
Old 03-06-2017, 06:32 AM   #158
GR8-68
GR8-68's Avatar
Originally Posted by MMcMasters View Post
Larry,
I degreased everything then prepped the surface with 80 grit glass beed. Everything was then wiped down with wax and grease remover and sprayed with two light coats. The recommend 1mil of coverage. Just made sure the bottle was mixed good and poured directly into the gun with no thinning. It sprayed like **** but flowed out nice once it was on. 30 minute flash time between coats. I let it hang for 24 hours before I touched it. They said it is fully cured 5 days after spraying.
They also have a oven cured product but I didn't have access to an oven large enough so I went this route.
Thanks for the info Mike, I actually do have access to an oven and a spray booth where I work at the cabinet shop. I will have to check and see how hot the oven has to be though as we can only run ours up to about 180 or I risk setting the sprinkler system off I really like how you set it up as bolt together it seems to make more sense to me.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-06-2017, 08:29 AM   #159
MMcMasters
MMcMasters's Avatar
The oven cure is 300* for an hour
https://www.cerakoteguncoatings.com/...EB_1-17-17.pdf
Mike
Old 03-06-2017, 09:16 AM   #160
boostedc10
boostedc10's Avatar
Mike the exhaust turned out great! Did I miss what you did to the driveshaft? Is it spray bombed or is it CeraKoted too?
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 03-06-2017, 09:31 AM   #161
GR8-68
GR8-68's Avatar
Thanks for the link Mike, looks like I would need to go with the air cure
Larry
"Project 68"
paypal.me/ldgrant
Old 03-06-2017, 10:26 AM   #162
MMcMasters
MMcMasters's Avatar
I masked everything with the driveshaft in place. I scuffed it and used dupli-color self etch primer then finished it with Eastwood's chassis black. All rattle can
Mike
Old 03-06-2017, 10:48 AM   #163
boostedc10
boostedc10's Avatar
Thanks Mike for the info. I was looking to paint mine but was looking to see if there were any other options out there.
Brandon
Instagram: DRVFSTR
Old 03-06-2017, 12:21 PM   #164
Dustmaker65
Dustmaker65's Avatar
Take a couple days off the board to go collect "Rusty Gold" and you built a tranny bracket(twice), a complete exhaust and coated it! Mike it looks awesome! And for the drop of the mufflers, it should work great! Much smoother flow. But where are the exhaust cut outs on electric actuators?
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 03-06-2017, 12:36 PM   #165
MMcMasters
MMcMasters's Avatar
It was quick and easy and should hold up pretty good. I'm jealous you have the body on yours!
Mike
Old 03-06-2017, 12:37 PM   #166
MMcMasters
MMcMasters's Avatar
Electric cutouts would be cool but I'm a tight ass
Mike
Old 03-06-2017, 01:11 PM   #167
Dustmaker65
I have a warranty book from a 66 Chevelle I owned several years ago. Would you like to have it?
Jimmy Hoelzel
Old 03-06-2017, 01:11 PM   #168
boostedc10
boostedc10's Avatar
I am definitely going to do mine. As for the body being on, dont be to jealous it will be coming off again real soon
Brandon
Instagram: DRVFSTR
Old 03-06-2017, 01:26 PM   #169
MMcMasters
MMcMasters's Avatar
That's awesome of you to offer, that would be very cool
Mike
Old 03-06-2017, 01:30 PM   #170
Dustmaker65
Give me a reason to come see this master piece
meant to send that in a PM...lol
Jimmy Hoelzel
Old 03-06-2017, 02:05 PM   #171
MMcMasters
MMcMasters's Avatar
Hahaha
Mike
Old 03-06-2017, 02:28 PM   #172
Camaroguy
Camaroguy's Avatar
It looks fantastic! Keep up the good work.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 03-06-2017, 06:02 PM   #173
MMcMasters
MMcMasters's Avatar
Thank you, I appreciate it!
Mike
Old 03-06-2017, 07:31 PM   #174
SCOTI
SCOTI's Avatar
I get the desire to make things serviceable but you're making us guys w/un-painted d-shafts look bad.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2017, 08:06 PM   #175
MMcMasters
MMcMasters's Avatar
Now that looks good!!
Mike
