Old 02-08-2017, 02:25 AM   #1
randy500
Crew Cab build preview...
Some might have seen my posts that I was planning this build. It takes a lot of trucks and a lot or parts but it has officially started. Build thread to follow.
If you can post up the prior crew cab build threads, I read most of them I think but didn't save them.
randy500 is offline   Reply With Quote
Old 02-08-2017, 05:56 AM   #2
Hombre321
Hombre321's Avatar
Re: Crew Cab build preview...
Subscriped, this ought to be interesting...
Protected people will "Never" be able to understand the intensity life "CAN" be lived at. To do that you must completely and totally understand the meaning of the word DUCK.
Hombre321 is offline   Reply With Quote
Old 02-08-2017, 07:51 AM   #3
GR8-68
GR8-68's Avatar
Sweet !!! And am in for the ride on this one
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-08-2017, 12:15 PM   #4
68 P.O.S.
Looking good, let me know if you need a hand.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 02-08-2017, 03:47 PM   #5
randy500
Thanks for the comments guys...I feel like going out there and welding that together
but the back of that cab is just for mock up, it is kind of cool mocked up though because It's all olive or olive and white. Makes it look more cohesive than it is.
For the final product I will be using a red and white 71 GMC cab and frame. I'm using that truck so the final product will have matching VIN on frame and cab and the 71 GMC Sierra trim level. I will probably put all the Sierra Grande items on it except the door panel inserts for the rear.
Old 02-08-2017, 03:50 PM   #6
randy500
I could use a hand if your available on Saturday, I need to lug the 3/4ton frame out of my backyard and into my garage so I can build the frame for this thing. I think it would be easily manageable with 2 people. I think I have your phone number but not sure, and I'm bad with names so cant remember your name right now.
Old 02-08-2017, 04:08 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
I was kinda wondering... because you've already got enough work to do, I was wondering why you picked a cab that was so beat up. Not impossible, but that's not a fun area to fix. Lookin' good!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-08-2017, 05:46 PM   #8
68 P.O.S.
I'm free on Saturday so I can help you out. I'll send you a message.
Paul
Old 02-09-2017, 01:26 AM   #9
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 02-09-2017, 01:38 AM   #10
randy500
Paul
Thanks but I just remembered this weekend is the corvette swap meet in Puyallup, are you going to that? I'm going Saturday morning, can we do the frame Sunday afternoon?
BTW, your the guy that has the blue and white truck and bought the hood and grill from me right?
Old 02-09-2017, 12:40 PM   #11
randy500
Bumping this up so it can be found by another member.
Old 02-09-2017, 01:32 PM   #12
randy500
I guess since people are subscribed I should add something useful to the thread...
Last night I mocked up the "B" pillar on the drivers side. My plan is to cut down a drivers side door to make the 4th door so with that in mind I figured I would use a truck cab "A" pillar hinge area which should give me, strong hinge mounts, formed structure for the door jamb area, courtesy light pin switch location and weather-strip mounting lip.
As you have seen in other crew cab builds they have made their own "B" pillar to match the passenger side, I think that is too time consuming and I don't care if both sides are an exact symmetrical match so chose this method.
The suburban "B" pillar has the following problems to solve.
Its narrow and needs to accommodate, the hinges with door full open stop and the latch nut plate for the front door. Problem is the front door latch and the upper hinge is at the same height.
I will modify the front door latch nut plate to take up less space front to rear and put the door full open stop on the lower hinges. I will use front door hinges and cut off the front mounting bolt tab from the hinge and the "B" pillar, similar to the passenger side hinges. (only 2 bolts on each hinge to pillar attachment.
I will post a couple pictures of the solution tonight.
Old 02-09-2017, 01:52 PM   #13
kehstr
kehstr's Avatar
Love crew cabs, into watch this!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 02-09-2017, 03:13 PM   #14
Hart_Rod
Hart_Rod's Avatar
In
Hart_Rod is offline   Reply With Quote
Old 02-09-2017, 10:49 PM   #15
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Crew Cab build preview...
looks like a fun build to watch
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 02-09-2017, 11:14 PM   #16
1972RedNeck
1972RedNeck's Avatar
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-10-2017, 12:40 AM   #17
Shinysideup
Shinysideup's Avatar
Very interesting, did you start with a burb body, hack off the rear, then add a truck back of cab? Or are you franken-fabricating the needed pieces for B pillars and rear doors?
Sorry if its obvious, I feel like I'm late to the party.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 03-02-2017, 12:44 AM   #18
randy500
Made a little progress past week or so. Repaired the driver side floor and rocker rust. I also made the driver side B pillar which mounts the 4th door, the door is full length for now, mounted and swinging. Next project is to shorten up that door.
Old 03-15-2017, 07:41 PM   #19
randy500
A friend asked me today if I had any pics of the build, I told him no and thought I hadn't made any progress since I had a big setback this weekend. Then I thought about the work I have done lately and decided to post up.
I found out the following:
Using the front door hinges will not work.
And measure before welding.
A couple pics of my progress.
Old 03-15-2017, 08:11 PM   #20
randy500
Well the door is now the right length hanging and swinging. The window regulator should work in the new position and the front interior panel of the door is the right shape to fit the contour of the B pillar. So I guess that is progress.
Problem is the hinges, they don't allow the door to open far enough because the front of door overhang on the rear doors is too great for the hinges. I found a set of 3rd door hinges from a member here on the forum and they are on the way, wont be here to work on this weekend but at least they are secured.
The door is now the right length and form except for the door skin at the front. The front of the door skin as anticipated will need be sectioned to match the contour of the back of the front door.
My other setback was when I sectioned the door lengthwise, I allowed some room for error, about a 1/2 inch in length to grind down for good fitment, well it fit so well on the first cut I welded it up and the door was too long when I hung it, then I remembered I cut it long on purpose so I got the pleasure of cutting, fitting and welding it twice.
As you can see in the picture I have a new helper...her name is Roxy. She is my sons dog.
Old 03-15-2017, 08:44 PM   #21
flashed
Im in for this one .
flashed is offline   Reply With Quote
Old 03-15-2017, 09:09 PM   #22
Getter-Done
Getter-Done's Avatar
I'm Sub'd also.
You are giving me some (bad ideas).
I got 29 or 30 inches behind my (cab and chassis) Cab with 157 WB.
Getter-Done is online now   Reply With Quote
Old 03-15-2017, 09:56 PM   #23
randy500
Originally Posted by Getter-Done View Post
I'm Sub'd also.
Then let me entice you, WB of crew cab short bed is 148, long bed is + 12 for 160, your right there
Old 03-15-2017, 11:24 PM   #24
zicc1835
zicc1835's Avatar
Sub'd��
zicc1835 is offline   Reply With Quote
Old 03-15-2017, 11:55 PM   #25
67chevy_hotrod
67chevy_hotrod's Avatar
Randy, if you need a hand with anything you know you can always reach out to me!
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
