Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-22-2017, 10:47 PM   #1
71chevc10
Push Brake Pedal and right turn signal comes on???
Hey All
Im having this recurring problem when I push the brake pedal the right turn signal lights up meanwhile the right turn signal still functions normally when used
this happens and then goes away and comes back again
any ideas would be much appreciated
thanks
71chevc10 is offline   Reply With Quote
Old 03-22-2017, 11:08 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Push Brake Pedal and right turn signal comes on???
Start off with running lights and flashers, and see what you get, walking around the truck. Might just be a bad bulb.
~Steven
Simi Valley, CA
Old 03-22-2017, 11:20 PM   #3
71chevc10
All the bulbs are fine and the turn signal functions like normal
when the brake is applied the right turn signal lights up for as long as the pedal is pushed then sometimes it goes away
Old 03-23-2017, 08:18 AM   #4
Mike C
Mike C's Avatar
You have a ground issue somewhere in the brake circuit most likely. It's a poor connection and somehow grounding through turn signal circuit. Most likely the rear brake light housing.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-23-2017, 09:52 AM   #5
Moose Monkey
Moose Monkey's Avatar
The turn signal switch is broken. Take test light CK yellow then green at curved plug coming from turn switch.step on brake.yellow and green live. Wiggle turn up and down little at a time . se e if right ( green if I remember correctly) stop light goes on and off.Got same problem
Moose Monkey is offline   Reply With Quote
Old 03-23-2017, 10:55 AM   #6
71chevc10
Thanks Guys!
Old 10-21-2020, 08:12 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
Has this issue been resolved? I have the same issue after replacing my turn signal switch. The problem I had before replacing the TS switch was no brake lights. Now everything works as intended, including both brake lights, except that when the brake pedal is pushed the RF parking light comes on and the RH indicator on the dash comes on as well. All other lights work as intended. The TS switch is an ACDelco NOS part, and is identical to the one I removed, all wires in the same positions. Any help is appreciated.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-21-2020, 09:01 PM   #8
RustyPile
RustyPile's Avatar
Your NOS turn signal switch is defective..
RustyPile is offline   Reply With Quote
Old 10-22-2020, 07:42 AM   #9
70STOVEBOLT
What would be the defect, and how can i correct it?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-22-2020, 01:12 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
What I would do to troubleshoot the lights and the turn signal switch is to unplug the column connector and run a jumper between the brown wire and the dark blue wire (front right turn and indicator lights power wire) and see if you get dim lights. This would indicate a poor ground on the light housing. If they are bright then use a multi meter on the turn switch column plug and check the ohms between the brown wire and the dark blue wire and check for near zero ohms when you select right turn. If you get high resistance then the contacts in the TS switch are corroded or dirty and you are not getting full voltage through the switch.
Here's a good thread on the turn signal switch.
http://67-72chevytrucks.com/vboard/s...d.php?t=695511
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-22-2020, 01:17 PM   #11
70STOVEBOLT
VetteVet I appreciate your knowledge and help. I will check this out when I get a chance and report my findings. One question, do the lights need to be on or off while testing?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-23-2020, 09:26 PM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You'll be putting voltage to the lights so they will need to be off, which they will be once you disconnect the column connector. If you meant the headlight and parking lights, then off. They are on separate circuits so you won't want them on.
VetteVet
Old 10-23-2020, 09:26 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Be sure and give us follow up on what you find.
VetteVet
Old 10-26-2020, 10:22 AM   #14
70STOVEBOLT
I forgot to ask, key on or off?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-26-2020, 08:18 PM   #15
Andy4639
Old member
Andy4639's Avatar
Question Re: Push Brake Pedal and right turn signal comes on???
There was a thread on here about 6 months a year ago about the newer turn signal switches having a bad clearance problem that was letting the lights stay on. Can't remember where though.
Anybody else remember it?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-26-2020, 08:27 PM   #16
70STOVEBOLT
This is an old NOS switch, came in one of those cardboard canisters with the metal lid that you have to peel the strip to open. It looks exactly like the one that was in the truck when I bought it 20 years ago. I know that doesn’t mean that one was original though.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-27-2020, 11:42 AM   #17
70STOVEBOLT
I think I ran across that when looking for info. Some of the aftermarket switches have a gray metal piece on the back that encroaches on the area that the cancelling cam is located and shorts out on the cancelling cam. I did not check that since mine is NOS but I will just to make sure.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-03-2020, 04:50 PM   #18
70STOVEBOLT
Bringing this back to the top, as I have had no luck in finding the source of the problem. I really do not believe it is in the turn signal switch, but it may be. Could the black wire from the horn relay have anything to do with this? I have a constant draw also that I have not been able to solve and believe that may be related to the horn relay, so I was wondering if both problems could be related, pointing to a problem with the horn relay? I read a thread on here today about a member having a constant draw issue that turned out to be the relay.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-03-2020, 09:35 PM   #19
Andy4639
Old member
Andy4639's Avatar
The horn relay in these trucks only work the horn. Is the horn working when you hit the horn button? Disconnect the horn out under the hood and see if it stops are take the relay wires off see if it stops the draw.
Are you talking about the lamp in the dash is coming on when you hit the brake pedal? If so pull the cluster out and check the printed circuit good. Look at the light bulbs circuit. I just had to fix mine.
Old 11-04-2020, 08:48 AM   #20
70STOVEBOLT
Andy, when I push the brake pedal the dash indicator for the RH turn signal comes on and the right front turn signal lights up also. The horns work when the button is pushed. The horns stopped working at one point and I replaced the relay and they started working again. I think that is when the battery draw started, so I thought there might be an issue with it.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-04-2020, 10:42 AM   #21
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Push Brake Pedal and right turn signal comes on???
Check out this post from me about my cluster. You may have some thing like this happening.
http://67-72chevytrucks.com/vboard/s...d.php?t=813932
Old 11-04-2020, 11:35 AM   #22
70STOVEBOLT
I will check the printed circuit, it was ok when I installed the cluster (bought it from Tom) a couple years ago but I know things happen over time. This all started when I decided to replace the rear lighting harness after installing my new bed.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-04-2020, 04:30 PM   #23
Andy4639
Old member
Andy4639's Avatar
I would start back there then. Take the harness loose at the water connector on drivers side frame rail the last connector and take your test light and check it. If it's back feeding through to the front lights are a wire is swapped.
Old 11-04-2020, 05:10 PM   #24
70STOVEBOLT
I should rephrase that. I decided to replace the rear harness due to the rear turn signals and brake lights not working properly and that didn't fix the problem, so I replaced the turn signal switch with an NOS unit and now the the rear turn signals and brake lights work but now I have the current issue.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 11-25-2020, 11:28 PM   #25
70STOVEBOLT
SOLVED! The NOS switch is indeed apparently defective if it’s not correct for our trucks. I checked out the original switch and found the terminal for the brake lights in the half moon connector was missing. So I found another black wire with the same terminal and soldered it on and used shrink tubing to seal it. Now all lights, turn signals, and flashers work properly. Thanks to all who responded, I appreciate it greatly!
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
