Old 03-31-2017, 01:48 PM   #1
nevada
Anti-Theft ?
Ok, so once my truck is all painted, mechanically right, I will still have one problem.
I will be worried to leave overnight in a parking lot when staying at a hotel, or parked on the street, hell, even going to warlmart.
The doors are so easy to slim jim and the dash ignition to reach under and hot wire.
What do folks on this site do to protect their investment??
nevada is offline   Reply With Quote
Old 03-31-2017, 01:58 PM   #2
In The Ten Ring
Re: Anti-Theft ?
This is a topic that comes up from time to time.
1). Don't drive your truck. Leave it garaged and let it be "used" online in pictures.
2). Get a big friend by the name of "Bubba" and pay him to sit in your truck. Pay him a bounty for every theft he stops and a bonus for every face he caves in or heart/lung/liver complex he penetrates with lead and copper.
3). Get a big dog that loves to bite. Leave it in the truck.
4). Battery disconnect. Apparently easy to do and very effective.
5). Fuel cut off valve. Easier to do if you left your fuel tank behind the seat.
6). Brake jack. Available online and makes the foot brake impossible to use.
7). Lojack/other tracking devices. Apparently a great idea and would go well under the seat.
8). Three speed on column. Few have ever seen one and most people cannot drive a manual anymore anyway. Not foolproof, a member had his 3OTT stolen last year.
9). Removing the shifter lever and taking it with you.
10). Chaining your rear axle to things.
In The Ten Ring is offline   Reply With Quote
Old 03-31-2017, 01:58 PM   #3
demian5
demian5's Avatar
Re: Anti-Theft ?
I have been mulling this over myself.
1. Get some kind of lock for your hood. On any old vehicle, if they can reach the motor, they can start it with a couple extra loose wires. Think about the remove hood release for the latch or a chain.
2. If they can get in the truck, they can start it be accessing the wires under the column with a couple extra loose wires. They also have the ability to open your hood once they get in your vehicle if it has a remote release (hence the lock recommendation).
3. Splice your kill stuff into your LOCKED engine compartment.
Make it simple for you but something that will never bee seen as a security system. Like a relay where you have to push in the lighter for the ignition circuit to work. Or some kind of inconspicuous switch that activates a relay that allows current to the starter or coil.
I remember putting relays into the power window circuit so the car wouldn't crank unless you were pressing the passenger rear window switch in the down position (rolling down the window, but also energizing the relay).
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-31-2017, 02:18 PM   #4
cleszkie
cleszkie's Avatar
Re: Anti-Theft ?
I keep the brain for my MSD Atomic EFI in my glove box. I simply unplug it and take it with me. This won't prevent someone from towing my Blazer away, but they will never drive off with it.
cleszkie is offline   Reply With Quote
Old 03-31-2017, 02:24 PM   #5
JustToxic
JustToxic's Avatar
Re: Anti-Theft ?
One option you have is switching it to a smart key set up. Which means you remove the ignition key and carry a key fob like most modern cars, and use a push button to start the vehicle. Digital Guard Dawg is a company that makes a good universal one to wire into your system. Here is a link http://www.digitalguarddawg.com/auto...e/pbs-i#videos
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 03-31-2017, 02:32 PM   #6
67/Heaven
67/Heaven's Avatar
Re: Anti-Theft ?
Install a 12v dc pulse on pulse off latching relay, that way once the relay is activated it will not require constant power as this can lead to failure. Install it under your hood to your HEI distributor hot wire. Control the pulse on or off with a 12v wireless remote. All easily found on ebay for about under 30 bones. Make sure your hood is secured with a lock of some type of whatever you choose. The "on" on your remote will latch the relay to close and supply your HEI (or starter solenoid control wire if you don't have an HEI) and the off as you lock your truck will open the circuit. This is slightly different than a kill switch wired into an alarm as I found out that simply removing the connector will allow the vehicle to start. In essence this is a wireless kill switch with no need to hide it as you will be carrying the remote with your keys. If they can not open the hood you should be okay. Anything can be stolen, all you can really do is slow them down or discourage them.
67/Heaven is offline   Reply With Quote
Old 03-31-2017, 02:57 PM   #7
El Dorado Jim
Re: Anti-Theft ?
hidden kill switch under dash,for HEI wire.....chain locking the hood down............also there is the "trunk monkey" https://www.youtube.com/watch?v=JV-XEiUOjYE
El Dorado Jim is offline   Reply With Quote
Old 03-31-2017, 03:00 PM   #8
weq92f
weq92f's Avatar
Re: Anti-Theft ?
In general, tbi/efi systems do have an advantage in this arena. More options for disabling ignition/start of motor. Even a real smart thief likely couldn't start mine when I've "enabled" my counter-measures ( MSD Atomic as well ).
Walking away with the Atomic unit in hand, well, that is a good idea.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-31-2017, 03:26 PM   #9
hamjet
hamjet's Avatar
Re: Anti-Theft ?
Drive a truck like mine and you don't worry about someone stealing it..LOL
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-31-2017, 03:28 PM   #10
DBK81
DBK81's Avatar
Re: Anti-Theft ?
I've yet to see a vehicle get stolen with a quick detach steering wheel that isn't there. Driving with a set of vice grips on a steering colum takes allot of balls and allot of skill my guess that the potential thief will be lacking one of if not both of those things.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 03-31-2017, 04:27 PM   #11
67/Heaven
67/Heaven's Avatar
Re: Anti-Theft ?
This will pretty much do what I described above, but it does it by disconnecting the battery. It could be wired to the starter to avoid losing radio presets and keyless or alarm functions as well as other options.
https://www.amazon.com/WirthCo-20395...5CZWCZG8M0JVBS
Old 03-31-2017, 04:45 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Anti-Theft ?
If leaving outside overnight, even before restoration I'd disconnect the battery, lock the steering wheel and doors, and flip the kill switch. Still no guarantee, but it would be almost fun watching someone try to theft the truck.
If you have an HEI then a kill switch is easy. Mine was just a 12 AWG wire from the switch to the smaller connector point at the distributor, which is the receptacle closest the firewall.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-31-2017, 10:01 PM   #13
Coley
Coley's Avatar
Re: Anti-Theft ?
Some great ideas here.
I don't live (currently) in a high theft area for vehicles but I would put myself in a thiefs shoes for a minute and then solve it from there.
Any thief wants a quick, quiet, clean get-away...with absolutely no attention drawn to them.
So in my books any of the above measures for preventing the start electrically is a good idea...then anything that allows the truck to move, at most, 50ft or 3-4 secs before an absolute stall or freeze is a good idea. If the vehicle stalls in the street...that guy will run....at least that is my thought.
Again...no one is going to start troubleshooting an immediately stolen vehicle in the middle of the street...they will bolt. They might troubleshoot it while its still quietly parked tho'....because nothing is obvious there.
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 03-31-2017, 10:42 PM   #14
truckster
truckster's Avatar
Re: Anti-Theft ?
I love the trunk monkey. Unfortunately, our trucks don't have trunks...
I plan to use a relay for the 12v to my HEI and use a hidden cutoff switch to the relay. It might be something hiding in plain sight, like needing to push in the cigarette lighter before the truck will start.
truckster is offline   Reply With Quote
Old 04-01-2017, 01:20 AM   #15
el_fantasma
el_fantasma's Avatar
Re: Anti-Theft ?
I bought one of these a month ago and it works great. It also saves you if you leave the headlights on. I'm going to try a move mine to where it is hidden instead of sitting on top of the battery
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 04-01-2017, 02:33 AM   #16
El Dorado Jim
Re: Anti-Theft ?
get a tonneau cover for the monkey he will love all the room in the bed! or a camper shell
Old 04-01-2017, 02:45 AM   #17
James the III
Re: Anti-Theft ?
The kill switch you'll have to have a novel idea, as the basic ones, They will know as soon as it won't start to look for.. I.E. the cig lighter, the turn on the parking lights.etc.
Ever see any vehicle start and run/move with a completely closed choke, ? me either..
Greatest thing about the new vehicle drive by wire, is you can put a throttle body in line of the air feed on a closed air cleaner.. and have it shut.. so the engine is getting almost zero air.. , and a simple relay, will open it for normal use..
Again, ever see a vehicle run and move with a completely closed choke?
Can even make this a manual, with a cable and a vent knob in the cab.. ( the ls one and others fit nicely in the round end of a closed air cleaner,that used a hose to the nose of the vehicle, not the ones that have the horn looking end.. ) paint it black.. and it can be manual cable opp.. or electric..
James the III is offline   Reply With Quote
Old 04-01-2017, 03:02 AM   #18
burnin oil
Re: Anti-Theft ?
I got a chuckle out of this. When I lived in SOCAL my roommate had an old Toyota pickup. The motor let go and we were putting a new timing chain and a 20R head on to fix it. Thieves tried to steal it 3 separate times. Ironically the battery was in the passenger floor board and all the motor parts were laying in the bed the entire time!
Different apartment I got deployed and had someone try to steal my firebird. Tore the door open with a can opener trying to access the linkage rod and left a foot long hole in the door. They didn't get into the car because they kept yanking on the rod. I got move and pushed on the linkage and the door instantly unlocked. I assume the same idiot stole the cassette deck out of my truck but left the disc player under the seat (yes this was awhile ago).
burnin oil is offline   Reply With Quote
Old 04-01-2017, 03:28 AM   #19
In The Ten Ring
Re: Anti-Theft ?
I'm sorry your property was damaged. My whole state has seen a vast increase in theft and it's a very sad thing.
Old 04-01-2017, 11:53 AM   #20
Mike harris
Re: Anti-Theft ?
Disconnect the battery and install one of these. They'll lift the hood and BOOM!! even if it misses them there's a pretty good chance they'll run away haha
Mike harris is offline   Reply With Quote
Old 04-01-2017, 01:40 PM   #21
Will Rotten
Re: Anti-Theft ?
Nobody is stealing mine easily... But the could rob parts under the hood.
Will Rotten is offline   Reply With Quote
Old 04-01-2017, 02:59 PM   #22
HO455
HO455's Avatar
Re: Anti-Theft ?
This has interested me, but I'm not yet at that point in the project.
http://nohotwire.com/product/about-ravelco/
RIP Bob Parks.
Old 04-01-2017, 10:20 PM   #23
James the III
Re: Anti-Theft ?
make your own.. a ubs outlet, and cable end "key"
or a mini headphone jack..
in the 80's when 3rd gen t/a's were very high theft..
mine was you had to push the speedo, "trip" counter reset button and turn key..
My s-10 you had to turn on the radio.. that was wired unswitched power.. and the power antenna trigger lead powered a relay.. and it start.. radio off. no start..
My chevelle, you had to close the ash tray..
