#201 |
Re: What did you do with your truck today, Part 3
#202 |
#203 |
#204 |
Looking very nice.
#205 |
Sorry wrong thread. I tried to delete this post.
#206 |
My truck caught fire about 8 onths ago when a fuel injector cracked and sprayed fuel all over. Been doing what i can to get my daily driver of 8 years back on the road. Took the fuel injection off and am in the process of installing a quick fuel carb. Should be ready to fire it up this week or this coming weekend.
#207 | |
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#208 |
got my vintage plates on the truck
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
#209 |
worked on the death rattles resurrection from the fire. I fixed one problem only create another that's got me scratching my head. I have fixed the fuel issue but now I have no spark. so I get to think about this for the next few days..
#210 |
Brought the 59 chevy short bed frame in to do some more welding on the frame and getting ready for paint. Wish I had my own shop but a friend's will do need and all lol.
UPDATE 🤔 didn't get it painted but I got everything welded on the frame got all the grim and grease off the frame and pressured washed and back into the shop to dry for the night will start and fire in the shop to get it warm and paint it in the morning will post it when it's done. Last edited by 59chevy310p; 04-25-2017 at 12:54 AM. |
#211 |
Well finished the paint on the frame now I have I baking in the shop to dry. I think it turned out pretty good didn't think it was gonna turn out this nice So now I'm gonna take the leads apart and do them and the axles as well now. Can't believe how it turned out doing it with a brush.
#212 |
looks good from here. those are some heavy duty axle stands you have there. a couple look like the axle tubes from an old tractor.
#213 |
Ya they axle off a like model T. They work really good I don't truck these cheap ones never had a issue with them. And I made them adjustable too
#214 |
Don't forget to take the front suspension off, getting ready for IFS. It would be much easier with just the frame to work with. PS: You will go with IFS if you drive it much.
#215 |
before you take front end off, if getting ready for IFS, centre punch a mark on the frame that denotes the axle centreline. you will need that later, especially if you plan on lowering the truck at all. also, while it is up in the air anyway, do a frame check for out of square (corner to corner check-not more than 1/8" out of square) and a check down the middle of the cross members to see if the frame is straight front to rear and up and down (swayback or sag). better to catch it now than later.
#216 |
here is the chevy page from the assembly manual on how they recommend to check the frame.
hope it helps. |
#217 |
Well sorry for all the post about painting my frame but really excited to get this truck done this was suppose to be our wedding truck but then went and bought a 58 gmc truck for the wedding, gotta love my wife for letting me have all these trucks . But anywho the frame is complete and done axles are painted tomorrow all the fuel lines and brake lines will be put back on and then start on the body.
#218 |
![]() Join Date: Jun 2007
Installed a seat out a 2005 Chevy and took it out for a drive. It is so much more comfortable to drive with the new seat.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
#219 |
nice looking truck. no snow up there? we have some sun on and off but not to warm today.
#220 |
No snow on the ground but it still feels like winter in the air. Need some warmer weather soon!
#221 |
I was down at my sons shop last week, first time I had seen my truck since Christmas when he picked it up. In case anyone is wondering, like I was, the new rear cab panel for the BBW converson had a Key Parts label and no hole for the fuel filler. I've used Key parts before so I'm fine with that, and happy that there's no filler hole.
#222 |
My wife and I drove up to Cave Creek to the Dairy Queen, and sat in the truck eating blizzards like a couple teenagers.
She understands what that stupid old truck means to me, and goes along for the ride whenever she can. I love that woman!
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
#223 |
Picked up my new power plant today. Can't wait to get that 5.3 motor on the freshly painted frame. But first I have to paint the motor and get it cleaned up.
#224 |
We have come a long way, haveen't we?
a run of the mill truck engine from a stocker has aluminum heads, plastic intake, a coil for each cylinder, and a computer to get the fuel mixture and timing correct while shifting the transmission and supplying signals to run the electronic gauges. Then it troubleshoots the engine and tells you what's wrong!! It's a 102 degrees today. I'm going to let the truck rest today and drive the corvette. It will be cooler this weekend. I gotta finish the air in the truck. The biggest problem is the glove box door. The door drops down right where I put the louvers for the air conditioner, so i'm going to make some slides that slide the door back towards the passenger's knees. That way, the air will look good, and I don;t lose any functionality with the truck. I found some slides for an aircraft ice bucket that are ball bearing, so I'm going to use those.
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 05-04-2017 at 04:55 PM. |
#225 |
Born when lead was good for us
![]() Join Date: Nov 2010
I made 62 door panels fit my '56
Not sure if I'm doing the insert picture right?
"Anyone can restore a classic, but it takes real hangin' nuts to cut one up" |
