66 front suspensio swap, help!
I have a 1966 c10 and want to swap out the front and rear suspension to get 5 by 5 lug, power disc brakes and power steering. Will an 87 c10 front suspension line up? I have seen posts where 73 to 85 will but 87's are the same, or are they. Can anyone help? Looking at buying an 87 c10 parts truck and swapping out.
Re: 66 front suspensio swap, help!
it should , i bought a 1987 r30 for my 66 c-20 and swapped the whole front and rear end, i just bought some parts from capt fab for the power steering and hydro boost brakes.
thanks, going to go look at the 87 today. Where do I buy capt fab items?
look under the 60-66 for sale section and you'll see his ad, Power Brake Booster Adapter Bracket (Multi-page thread 1 2 3 4 5 ... Last Page) this is his power brake booster bracket, but look under his name it should have his other stuff also
i see your location is Gettysburg, i'll be going there in July for bike week
64-66 CHEVY JUNKIE
As Long it's a Square Body C-10 you'll be fine. . Get the Power Steering Gear Box Mounting Bracket also from Capt Fab, So you can mount the center-link and Power Steering Gear Box as One Unit....
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
One foot in front of the other
![]() Join Date: Aug 2008
Here you go:
http://67-72chevytrucks.com/vboard/s...339081&page=15 Also check out the FAQ section in 60-66 Area. Invaluable info there. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've done them both ways, but it's quicker and easier to just swap the 73-87 parts onto your existing crossmember. Either way, it's up to you, but if you have your engine in place, it adds a lot of work swapping the crossmember itself. The 73-87 upper and lower arms will bolt right onto your existing crossmember.
Be sure and swap over steering components (tie rod ends, adjuster sleeves etc) and spindles as well. I've ran into problems when you try to intermingle the components from different years and the outer tie rod ends wont drop into the hole on the steering arm.
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
