05-05-2017, 11:13 PM | #426 |
Re: How about some pics of '73-'87 Long Beds Part II
Well building a car or truck is one step at a time for us normal budgeted people, cool to see the lift, gives an idea of what's coming, nothing but better.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-09-2017, 08:28 PM | #427 |
Here are some pics of Big Ugly after the new wheels and tires. I'm pleased with how she looks.
05-09-2017, 09:02 PM | #428 |
It followed me home?
can you tell me about your steps? Nice truck
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
05-09-2017, 09:53 PM | #429 |
I believe the brand is Iconic, and they are the factory style running boards. ABS plastic with aluminum support on the underside. Pretty sturdy👍
05-10-2017, 07:47 PM | #430 |
Well that is way nicer, don't see the ugly though just coolness.
Mudman.
05-10-2017, 11:02 PM | #431 |
Thanks madman. I like the way it turned out. I wouldn't mind it a little taller, but I'm battling driveline and pinion angles right now and I believe it would be pushing limits of drive ability and comfort with much more lift.
05-10-2017, 11:14 PM | #432 | |
It needs a good bit of sorting out and will very likely need a new motor soon but IDGAF!!! Imma drop it on its chin and bash the **** out of it until something pops and then a carbed LS will make its way into the mix. Teaser shot of some new footwear... Last edited by Poop du Jour; 05-11-2017 at 12:57 AM. |
05-16-2017, 08:14 PM | #433 |
84 Chevy on 05 frame. 6.0 4l80 3 link Dana 60 coils 14 bolt 456s
05-18-2017, 02:15 PM | #434 |
Goals for my 77 bonanza. Currently awaiting lots of parts. got the axle flipped and the front drop spindles going on tonight. Looking for a CNC water jet cutter that is willing to cut the rally wheel holes into a set of 22" transits for me. Like i said goals. Ill post pictures once i get it back on the ground tonight. Hopefully.
instagram - @custom.chevy |
05-18-2017, 02:18 PM | #435 |
Wheels on, repping that squarebody!!
05-18-2017, 03:57 PM | #436 |
Here's my 79 C/20 Silverado original paint no rust
05-23-2017, 02:45 PM | #437 |
Just picked up my first Square body.
1st picture is after a bath and removal of the running boards. 2nd picture is the truck lamenting in the previous owners driveway.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
05-26-2017, 12:14 AM | #438 |
1977 Gmc original 39,000 miles on body and interior. High Performance 355 c.i motor ,T.c.i sizzler th350 with 9 inch stall converter,Auburn limited slip diferrential. With 4:11 gear...just using as a cruise night truck needs big meats in back for some traction.Will be adding some Wider tires but a little pricey for setup Im wanting...Want to keep original hubcaps..
05-26-2017, 08:02 AM | #439 |
Nice truck Tone210.
Romans 10:9 - The Truth |
05-26-2017, 08:43 AM | #440 |
Thanks one of the coolest trucks I've owned, heres a pic when it was stock
05-26-2017, 12:37 PM | #441 | |
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
05-26-2017, 12:45 PM | #442 |
Thanks... its been clear coated on both sides but still needs hood ,roof & tailgate sprayed
05-26-2017, 03:20 PM | #443 |
1973 GMC Pick-up. 350 small block, 3 speed manual, 8 lug
05-26-2017, 03:24 PM | #444 |
Just picked this one up. Looking at doing the exhaust first. Need some dog-dish caps for the wheels and I got some rust on the roof. Old school body and paint job done sometime ago. 83K miles, original motor, trans, floor pans have been replaced, tailgate rusted up as well.
05-28-2017, 09:07 PM | #445 |
05-30-2017, 12:30 PM | #446 |
the truck after some stuff installed. needs trim
05-31-2017, 09:42 AM | #447 |
New here and a pic of my 86 still a work in progress. cant read its my first day.
05-31-2017, 09:52 AM | #448 |
That's a tight square you've got there, unfortunately you're too short to ride this ride!!
Posted via Mobile Device |
05-31-2017, 12:40 PM | #449 | |
Nice truck for sure.
06-03-2017, 09:14 AM | #450 |
Sorry guys didn't mean to run my small bus into your thread..I tried to remove.. I am an idiot!
