Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 11-22-2001, 06:24 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post HEI swap
A REAL EASY, CHEAP, AND PRACTICAL UPGRADE YOU CAN DO TO ANY OLDER G.M. VEHICLE, WOULD BE TO DROP IN AN H.E.I. DISTRIBUTOR OUT OF A MID TO LATE '70'S CHEVY.
IT'S A STRAIGHT FORWARD SWAP, THAT IS ALMOST AS EASY AS PULLING THE OLD AND DROPPING IN THE NEW. ABOUT THE ONLY THING TO REMEMBER WHEN DOING THIS, IS THAT IN ORDER FOR THE H.E.I. TO WORK PROPERLY, IT WILL NEED FULL SYSTEM VOLTAGE. THE WIRE GOING TO YOUR COIL WILL NOT SUPPORT THIS KIND OF LOAD. THE BEST WAY TO DO THIS, IS TO PLUG THE HEI FEED WIRE INTO THE IGN. UN FUSED LOCATION ON YOUR FUSE BOX, AND RUN THE NEW WIRE OUT TO THE DISTRIBUTOR. WHILE DOING THIS, THE YELLOW WIRE GOING TO THE STARTER CAN BE DELETED ALSO. THE 2 WIRES CAN BE SNIPPED, OR TAPED AND TUCKED AWAY.
ONE OTHER THING TO REMEMBER WHEN DOING THIS, IS YOU WILL NEED A NEW SET OF PLUG WIRES. FOR A FEW BUCKS MORE, YOU CAN HAVE HIGH QUALITY WIRES THAT WILL GET ALL OF THE NEW FOUND POWER TO YOUR PLUGS.
FOR A LITTLE MORE POWER AND ECONOMY, PUT IN A HOTTER COIL AND AN AFTER MARKET ADVANCE KIT.
THIS EASY MODIFICATION WILL REWARD YOU WITH EASIER STARTING, BETTER GAS ECONOMY, AND LONGER PLUG LIFE. NOT TO MENTION THAT YOU'LL NEVER HAVE TO MESS WITH THE POINTS SYSTEM AGAIN.
The hot rod;
a'69 G.M.C. Short/Fleet. 350 W/a heluva cam and nice stance. Still a beater though. Trying to clean up the left over damage from the Dope-Smokin-Old-Man...a real bummer. See it at http://geocities.com/andys_69_gmc/
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Check out my Longhorn site at http://geocities.com/MotorCity/Flats/8752/
IM me on Yahoo pager...cockroach93.
hey, stop laughing!!!
Longhorn Man is offline
Old 03-29-2002, 08:30 AM   #2
Yukon Jack
Yukon Jack's Avatar
Post
To keep info on HEI in an easy to find spot I'm adding this info posted by members regarding HEI.
bigjimzlll: I bought a proform HEI..its a hi performance..higher volt coil..better advance curve..low saturation module..they cost about a 150.00 ..thats a brand new bolt in set up...its a simple install...just run a #10 wire from the unfused ignition terminal on your on your fuse block to the HEI..do away with the resistor and wire from your starter to the old distributor..and new plug wires.
Fast68Chevy: any HEi distributor on any chevy V8 without the extra 4 pin flat wiring plug will work, make sure it has the vacuum advance diapragm on it(not ESC controlled in some of the 81-up vehicles such as camaros firebirds pickups, etc) caprices and impalas and such didnt have that stuff tht Ive ever seen.
Run new feed wire form instrument panel fromt he ign unfused port, and use inline fuse, and do away with the old white wire that goes to + on the coil and also do away with the yellow wire thjat goes to + on coil and goes from there to R on the starter solenoid.
Project1970: Everyone else already got it as far as the install (just in case - you need new wires, of course) but as for what to expect when you get it done...well, when I did mine...I got a better idle, easier starts, and - the best part, and I've got numbers to back them both up! - a boost of nearly 20hp (191 to 208) and 2 miles per gallon (from 7.7 to 9.7!!) - and I still haven't regapped the plugs for HEI. I'll probably pick up a little more all around once I widen the gap to .045 or so.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline
Old 04-10-2002, 10:42 AM   #3
Yukon Jack
Yukon Jack's Avatar
Post
BigJackDaddy posted the following diagram
Old 12-18-2002, 03:42 PM   #4
kxmotox247
kxmotox247's Avatar
This is quality information here. I wanted to respond to keep the post going.
I switched to an HEI and I couldn't believe the difference.
To hell with the points type.
Thanks for the diagram.
kxmotox247 is offline
Old 12-23-2002, 05:27 AM   #5
GMC Jim
GMC Jim's Avatar
HEI-- Cent & Vac advance
I purchased my H.E.I. unit from a firm that specializes in distributors, re-building ; including H.E.I. I was told they would calibrate the unit to factory specs or what I might desire...
I furnished the specs as outlined in the GM Service Manual for a 402 engine. Centrifugal advance - - [ degrees] ( 0 @ 930 RPM )
(2 @ 1260 RPM ) (16 @ 2400 RPM ) 30 @ 4400 RPM). GM also specifies ( 0 degrees vacuum advance @ 8" Hg ) ( 20 degrees vacuum @ 17" hg ). Purchased a new vac advance as old one was not in calibration.
I installed the distributor on the engine and set it up per previous stated specs. I also have another reference which, I believe is a great cross check and is not difficult to accomplish!...
This manual "1971-80 Tune-Up Specifications" published by GM-AC-Delco ( Man # SD-100 ) This reference states that centrigal spark advance @ 2000 RPM should be 10-13 & total advance ( incl. vacuum) should be 28-35.
So, I dialed in the timing lite 32 degrees; set engine speed at 2000 read on the "0" mark on the c/shaft damper timing indicator.....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline
Old 01-12-2003, 10:44 PM   #6
our64
http://public.fotki.com/street
our64's Avatar
Does anybody know..can I get a HEI from a 250 6cyl and use it in my 64..Think I got a 230 CID
our64 is offline
Old 05-08-2003, 10:07 PM   #7
jimfulco
I used a 65 Chevy II distributor and coil when I broke my 77 6cyl. distributor shaft.
jimfulco is offline
Old 11-02-2003, 01:47 PM   #8
mutant-jimbo
mutant-jimbo's Avatar
i have always had HEI, but am thinking of getting the hotter coil package i see in summit. i didnt know it helped gas milage.....
"Texas is an outrage when your husband is dead, Texas is an outrage when they pick up his head, Texas is the reason why the presidents dead"-bullet by The Misfits
mutant-jimbo is offline
Old 11-02-2003, 03:53 PM   #9
Longhorn Man
It does...but you will never see the increase, to say it is minimal is an understatement.
Old 01-29-2004, 01:07 AM   #10
dinnut
dinnut's Avatar
if im going to run my pink hei wire from the ign unfused port... do i need an inline fuse?
70 longbed
496/th400/Ford 9"
dinnut is offline
Old 01-30-2004, 10:39 AM   #11
Longhorn Man
Yes you will.
Old 09-19-2004, 09:22 PM   #12
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
what is this ign unfused port? does it say that on the fuse block? so i just drop HEI in run wire from there to the HEI and im done? what can i do to the HEI to make it better? the one i have is just stock as far as i know.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline
Old 09-23-2004, 09:51 PM   #13
Longhorn Man
Stock is fine. higher output coils do little tro nothing in stock or stock-ish engines. (dynos don't lie)
Ignition unfused is a terminal in the fuse box, if the print is still readable, then it'll say it...if not, I can post a pic of it when the attachments are up and working.
Old 01-28-2005, 05:09 PM   #14
franko72
Franko72
franko72's Avatar
what about the fact. tach hook up?Do you hook it the the neg, side of the coil?
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline
Old 01-28-2005, 06:33 PM   #15
krue
Designated A-hole!
krue's Avatar
My HEI cap has a spade for the tach hookup. It's right beside the hot wire for the coil.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline
Old 01-29-2005, 11:53 AM   #16
franko72
Franko72
franko72's Avatar
sounds like an easy swap.The truck wont have any more performance power will it? It just gets rid of those problem points ,right?
My Home Page
franko72 is offline
Old 01-29-2005, 09:09 PM   #17
marvxyz
hei swap
I have a 80 GMC and it has no points. I am wondering if I have a HEI distributer system.
marvxyz Pittsburgh Pa.
marvxyz is offline
Old 01-30-2005, 12:22 AM   #18
krue
Designated A-hole!
krue's Avatar
Yeah, your 80 should have had HEI. They quit putting points on them in the early 70's.
www.daveramsey.com
krue is offline
Old 02-07-2005, 02:26 AM   #19
1STtimePRo'71
1STtimePRo'71's Avatar
I have a 71 k20. Do I have HEI. How can I tell? I'm having starting problems, and I dont understand why. When did they start using HEI factory.
1STtimePRo'71 is offline
Old 02-07-2005, 02:27 AM   #20
67ChevyC10Stepside
hei is real big and has coil in the cap.....points is just big enough for all the plug wires..
Old 02-07-2005, 03:35 AM   #21
krue
Designated A-hole!
krue's Avatar
Here are some pics I got from Ebay.
First is points type dizzy.
Second is HEI
www.daveramsey.com
krue is offline
Old 03-17-2005, 01:45 AM   #22
ryanroo
ryanroo's Avatar
What size inline fuse should you use for the wire from the firewall? thanks
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 03-17-2005, 02:14 AM   #23
1974gmc
In Progress
1974gmc's Avatar
can anyone post where the unfused terminal would be on a '74, i cant read a thing off my fuse block
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline
Old 04-17-2005, 05:00 PM   #24
1978steven
1978steven's Avatar
Ryan
I would also like to know what size inline fuse to run to the H.E.I.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline
Old 05-02-2005, 10:20 AM   #25
jtminton
II Timothy 4:2
jtminton's Avatar
Me too. I just picked up a HEI and am eager to get it hooked up.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline
