Old 06-24-2017, 12:16 AM   #26
Robznob11
Robznob11's Avatar
Re: Drag racing
Originally Posted by Marine-58 View Post
this is probably a dumb question but exactly what do you mean by surge? just making sure I'm following you. Also if it is a holley650, on the front of the air horn will be a 4 digit number. it will be something like 4150, 4160, something like that. Do you have the site windows on the side of the bowls? mis-adjusted float level can cause various issues.
Others are also on the right track with the fuel line size, etc... Do you know if the acc pump has been changed out for a bigger diaphram?
Bad accelerator pump will caus this...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-24-2017, 12:19 AM   #27
Hayden Buck
Re: Drag racing
Yea it could be. I'll check that to. Do u or anyone know a racing mechanic in Ok?
Hayden Buck is offline   Reply With Quote
Old 06-24-2017, 07:18 AM   #28
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Drag racing
^^^^^ ding, ding ,ding! Winner
Tom Vogel is offline   Reply With Quote
Old 06-24-2017, 07:45 AM   #29
Grumpy old man
Grumpy old man's Avatar
Re: Drag racing
Post up a few pictures of your "race truck" I would think you might be better off learning more about the mechanics and what works and what doesn't before you start drag racing anything ! It's a LOT more than just buying a friends "race truck " and having someone "race tune it " jumping in the drivers seat and stomping on the pedal of a machine you know nothing about . It's a disaster waiting to happen and if your lucky the only thing you'll break will be truck parts and not body parts !
Brakes ?
Suspension ?
Tires ?
safety equipment ?
NEVER RUN RUBBER FUEL LINES . pushing more fuel is usually the cause of an off the line stumble rather than the cure , We all like to have fun , Don't let it kill you !
What year and model truck ?
Old 06-24-2017, 08:08 AM   #30
Hayden Buck
Re: Drag racing
It's a 84 chevy long box c10. With disc and drum brakes. 1/2 ton suspension. I have a pair of ps5860 sport drag tires on it. And I don't have safety equipment besides the seat belts that came with the truck.
Old 06-24-2017, 08:11 AM   #31
Hayden Buck
Re: Drag racing
And I almost completely built the truck from the ground up.
Old 06-24-2017, 10:03 AM   #32
Mollzyie
Mollzyie's Avatar
Re: Drag racing
Last time I saw that happen it was a blown engine ... I think yer in deep doo doo .
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 06-24-2017, 10:20 AM   #33
Hayden Buck
Re: Drag racing
Ok. It is has completely rebuilt 355 in it
Old 06-24-2017, 10:42 AM   #34
Grumpy old man
Re: Drag racing
ok you have a stock 5000 lb 86 with a 355 and sticky back tires and the aerodynamics of a brick , what trans ? have you gone thru the driveline and rear diff/axles yet ? because if you do get it to run right and actually hook up your going to leave lots of little parts at the line starting with the driveshaft / universals . I'm guessing at maybe 16:00 seconds in the quarter ? that's pretty close to what my stock 95 Z-71 would do .It takes a lot of modifications to get these old trucks race ready, lots of guys have done it but it's not cheap or easy .
Old 06-24-2017, 11:17 AM   #35
Hayden Buck
Re: Drag racing
I run a quarter in 10 seconds. It has a thr400 trans. I have gone thru the drive line and it is in good condition. I have camel hump heads. And a racing distrupter.
Old 06-24-2017, 11:30 AM   #36
Grumpy old man
Re: Drag racing
I wish you the best .... 10's
Turbo charged 10 second 83 c-10 shortbed
https://www.youtube.com/watch?v=taiaebEMWFs
https://www.youtube.com/watch?v=I7IEZuSe7tc
Old 06-24-2017, 11:49 AM   #37
geezer#99
geezer#99's Avatar
Re: Drag racing
In the 10's!!
Is that downhill??
A 10% grade maybe!
Do you Got pics of this wannabe drag truck?
Old 06-24-2017, 02:19 PM   #38
Mollzyie
Mollzyie's Avatar
Re: Drag racing
Had
M.A.G.A.
Old 06-24-2017, 02:21 PM   #39
Mollzyie
Mollzyie's Avatar
Re: Drag racing
M.A.G.A.
Old 06-24-2017, 02:47 PM   #40
davepl
davepl's Avatar
Re: Drag racing
Sometimes when you see hoofprints you gotta think horses, not zebras. Probably as simple as the timing is off or (most likely) the accelerator pump has failed or is out of adjustment.
But did I read that right? 355 with camel hump heads running 10s in one of our trucks? That's pretty amazing. Imagine if it didn't bog... maybe 9s?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-24-2017, 04:23 PM   #41
Hayden Buck
Re: Drag racing
Yes you did read it right. I only high school drag I can only do 85 in the 1/8 mile. My dad takes it and test runs it and in the quarter mile it hits around 120. It has no nitrous or super charger just a super fast 355 and a super quick get up and go.
Old 06-24-2017, 04:28 PM   #42
geezer#99
geezer#99's Avatar
Re: Drag racing
Dream on grasshopper, dream on!!!
Old 06-24-2017, 04:39 PM   #43
Hayden Buck
Re: Drag racing
Well the high school drag regulations says u can't run any faster than 8.20 so I stay safe by running less than that.
Old 06-24-2017, 04:41 PM   #44
davepl
davepl's Avatar
Re: Drag racing
Take about 580 horsepower to push a 4000 pound truck to 120 in the quarter.
How'd you get 580 horsepower out of a classic smallblock with old iron heads?
Old 06-24-2017, 04:58 PM   #45
Grumpy old man
Re: Drag racing
You add a 350 HP shot of NITROUS
Old 06-24-2017, 05:09 PM   #46
Hayden Buck
Re: Drag racing
I run it that fast by spending lots of time and money into it. I also have upgraded the power by reducing weight by taking old heavy stuff out and putting lighter equip in it.
Old 06-24-2017, 05:22 PM   #47
geezer#99
geezer#99's Avatar
Re: Drag racing
Where's the pics????
Old 06-24-2017, 05:25 PM   #48
Grumpy old man
Re: Drag racing
Your in High school and I'm sure your having fun with it so don't pay any mind to us old guys ! we're just ribbing you a little for fun . As long as your happy with it that's all that matters . there are a lot of guys in here that can give you more information than you'll ever want about these old trucks so make use of it . Some of us grew up driving these 67-72 trucks when they were brand new . My son was born before your truck was built .
Old 06-24-2017, 05:29 PM   #49
trac209
Re: Drag racing
Ok guys this is obviously a joke,built from ground up and can't tune it??? Sorry but this thread is no win situation. Runs 10s lmao.
trac209 is offline   Reply With Quote
Old 06-24-2017, 05:44 PM   #50
Grumpy old man
Re: Drag racing
You mean we've been CATFISHED ? (is that the right phrase ?) Nah , I think we've been high schooled
