Old 08-10-2017, 04:05 AM   #1
71C10Guy
71 c10 ac questions
So I have been in the process of completely redoing the ac on my 71 C10, and I have a few questions. The first, which I am working on right now, is what the hell is this thing?? It seems to be a low pressure switch? I'm not sure but I haven't replaced it because I don't know what it is or does, and needed some help. Also, I have been trying to blow through the system with air and it is getting blocked somewhere by the evap, I'm thinking that that switch, or the valve in the second picture is closed and not letting anything through. Any help would be appreciated. Thank you.
1st Pic
2nd Pic
3rd Pic
71C10Guy is offline   Reply With Quote
Old 08-10-2017, 06:03 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: 71 c10 ac questions
I can't see your pictures. If I could I would help.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-10-2017, 12:35 PM   #3
71C10Guy
One other question, where is the expansion valve / orifice tube located on the stock ac setup for a 4 seasons AC? Thanks!
And I will try to get those pictures up, I linked them to imigur, so maybe that's not right?
Old 08-10-2017, 02:15 PM   #4
demian5
demian5's Avatar
Just download the manual like I did and it answers all of your questions.
http://67-72chevytrucks.com/vboard/s....php?p=5781194
http://www.mediafire.com/download/?40ne0nab4bgyqyf
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-10-2017, 03:47 PM   #5
71C10Guy
Thanks you so much, this is an amazing amount of information and I'm go8jg to bookmark this page until I die haha. Yes, it did help me, the big cylinder is the pressure control valve and the other is the expansion valve / orifice.
One other thing though, and keep in mind I did this with the old expansion valve and the same pressure regulator valve, I blew air through the evaporator core, and it seemed to be blocked. I'm not sure if the expansion valve or the pressure regulator might be blocked or have a valve that is blocking the air, or if my evap is just junked. Thanks!
Old 08-14-2017, 03:26 PM   #6
71C10Guy
Alright guys, well after replacing everything (almost) and running both vacuum and pressure tests, I have concluded that my system still sucks. First off was a leaky valve, which I replaced, and not the condenser core has a giant hole in the side, so I'm going to have to get a new one. It would be a lot better if the one I got from Vintage Air actually fit tho haha.
Old 08-15-2017, 06:58 AM   #7
engineer_gregh
engineer_gregh's Avatar
Here is the post I did when I rebuilt my A/C. I hope it helps you out.
http://67-72chevytrucks.com/vboard/s...al+mass&page=2
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
a/c, air conditioning, rebuild
