Closed Thread
Old 08-19-2017, 08:14 AM   #5701
BugzC10
BugzC10's Avatar
Re: What did you do to your truck today? Chapter II
Good morning. I believe those are tail gate trunions.
Yep...I didn't see the depth of roller. I don't have that type on my year.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 08-19-2017, 06:09 PM   #5702
Orange67
Orange67's Avatar
Replaced both rubber fuel lines on my 67 chasing a vapor lock issue. The one from the frame to the pump I know had been replaced when I did the pump. The one from the tank to the frame... Original 1967, complete with undercoating and spring type fasteners. Here's to hoping...
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline
Old 08-19-2017, 06:35 PM   #5703
RodnRudy
RodnRudy's Avatar
I replaced the tail/stop lamps in my 68. They were some a friend gave me, LED style, Chinese made. I got home from the local cruise in at about dusk last night and decided to walk around the truck to check the tail lights before putting it in the garage. And to my surprise I had no tail lights! I knew I had power back there as I had a license light. So this morning I pulled out two new 1157s and we're back in business. The LED lamps had come loose in the sockets. Both of 'em, go figure.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 08-19-2017, 09:30 PM   #5704
Big Block
Big Block
Big Block's Avatar
Installed courtesy lights. Simple up grade that makes a huge improvement to lighting in your cab. Thanks to Board member Roger Koop. Check out his wiring harness on the parts board.
Big Block is offline
Old 08-19-2017, 10:29 PM   #5705
74baggedbug
http://67-72chevytrucks.com/vboard/a...1&d=1503196081
My new functional air cleaner.. wanted something a bit different
74baggedbug is offline
Old 08-19-2017, 11:12 PM   #5706
Big Block
Big Block
Big Block's Avatar
Oh it's different alright. If you like it that's all that matters. I'd say you have a conversation starter there. It's a Texas thing.
Old 08-20-2017, 07:31 PM   #5707
66clow
66clow's Avatar
Originally Posted by BugzC10 View Post
Ok...I give up, what are they?
You weren't alone lol
66clow is offline
Old 08-20-2017, 08:01 PM   #5708
Greg58
Greg58's Avatar
Is that a Stetson air cleaner??
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline
Old 08-21-2017, 07:19 AM   #5709
74baggedbug
Yea they are trunions, trying to get rid or a rattle on the tailgate, also these are make out of stainless steel and have a bushing
Old 08-21-2017, 09:30 AM   #5710
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Put a 211 LED bulb ( in your under dash lights too ) in your interior dome light and it'll be like daylight when you open a door at night.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 08-21-2017, 10:42 AM   #5711
Big Block
Big Block
Big Block's Avatar
Thanks for the tip.
Old 08-21-2017, 12:25 PM   #5712
gmc4x4can
gmc4x4can's Avatar
added a 1 inch spacer under my carb chasing a hot start issue, installed a daytime running light kit, and installed jute padding on my firewall. What a job that last one is, I should have done that first instead of last.
gmc4x4can is offline
Old 08-21-2017, 01:40 PM   #5713
Big Block
Big Block
Big Block's Avatar
Where did you order the jute padding for your firewall? Did you get pre cut? If you did how well did it fit? Thanks
Old 08-21-2017, 06:30 PM   #5714
Orange67
Orange67's Avatar
Think I fixed the vapor lock issue, so I gave her a much needed bath.
Justin
Orange67 is offline
Old 08-21-2017, 08:25 PM   #5715
Boog
laying low
Boog's Avatar
flip.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 08-21-2017, 09:30 PM   #5716
Orange67
Orange67's Avatar
Thanks Boog!
Justin
Orange67 is offline
Old 08-21-2017, 09:52 PM   #5717
gmc4x4can
gmc4x4can's Avatar
error please delete
Old 08-21-2017, 09:54 PM   #5718
gmc4x4can
gmc4x4can's Avatar
Got them from repops. Got the left firewall, center, and righ side firewall, they all fit extremely well, only had to tear apart half the dash to get them installed. Hardest part though was inserting the plastic plugs into the firewall holes. All precut.
Old 08-22-2017, 08:03 AM   #5719
Big Block
Big Block
Big Block's Avatar
Thanks for the information. Getting ready for this project.
Old 08-22-2017, 11:57 AM   #5720
NoStopN
NoStopN's Avatar
When I got my truck, the tail lights worked intermittently. Figured out the bulbs were wiggling in the sockets. But since my truck doesn't have a bed, I used a set of sealed LED lights from a parts store.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 08-25-2017, 03:46 PM   #5721
Already Gone
I'm a day late but it shouldn't matter. 2 days ago I installed the Classic Gauge and Cluster (Member TBONE1964) voltage gauge replacing the original ammeter gauge. Yesterday I swapped out the original 7/8 inch front sway with its tired bushings for a 1 /1/4 bar from a 1985 C30 truck and Energy Suspensions Polyurethane bushing. I should have taken before and aft pics of the sway bars but forgot.
Old 08-25-2017, 03:56 PM   #5722
OregonNed
OregonNed's Avatar
It's a great kit! Did mine too
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 08-25-2017, 03:58 PM   #5723
OregonNed
OregonNed's Avatar
This morning I changed my trans filter and pan gasket to fix some leakage
Old 08-26-2017, 03:06 PM   #5724
66clow
66clow's Avatar
Picked up some honda civic door opening sills.$20 They are the perfect length. Will paint the gray area to match the interior i go with. Couldn't find black. Also saw what was left of this probably 68 in the yard.
66clow is offline
Old 08-26-2017, 04:49 PM   #5725
Boog
laying low
Boog's Avatar
turnd
Boog
primer is finer
Boog is offline
Closed Thread
