Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-04-2017, 06:47 PM   #1
YOLO
Custom Truck Lover!
YOLO's Avatar
1969 three door with a Cummins. Project "Big Burb"
#12 is an update as of 12/22/17
I am writing a tech article for Street Trucks Magazine on a swap Big 10 Garage just finished. The donor is a 1992 2wd Dodge 250 with a Ve Pump 6bt engine and a518 automatic transmission. Look for the article soon. Next up is the suspension, then interior. We are already driving this beast and put 170 miles on it in the first 5 days.
Squarebody guy
YOLO is offline   Reply With Quote
Old 09-04-2017, 07:05 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 1969 three door with a Cummins. Project "Big Burb"
Thats big holes thru that burb.....
Old 09-04-2017, 09:22 PM   #3
YOLO
Custom Truck Lover!
YOLO's Avatar
I like big holes!
It was reinforced with 5 inch pipe. 4 inch exhaust
Squarebody guy
Old 09-05-2017, 02:38 PM   #4
nastety92
Truck looks badass from the rendering. Are those Detroit Steel wheels? 20/22"?
Looking forward to seeing this built through.
Nick
nastety92 is offline   Reply With Quote
Old 09-05-2017, 04:01 PM   #5
YOLO
Custom Truck Lover!
YOLO's Avatar
Nick
Yes they are DSW 20x8 with 4.75 backspace all the way around. The next tech article will be on suspension. Unsure if I will be doing bags or coilovers.
Squarebody guy
Old 09-09-2017, 08:31 PM   #6
goldenburb
goldenburb's Avatar
Cool....but I got a few Qs.. When I started my Cummins 4x4 build I read the weight was around 1000 pds and I had to upgrade to D60..
So how is bags going to work? and where will you get the motor mounts
. I really hope you finish your burb and share alot info..
I have 20" dsw those B's are heave.lol
Good luck love the rendering.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 09-09-2017, 08:53 PM   #7
goldenburb
goldenburb's Avatar
P.S good luck on 9-20-17
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 09-10-2017, 05:20 PM   #8
YOLO
Custom Truck Lover!
YOLO's Avatar
Thank you. Text me and I'll give you more info. I wrote the tech for Street Trucks magazine and don't want to write too much here until the article comes out. Mark 6234510221
Squarebody guy
Old 09-25-2017, 09:36 AM   #9
Hart_Rod
Hart_Rod's Avatar
Should be a fun build.
Hart_Rod is offline   Reply With Quote
Old 09-25-2017, 10:05 PM   #10
YOLO
Custom Truck Lover!
YOLO's Avatar
The tech article is complete for Street Trucks and C10 Builder's Guide. Once the magazine comes out I will post more pictures here.
Next up is suspension. I will do a 4/6 static drop with air bags in the rear for towing.
Squarebody guy
Old 12-13-2017, 06:47 PM   #11
YOLO
Custom Truck Lover!
YOLO's Avatar
I hope you have had time to pick up the newest issue of C10 Builder's Guide. I believe my tech starts on page 68. Next issue will be complete suspension with disc brakes and tow bags.
Squarebody guy
Old 12-23-2017, 12:03 AM   #12
YOLO
Custom Truck Lover!
YOLO's Avatar
Old 12-23-2017, 12:08 AM   #13
YOLO
Custom Truck Lover!
YOLO's Avatar
Squarebody guy
Old 12-23-2017, 12:08 AM   #14
YOLO
Custom Truck Lover!
YOLO's Avatar
Squarebody guy
Old 12-23-2017, 12:10 AM   #15
YOLO
Custom Truck Lover!
YOLO's Avatar
All suspension and brake parts are from Performance Online. The install took 3 days. Included everything in the pictures. Next up is new gears and axels, wheels and tires.
Squarebody guy
Old 12-23-2017, 10:13 PM   #16
goldenburb
goldenburb's Avatar
Read your article well in Santiago Chile airport.found some good info but leaves me with Q's lol
I'm looking forward too seeing more soon. Good luck.
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 12-24-2017, 11:11 PM   #17
YOLO
Custom Truck Lover!
YOLO's Avatar
I would be more than happy to answer any questions. Leave those questions here or email me Mark@MarkBarbee.com
Squarebody guy
Old 12-30-2017, 11:48 PM   #18
ChuckLee
What you have to say about that air suspension setup?
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 01-08-2018, 09:20 PM   #19
nuke1
nuke1's Avatar
Looks really great that rendering. Love the diesel idea bor the burb
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-16-2018, 11:04 AM   #20
YOLO
Custom Truck Lover!
YOLO's Avatar
Im confused. You read the article and have questions about the "air suspension setup?" There is nothing mentioned about air suspension. There are NO plans to bag this Suburban. It is a static drop with tow bags on the rear.
Squarebody guy
Old 01-16-2018, 11:05 AM   #21
YOLO
Custom Truck Lover!
YOLO's Avatar
Thank you. It is a blast to drive and gets plenty of looks when the diesel roars!
Squarebody guy
Old 01-16-2018, 01:36 PM   #22
ChuckLee
i may be confused then. a couple posts above my question is a picture of a compressor, an air tank, and bags, an Airmaxx kit. I didn't realize you were solely using the bags for towing. makes sense now
Old 01-16-2018, 08:26 PM   #23
YOLO
Custom Truck Lover!
YOLO's Avatar
Im getting older. I like the bagged look but like the dependability of a static drop.
Squarebody guy
Old 03-26-2018, 08:48 AM   #24
goldenburb
goldenburb's Avatar
Sooooo is this build on the 10 yr. Plan? Lol ����
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 04-04-2018, 10:24 AM   #25
Hart_Rod
Hart_Rod's Avatar
If it is, it's way more aggressive than mine was.....
dakota digital, diesel swap, engine compartment pics, mpg, towing
