Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-12-2017, 11:47 AM   #176
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1972 Medium Blue Highlander Blazer Resto
Originally Posted by Andrew S View Post
You mention a "sending unit wire clip" a few posts back, did the Blazers have a parking brake sensor, or is that clip for the hydraulic brake light switch wiring? Great build, thanks for documenting so thoroughly!
Andrew
I'm going off my rusty memory at the moment and will double check but seem to recall the clip served the wire for the brake dummy light running to the prop/metering valve at the MC.
You bet!
Old 09-24-2017, 06:52 PM   #177
toolboxchev
YES!
Bring her back!
toolboxchev is offline   Reply With Quote
Old 09-25-2017, 01:47 AM   #178
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Love the detailed pics. Thanks for taking the time to post. Being as detailed as you are, I know that takes a lot time and effort.
This is going to be a great build and reference! Keep it up!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 09-25-2017, 09:50 PM   #179
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys! I enjoy documenting the little details - wish I could do more.
Tub is back on the frame. I'll get some pics up soon of that. Struggling with configuration of the OEM gas tank neck on the repro tank. I regret using a repro tank. The repro tank had a neck that was welded not soldered in place and therefore couldn't be sweated off like OEM for a direct neck swap. So it's solder, test, solder test.
Meanwhile I soaked my parking brake control in Evaporust - I like the result! I'll repaint and apply Boeing T9 spray. Thanks John!
Old 09-25-2017, 09:51 PM   #180
DeadheadNM
Carpe manana
DeadheadNM's Avatar
After....
Old 09-25-2017, 11:17 PM   #181
72K5CSTDarkOlive
I bought a repo tank from Brothers and swapped the neck from an original. Took it to a radiator shop to do the neck swap and configuration seems to be spot on like the original. fits nicely over the frame.
I couldn't tell you if the repo tanks neck I bought was welded or soldered.
What's the issue with the configuration?
Old 09-26-2017, 10:11 PM   #182
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I did the same - both tanks to a radiator shop. Have returned twice since. The gal that does the work is really nice but I think her patience is wearing thin. It's been the height of the neck: too low x2 now too high. It'll work its way out.
Old 09-27-2017, 10:06 AM   #183
rayray767
Maybe you need to babysit ��
rayray767 is offline   Reply With Quote
Old 09-27-2017, 06:00 PM   #184
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Pete, nice work. Where can you get the Boeing T9 spray? I'm guessing no where but then maybe my search missed it.
Ryan
1969 Chevy milk truck
Old 09-27-2017, 10:05 PM   #185
CJM72
The product name is Boeshield T-9. You can order it on Amazon and lots of other places. Woodworking shops usually have it in stock as well. Works well to prevent rust on cast iron machine surfaces. https://www.amazon.com/s/?ie=UTF8&ke...SAAEgIpGPD_BwE
CJM72 is offline   Reply With Quote
Old 09-27-2017, 10:09 PM   #186
Dieselwrencher
Thanks. I saw that on my search but wasn't sure if that was the same stuff.
Ryan
Old 10-02-2017, 10:05 PM   #187
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks the evaporust worked well. Seems like other members have had good success with vinegar baths as well. Yep, Boeshield.
Old 10-02-2017, 10:07 PM   #188
DeadheadNM
Carpe manana
DeadheadNM's Avatar
This NOS power brake booster set up fell into my lap. Initially I intended to do a 3/4t booster swap. Oh well, on it goes.
Old 10-03-2017, 07:34 AM   #189
IronCanine
I'm trying....
IronCanine's Avatar
Wowzers...what a score. I thought I was jealous before. That is incredible.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 10-05-2017, 07:27 AM   #190
72ironmike
72ironmike's Avatar
Pete, Finally subscribed. Got tired of searches each time for updates. Cant wait to see this finished !
72ironmike is offline   Reply With Quote
Old 10-07-2017, 04:21 PM   #191
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys! I'm chipping away in the garage today. Momma at work so doing what I can w baby. We are almost done rebuilding the fender to cab dust shields. I was surprised to see part #s on the small pieces. My staple gun wouldn't power the staples through the metal brace but these were easily placed through the existing holes. One down one to go.
Old 10-07-2017, 04:22 PM   #192
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old 10-07-2017, 04:25 PM   #193
DeadheadNM
Carpe manana
DeadheadNM's Avatar
One more ...
Old 10-07-2017, 04:38 PM   #194
DeadheadNM
Carpe manana
DeadheadNM's Avatar
In working with the baby in the garage I was reminded of the safety film we watched in middle school shop class "Shake Hands With Danger". So, I thought I'd try a you tube search and low and behold there it was. Never mind it was produced by Caterpillar tractor. At time 2:17 there's a vignette with what looks to be a 67 3/4T Chevy Custom Camper. Keep it safe!
Old 10-07-2017, 07:18 PM   #195
IronCanine
I'm trying....
IronCanine's Avatar
Pete...that song is legit. I'm putting that thing on the office mix first thing Monday morning.
PS...it's been my experience that a baby that smells like PB Blaster was smarter and way more loved than your run of the mill Johnson & Johnson brat. Strong parenting.
Old 10-25-2017, 11:03 PM   #196
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not much new to report. I opted to have my power steering pump rebuilt. Number checks out as correct for original application. Marty at powersteering.com did a good job. We'll see if it functions as good as it looks.
Old 10-25-2017, 11:03 PM   #197
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old 10-26-2017, 03:30 AM   #198
72K5CSTDarkOlive
Looking great Pete. Wish I knew about these guys before I traded mine in for a refurbished one at the local auto store. I did manage to get the same style pump that I traded in for which has the slim neck like you have there.
Old 10-27-2017, 12:02 AM   #199
Dieselwrencher
Nice work Pete! I remember my dust shields were all tore up and it took me a bit to get the pieces laid out before I wanted to staple them. Haha
Ryan
Old 10-29-2017, 11:25 PM   #200
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Mike and Ryan. I was afraid I'd have a hard time locating a rebuilt pump locally and spend a lot of time trying so thought I'd try a rebuild. Soon I plan to ship the AC compressor for a rebuild.
Anyone know what the current scoop is on reproduction power steering pressure hoses for 4wd? Frank Hamm isn't producing these. I'm tempted to have the rubber replaced on the pressure line but not sure if there's a local company doing this work here anymore.
I spent part of today sorting the engine brackets for the alternator, AC compressor, power steering pump, and the AIR pump and matching up the respective replated hardware. I'll bolt these onto the motor later in the week. I found a NOS example of the 72-only alternator bracket.
