Opinions on best brake flaring tool and bender
In the market for a flaring tool and brake bender . Recommendations welcome !
68 c10- Under construction |
![]() Join Date: Nov 2013
Re: Opinions on best brake flaring tool and bender
I got this one and added the 37º JIC turret as well...there are more expensive ones but this one has worked very well for me....
http://www.eastwood.com/professional...ring-tool.html
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
![]() Join Date: Jul 2012
Ive been pleased with the flaring tool from Mastercool. A bit pricey and worth it to me. https://www.amazon.com/Mastercool-71...l+flaring+tool
The one from mastercool is the best. Hands down. I use mine all the time.
I use the Eastwood one too and have never had a bad flare. As for benders, buy one dedicated for the size you're bending, don't buy the 3 in 1 benders because they only bend one radius based on the largest tubing it will bend. Most of my benders are Imperial but my 3/16 bender is a Rigid.
![]() ![]() Join Date: Oct 2014
I have a Rigid flare tool and it worked/works well. https://www.ridgid.com/us/en/precisi...ing-flare-tool
#7 | |
Brake lines requre a double wall flare. |
I have the Mastercool tool also, like it a lot, use it all the time. It creates an excellent, professional flare every time. With that said, the Eastwood tool looks a little easier / quicker to use. With it clamped in a vice you have both your hands free. It seems like I need three hands to get everything lined up well with the Master cool. Also, I think you have better feel/control with the lever on the Eastwood (if that matters).
One plus for the Mastercool, you can flare on the vehicle if room allows, done that more than a few times. I think I'll buy the Eastwood tool someday, can't have too many tools! |
That's correct about the flares. I should have added that I used a collar behind the flare and in front of the tube nut. My apologies.
#10 | |
The Mastercool kit is awesome and its strongest suit is that you can use it anywhere on the car rather than having to remove a line and carry it to the vice to connect an existing line to a new line. It also forms many quick connect fuel lines,etc. The only down side to it is that the clamping pieces have a heavy knurl,and will leave some of that showing behind the tube nut. It is a non-issue for normal shop repairs,but might not look as nice on a custom/show vehicle. I like the Eastman type tool the best. It is fast and makes nice looking flares without the knurl where it clamps the line. I especially like that when using the softer copper/nickel line we use in the rust belt. The Eastman tool wasn't around when I bought my flaring tool,but I have one very similar. It came from Fed Hill Trading Company. https://cunifer.com/hikashop-menu-fo...-flaring-tools For those unfamiliar,Cunifer is the trade name of the original UK sourced copper-nickel brake line. It gets its name from copper (Cu),nickel (ni) and ferrous (fer). It is considerably more expensive then the Eastman,and kind of pricy to keep adding capability to as well. For the person doing their own repairs and restorations,I think the Eastman would make the best overall tool. |
I ended up with the eastwood products and couldn't be happier. This is my first time making a complete set of brake lines for a truck and it was not bad at all. Here are the links to the tools I used.
I highly recommend these 3 tools https://www.eastwood.com/professiona...ring-tool.html https://www.eastwood.com/eastwood-ha...ighteners.html https://www.eastwood.com/tubing-bender-rolling.html This is the only tool I ordered that I am not a fan of atleast with Nickel copper lines https://www.eastwood.com/tubing-bend...liers-kit.html
Ridgid all the way...
#13 | |
I thought you had to have double flares as well, but my TCI chassis came plumbed with 3/16” SS tube and when I made a few changes I had to buy a 37 degree single flare tool that could handle SS tube - I got the Rigid and it worked great.
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#14 | |
Are the single wall 37 degree flares legal for road use? Or just off road/racing applications? |
#15 | |
The reason for single flare versus double flare is due to the type of tube and how it is manufactured. A standard steel brake line starts out as a flat piece of steel. It is rolled into a tube and electro-welded (brazed?) and then finished smooth on the outside,but there is still a seam on the inside. The double flaring process allows the smooth outside of the tube to be folded over and become the sealing surface of the flare. A single flare would cause a leak where the seam is. The stainless steel tube is seamless tubing,and does not require the double flare. It does require a tube sleeve and a tube nut for the connection. You are correct-the other link was for 45º single flares. That should not be used for brake lines. Rigid makes both,but I don't know of any automotive use for single 45º flares. |
#16 | |
I appreciate the info. Compression fittings are not legal in pa. |
#17 |
![]() Join Date: Jul 2006
I bought this kit, DO NOT RECOMMEND. It distorts on tightening, the knurling no longer holds the tubing and it is generally clunky and troublesome. Go hydraulic if you budget allows.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#18 | |
so I bought the tube....went out to my truck....came back in and bought the compression fittings....silly? yes but that was Napa's rule.... Normally I would never do this anyway....but that truck was never on the road...I didn't even have tags and insurance on it. When I bought my current K/5...someone had jury rigged the rear brake lines and there was a compression fitting on the main tube above the axle....it was leaking so I bought some tubing and some of the coli spring shield material and made all new lines....along with a new line going all the way up front to the first connection....that's when I bought the Eastwood tool and made the tube straightener...
#19 | |
![]() Join Date: Jun 2012
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#20 |
You need to use 37 degree single flares on SS - there is a version of the same Rigid tool for those and it worked great for me on my SS lines.
