Old 09-27-2017, 07:14 PM   #1976
oldman3
oldman3's Avatar
Re: Kabwe's aka Bam's build
Bam, great update and info, I'm like the rest, can't wait for more...Jim
oldman3 is offline   Reply With Quote
Old 09-28-2017, 11:51 AM   #1977
BAM55
BAM55's Avatar
First of all I want to thank everyone for the comments and encouragement. Its greatly appreciated. I'm really excited at this point of the build (putting it back together) its really going to be nice to start this engine with it between the frame rails. I got home yesterday and the exhaust kit was on the front porch. I need a couple of other things but I'm looking and thinking about the exhaust.
Originally Posted by ptc View Post
Looks real good Bam - bet you are getting jazzed about getting it going each day it gets closer....
Are you going to sound deaden the inside of the doors? same materials too? im trying to figure mine out now and if it helps or not.
keep it up!
Ptc, it does make a difference, and yes I'm going to use the same material inside the door. You don't have to cover the entire inside of the door, just a nice piece will be good. You also don't have to cover the whole floor but people do because its easy to do. Its a why not thing.lol
BAM55 is offline   Reply With Quote
Old 09-28-2017, 03:12 PM   #1978
JML55
JML55's Avatar
Looking good , looking forward to watch the assembly process and the complete truck.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 10-16-2017, 01:08 PM   #1979
BAM55
BAM55's Avatar
I started working on the exhaust. I got it about half way done. I stopped at where I will be connection the second half of the exhaust with marman v-band flanges.
Any way these are the components I used.
2010 Camaro Shorty Headers
2010 Camaro Flanges
Jegs universal 2 ½ exhaust kit
Jegs 2 ½ H-pipe kit
Oxygen Sensors Bungs
Marman V-band flanges will tie the front and rear sections together
Here are some pics on the install so far.
Tack together for a test fit to the h-pipe
Completely welded and Marman v-band flanges installed. This is the front section it stops at the back of the cab.
Installed in the truck.
Old 10-16-2017, 02:31 PM   #1980
youngrodder
youngrodder's Avatar
Nice....Are those exhaust kits pretty easy to work with? I was considering the same myself.
Looks good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-16-2017, 02:34 PM   #1981
BAM55
BAM55's Avatar
Looks good.
Marc
Yeah they give you all the bends you would need. One end of every pipe is expanded so that you can do lap joints. This helps a lot during mock up, you simply slide them into each other to check fitmet before welding. .
Old 10-16-2017, 05:20 PM   #1982
solidaxel
solidaxel's Avatar
Now that you have bought all of your V band clamps, take a look at AceRace v bands
Super simple and not bad on the price
What oil pan did you use that is lower than the trans bell housing?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-16-2017, 08:33 PM   #1983
Kim57
Kim57's Avatar
Very nice work Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-16-2017, 08:48 PM   #1984
BAM55
BAM55's Avatar
Thanks guys
I like the v bands I used because they are not prone to leaking like the ones with just the flange. The v-band kit I used are 24.00 bucks a piece. I only need two. I'm sure the AceRace ones are nice also.
The oil pan is from a 1999 Camaro. I got it on ebay years ago. When you change the oil pan you will need the Camaro windage tray and dipstick. Those items I got from GM Direct.
Old 10-28-2017, 07:51 PM   #1985
Az. Hank
Az. Hank's Avatar
Very nice! Are the pipes stainless? Sure looks like it.
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 10-30-2017, 03:10 PM   #1986
BAM55
BAM55's Avatar
Thanks man and no the pipe is the Aluminized Exhaust Kit from jegs.
Old 10-30-2017, 03:22 PM   #1987
bowt1ed
Hey BAM - sorry to hijack, but is there a significant difference between the aluminized steel and s/s (besides, of course, the cost and ability to Mig)?
Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 10-30-2017, 06:18 PM   #1988
BAM55
BAM55's Avatar
Thanks, Jim
Well Stainless Steel is more corrosion resistant than the aluminized steel. But I had aluminized under my car for about 10 years and it looks the same as the day I installed it. Being in Cali and building a truck I plan to drive as a fair weather vehicle I just don't see the need for stainless. I will paint the welded area and call it a day.lol Now if I were building a show car I would go stainless.
Old 10-30-2017, 06:58 PM   #1989
Indian113
Indian113's Avatar
Bam, I have the same exhaust on my S10 and I drive it All year around in Iowa. The pipes look as good today as they did 6 years ago.
Indian113 is offline   Reply With Quote
Old 10-31-2017, 08:24 AM   #1990
bowt1ed
Thanks, good to hear that. I don't plan on driving mine in foul weather and keeping in the garage, so likely spend the money elsewhere.
Cheers, Jim
Old 11-06-2017, 02:08 PM   #1991
BAM55
BAM55's Avatar
Completed the rear section of the exhaust. The mufflers are Dynomax race bullets.
Mocked up
To snake around the gas tank
Old 11-06-2017, 07:36 PM   #1992
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
More great work sir!
Ryan
1969 Chevy milk truck
Old 11-06-2017, 08:12 PM   #1993
oldman3
oldman3's Avatar
Looks great...Jim
Old 11-07-2017, 12:35 AM   #1994
iowaboynca
iowaboynca's Avatar
Bam...I know you hear it a lot but your attention to detail is top notch! You do beautiful work. I love how you keep the symmetry of your build together. Nicely done!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 11-07-2017, 04:59 AM   #1995
Nut Case
Nut Case's Avatar
Kabwe
Looking over the exhaust system I noticed that the H pipe appears to be lower that the through pipe. Any concern that condensation will collect there and cause some rust?
All else looks top notch, strong work
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 11-07-2017, 09:13 AM   #1996
Kim57
Kim57's Avatar
Very nice work Bam.
Kim
My build thread
Old 11-07-2017, 01:42 PM   #1997
BAM55
BAM55's Avatar
Thanks guys
Originally Posted by Nut Case View Post
Kabwe
Nut Case
Nope I'm not worried about condensation at all. Why? because all exhaust systems due to weather change and heat cycles of the engine will have some condensation in the pipes. Example, its cold weather and you start the engine and little spinkles of water start blowing through the tail pipe, we've all seen it. Car warms up and the water evaporates.
In my opinion its a non issue because by the time this exhaust rust I will most like not be driving anymore or among the living.LOL I serious doubt that it will be rusted through even than. I have had the same setup on my 55 Sedan for the past 10 years and exhaust looks like I did it yesterday.
Why did I do my H-pipe like that? To tuck it up as far as I can and miss the trans output shaft. The kit comes with two pipes, a straight one and the curved one for that reason. You have to use the curved pipe to avoid any obstruction.
Old 11-07-2017, 08:17 PM   #1998
Black_Sheep
Black_Sheep's Avatar
Nice work Bam! I used a similar builders kit from Summit, it took a lot of head scratching and test fitting to come up with a decent layout and I didn't have a panhard bar to contend with.
Black_Sheep is offline   Reply With Quote
Old 11-08-2017, 01:53 PM   #1999
_Ogre
_Ogre's Avatar
looks good bam
when we build a full on custom ss exhaust system we use the same method of straight pipe and fittings for building the exhaust
a lot of cutting and welding involve but it's really the only way to build custom mandrel bent
only the production exhaust systems are bent from a single stick
it takes quite a bit of prototyping to get the angles, rotation and lengths figured out
shop air compressor timer
Old 11-08-2017, 02:02 PM   #2000
joedoh
joedoh's Avatar
super nice work on the exhaust!
