05-02-2016, 05:10 PM | #26 |
Re: Marks Diesel 46 project
59 steering wheel is a classy pic but I like the last pic best.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
05-02-2016, 08:51 PM | #27 |
The little one is a cutie. We just spent a week in Hanover visiting with our youngest granddaughter.
The steering wheel is a good idea. |
10-09-2017, 11:44 AM | #28 |
OK I'm back at it after a long break. Had to do some major home remodeling and lots of family time with 5 grandchildren and one more next month. all 3 years and younger. I have some step by step pics to catch up to where I am now. Ill post in the next day or so.
46 Chevy Pickup (project) 60 Chevy Biscayne 93 Caprice wagon(Impala SS style) 99 Corvette convertible 2014 Silverado 2500HD 92 Chevy 1500 (Shop/plow truck) 02 Silverwing 05 H-D Springer Classic 2011 Civic (Wifes car) 03 Highlander (beater) 96 Honda Elite 80 |
10-09-2017, 01:25 PM | #29 |
wow I love the mercedes engine choice, nice work!
10-14-2017, 11:35 PM | #30 |
I bought an A/C kit. I was able to get some universal mounts for the compressor. Made a plate and bolted to the engine block and welded the mounts to it. Also mounted a gm alternator.
10-14-2017, 11:50 PM | #31 |
I was looking for an old looking steering column. Had a 59 Chevy column hanging in the attic of the garage. I had to shorten it 4 1/2 inches and bought new bearings horn switch and turn signal lever. I ground off the mount for shifter handle and filled the rest of the holes. Mounted it with exhaust clamps. I cant remember what the universal shaft came out of but I was able to make it work with a shat support bearing.
10-15-2017, 12:07 AM | #32 |
Pulled the cab back off. Made a crossmember for the rear shocks and made up the mount for the brake booster and master cylinder.
10-15-2017, 10:10 PM | #33 |
I can almost hear the clackity clack of that diesel! the overdrive will be nice too. I had an 81 300sd and it was a locomotive on the highway but turned a bit too much rpm for my liking.
hey did you know? you can build a lifting frame for your cherry picker and stick it through the windows, you can get a lot more height lifting from inside the cab.
10-17-2017, 02:07 AM | #34 |
Nice progress having ac will be nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
10-17-2017, 07:48 PM | #35 | |
10-17-2017, 08:02 PM | #36 |
The A/C is mostly for my wife but I'm sure I will enjoy it myself.
10-17-2017, 08:15 PM | #37 |
I Stripped the frame down and turned it over and finished all the welds. Next will be sandblast and paint as soon as I have time.
10-29-2017, 09:42 AM | #38 |
Decided to take a day off work, I needed a break. Got home Thursday and still had some daylight (unusual this time of year). I moved the frame outside to degrease and pressure wash to get ready to blast.
10-29-2017, 12:27 PM | #39 |
A great way to clean the frame. Sure beats a wire wheel while still in the shop.
10-29-2017, 04:19 PM | #40 |
Friday morning as soon as the sun came up and melted the frost away I started sandblasting. What a job. You don't realize how much surface area there is to a frame! It took me all day with a few breaks I was finishing up as the sun was going down and moved back in the garage. It sure was a good day for the job, warmed up to about 60, a nice breeze to blow away the dust, and lots of sunshine.
10-29-2017, 04:26 PM | #41 |
I got some epoxy primer and semi gloss urethane paint from summit racing. I don't paint cars every day but it seems like when I do all the products change.
10-29-2017, 04:42 PM | #42 |
Saturday, another beautiful fall Pennsylvania day. A little warmer than Friday, no frost and warmed up fast. I sprayed the primer on, waited about an hour or so and painted two coats of the semi-gloss black. Finished up and cleaned up just in time to be 20 minutes late for our grand daughters first birthday party!
10-29-2017, 08:41 PM | #43 |
Yea that would have taken days to wire wheel all the layers of stuff and get to bare metal!
10-30-2017, 10:16 AM | #44 |
Looks good
11-02-2017, 09:06 PM | #45 |
6>8 Plugless........
Your frame looks very nice! That has to help you seeing shiny stuff now!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-05-2017, 12:27 PM | #46 |
Thanks Dieselwrencher, I kinda feel like I turned a corner on the project but then I look at the piles of parts. I have a long way to go at the pace I work.
11-07-2017, 01:30 AM | #47 |
Slow and steady you will get there.
11-07-2017, 04:43 AM | #48 |
Diesel46
Fun project, Bam used two engine stands to create a frugal rotisserie, so you don't have to lay on the concrete to get underneath to spray. I made one works real well, so kudos to Bams invention. Keep on keepin on Nut Case
Been there, wrecked that |
11-23-2017, 06:52 PM | #49 |
A rotisserie would have made the frame painting go easier!
11-23-2017, 07:03 PM | #50 |
I may have found a seat for the old truck. I bought a rusty Ramcharger for $200 to part out and scrap. The back seat seem like a good fit. I won't know for sure until I put some of the truck back together. If it fits I will get it recovered to go with the rest of the truck.
