Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-03-2017, 11:26 PM   #451
lower50's
lower50's's Avatar
Re: "TANGERINE" (C20 to K10) (LWB to SWB) (CST/MOD) (5.3)
What brand is your sheer?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-04-2017, 01:57 AM   #452
fakerwade
fakerwade's Avatar
It's an Eastwood,,,throatless sheer. About $160
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 05-08-2017, 10:11 AM   #453
7dee2
7dee2's Avatar
New tools are just the best!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 05-10-2017, 07:57 AM   #454
68 TT
Still plays with trucks
68 TT's Avatar
Great progress Wade. Nice to see you have a place to work on it again.
Sorry I haven't been around much. Life has gotten in the way again.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-14-2017, 02:40 AM   #455
fakerwade
fakerwade's Avatar
I'm getting so many tools that I might have to do another build just to justify having so many!! But your right,, tools are cool!!
Hey Mike,, it's great to here from you! Believe me,, I understand about life getting in the way. Got a question for you,, I was thinking of putting three point (shoulder) seat belts in Tangerine,,, there is already a tapped hole in the B-pillar that seems like the right height. Do you think that hole is a strong enough anchor point for the seat belt? Do you have any suggestions for a three point belt,, it has to be black and retractable? I seen one for second gen camaro's that looks interesting,, but it sells for $179 (ouch!!) Any ideas?
Wade
Old 08-14-2017, 01:48 PM   #456
68 TT
68 TT's Avatar
Hi Wade, sorry I haven't been on here in quite a while. Too much work to do at work and not enough time for fun
That is the bolt hole the factory used for the shoulder belts. It is a fine thread shoulder bolt you need for that spot so they are a little hard to come by but they area out there. All the newer stuff used coarse threads.
I found that the second row shoulder belts out of an ~86-91 Suburban are a good match and won't take much work to make fit. The lower housing and mount bracket is level to the floor so there is plenty of material for a clean look and no odd shapes left over. The size is manageable and will fit in the space we have to work with.
Not sure if there were any Suburban seat belts that are black but I have used fabric & vinyl dye on seat belts before and is works well. A little rigid at first but they soften up after some use and the coating stays in place. Krylon Fusion paint for plastic works well on the housings.
Are you heading up here for Good Guys?
Old 08-15-2017, 12:16 AM   #457
fakerwade
fakerwade's Avatar
Thanks for the good info Mike! Yep,, I'm going to be at Goodguys 9 Sat. Did you want me to bring up those old doors and bedsides?
Wade
Old 09-01-2017, 10:56 PM   #458
thetucks
Hows it been going fakerwade? Got any updates? Hows the interior going?
thetucks is offline   Reply With Quote
Old 11-13-2017, 02:00 AM   #459
fakerwade
fakerwade's Avatar
Hey Guys,,, it's been a little while!! Progress is still going on,,, lost my camera so no new pics till I find it! We are heading in to winter and the shop is not very well insulated and the stove is pretty small,, so,,, it will probably be about three months before I get back to work her. I got a lot accomplished this year but I've also been very surprised how long a lot of the custom work is taking me. Having never really done this kind of work before,, it's hard to get the things in my brain to be actually created and functioning. Sometimes it's just trial and error over and over. But I'm still optimistic that the end is near.
Wade
Old 11-13-2017, 09:20 AM   #460
thetucks
Looking forward to the progress update
Old 11-14-2017, 07:09 PM   #461
lower50's
lower50's's Avatar
Good job Wade. Sometimes no mater who it is it takes forever. Keep it up.
1951 MG TD
Old 06-13-2018, 12:41 AM   #462
fakerwade
fakerwade's Avatar
Okay,, I'm back,, and I found my camera! So I spent a lot of time last year cleaning all the rust off the frame. I don't know why it had so much RUST!! The donor Yukon came from North Idaho,, where they do not salt the roads,, so,, beats me why so much rust. Anyway,, I also welded up a lot of the "tie down" holes in the frame too.
Wade
Old 06-13-2018, 12:46 AM   #463
fakerwade
fakerwade's Avatar
I also got rid of the factory fuel tank and installed a custom made beauty. The factory cross member in front of the tank wasn't going to cut it,, so I cut it out and built a new one.
Wade
Old 06-13-2018, 12:51 AM   #464
fakerwade
fakerwade's Avatar
I started to build the frame work for the bed but it looked like the tops of the shock mounts were just a little too tall and might interfere,, so I modified them with strength in mind.
Wade
Old 06-13-2018, 12:54 AM   #465
fakerwade
fakerwade's Avatar
So here is a picture with the bed frame work a little further along and some test fitting of the bedsides.
Wade
Old 06-13-2018, 01:52 AM   #466
fakerwade
fakerwade's Avatar
Here's a couple more pictures of the new cross member modification.
Wade
Old 06-13-2018, 07:26 AM   #467
Glad you found everything and are able to entertain us again.
Really nice work!
Old 01-04-2020, 01:35 AM   #468
fakerwade
fakerwade's Avatar
more updates, it wasn't the most productive year but progress was made. Got the fronnt of the frame rails finished.
Wade
Old 01-04-2020, 01:42 AM   #469
fakerwade
fakerwade's Avatar
Trying to use a new online photo storage,,, but it doesn't seem to be working. I think the photo's file size is too large. I'm trying to use Flickr,, just don't know how to re-size the photo's with that site.
Wade
Old 01-04-2020, 02:34 AM   #470
fakerwade
fakerwade's Avatar
Wade
Old 01-04-2020, 02:37 AM   #471
fakerwade
fakerwade's Avatar
Okay,, switched to photobucket,, we'll see how this works. Painted and Dyna matted the firewall.
Wade
Old 01-04-2020, 02:41 AM   #472
fakerwade
fakerwade's Avatar
Also got the engine rebuilt,, spent $5400. Has a lot of Texas Speed parts in it,,, should put out about 400hp.
Wade
Old 01-04-2020, 02:43 AM   #473
fakerwade
fakerwade's Avatar
Wade
Old 01-04-2020, 02:55 AM   #474
fakerwade
fakerwade's Avatar
The ceramic coated long tube headers are from JBA! Super high quality and great fit. They ran just under $700, plus another hundred for JBA high heat spark plug wires and oxygen sensor wire extensions.
Wade
Old 05-04-2021, 06:10 PM   #475
MikeinNH
Well this is a bummer, I'm looking to do a similar project but not many of these builds have been completed. I like the idea of using the Tahoe/Yukon floor and firewall to keep the HVAC intact. I hope all is well with the OP.
Mike
https://www.youtube.com/channel/UCUa...rZijm2tORBoexQ YT channel of my son and mine.
71 resto-mod (probably take years to do)
Projects: 71 C10 going on 04 Tahoe chassis * 67 IH 1200B Pickup mostly original w/ ext rust repair * 41 Buick Super 8 4 Door all original * 52 IH L-110 Panel Van getting S10 motor * 73 Datsun 620 Pickup all original
MikeinNH is offline   Reply With Quote
