#1326 |
![]() Join Date: May 2007
Re: My 50 roadster pickup build
hahaha nice pun
#1327 |
![]() Join Date: Mar 2011
Well, the teardown has started. Was able to get in a couple hours today. Got the electrical disconnected to the headlights and turnsignals, removed them along with the front bumper, horn, the grill and the radiator hood latch panel. Will see if I can get some more done this week. Here's a few pics...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1328 |
![]() Join Date: Mar 2007
Looks good. One of those 1 step forward and 2 steps back kind of projects...It will look like new again before you know it.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1329 |
![]() Join Date: Jul 2012
No doubt you guys will have it spot on and finished in no time. Jim, is the grill a reproduction piece?
#1330 | |
#1331 |
Jim, Slow and Steady! We are getting older I think that will work for a excuse
#1332 |
Hey Ray, Been using it for an excuse, more than I want too...Jim
#1333 |
![]() Join Date: Jun 2015
Lookin good man. Those rods that tie the core support to the lower grill, are they stock? My 49 didn’t have those and my 54 front end (changeover due to 54 cab) doesn’t have it either. Although it sure would firm things up.
#1334 |
Great!
You will be up and running again in no time!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1335 |
Slow and steady is fine, spring is months away.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1336 |
Yes, they are stock and they help lift up the lower panel, that is attached to grill...Jim
#1337 |
Thanks Kees and lower. Seems my months go by as fast as weeks
#1338 |
Was finally able to get back into the shop on Saturday for about 3 hrs. I removed running boards, small aprons, both front fenders and drivers inner fender.
#1339 |
Back to the shop in the afternoon on Sunday.
Pic 1 show how dirt and grime built up over the last few years. Pic 2 About an hour later, using Windex and lots of paper towels, in looks good again. Pic 3 Hard to see but, when I had the accident the deer also hit the drivers side door, but heres the crack in the paint. Pic 4 Here's the fenders all mounted to my fender horses, for work, etc.
#1340 |
After supper I went back to the shop and removed the interior door panels, disconnected the wires to the power windows, etc.
#1341 |
Tomorrow I will get Mark to help me remove the doors. I didn't want to just paint the parts that needed painting, just in case the paint isn't and exact match. So my plan is to paint both doors and from the cowl forward, including the hood. That way it should look good.
I plan on removing 90% of the paint from painted parts, so that way all the panels will have about the same thickness of paint. Will keep you update as I go along...Jim
#1342 |
outstanding attention to detail jim!
I read something about this the other day, seems if you do new stuff all the time the time dilation slows down, routine really is the thing that makes time accelerate.
#1343 |
Thank you...Jim
#1344 |
Extra work and I am sure the results will be worth it. Those horses are working well too.
Going to be nice. |
#1345 |
Thanks Doug, I'm hoping it will...Jim
#1346 |
Real quick update. Mark helped me with the doors and hood today. They are off and ready for me to get to work. Here's a couple pics...Jim
#1347 |
Looking good I like the painting plan.
#1348 |
#1349 |
Well I got started on removing paint today. It's going to be slow going, but I think it is worth it. I'm sanding with 320 grit wet paper, then using the palm sander with 1200 grit wet paper, then repeating until I'm happy. I'm using lots of pressure with both the hand sanding and the sander. Here's a few pics...Jim
Pic 1 and 2 Box and pad to use with palm sander. Pic 3 Here is a small section I did with 320 grit, to see how it worked. Pic 4 This is what I would like to see all over the hood, almost breaking thru to primer. Pic 5 Half hood at a time.
#1350 |
![]() ![]() Join Date: May 2015
looks good Jim. ..curious though...why the jump from 320 to 1200 paper...i would have thought 1200 would be to fine...but I'm not a real painter either..
