Old 12-20-2017, 10:24 PM   #1351
gigamanx
Re: My 50 roadster pickup build
Originally Posted by Flysocal View Post
Lookin good man. Those rods that tie the core support to the lower grill, are they stock? My 49 didn’t have those and my 54 front end (changeover due to 54 cab) doesn’t have it either. Although it sure would firm things up.
My 49 has them. I tried to keep little things like that to stick with the old truck vibe. That's why I also kept the X on the front of the radiator support even though its not really needed. You can kind of see them in this pic. Sorry for posting such dirty pics of my rust bucket when all I'm seeing is sweet shiny chrome in this thread
Fender saw horses. What a marvelous idea
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 12-21-2017, 12:20 AM   #1352
oldman3
oldman3's Avatar
Originally Posted by mongocanfly View Post
looks good Jim. ..curious though...why the jump from 320 to 1200 paper...i would have thought 1200 would be to fine...but I'm not a real painter either..
First thank you. 1200 is the courses they have that is used with water. The 320 cuts it good, but is done by hand, and I'm lazy. My thinking is between the two I will get the paint cut down thin, and still have a good surface for new paint...Jim
oldman3 is offline   Reply With Quote
Old 12-21-2017, 12:29 AM   #1353
oldman3
oldman3's Avatar
gigamanx, No problem with the pic, it may help someone see how they attach.
Fender horses, as you can see by the different colors, they have been used alot...Jim
Old 12-21-2017, 04:44 AM   #1354
Nut Case
Nut Case's Avatar
Oh Wise one, would you go step by step the process from raw steel to last clear coat. What materials you use, you know what type of primer, sealer, color, and clear. What sand paper and grits for what application. things that I need to avoid. Recommended any brands and such, what type/style sanding blocks. I've painted several projects using laqur, time to join the 21st century. This is not a time sensitive issue, just when you have time.
What gun and pressor for the various stull
Your painting skills are very good, all on needs to do is look at you roadster pick-up
Thanks in advance
NC
From Clear and Still Idaho!!!
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 12-21-2017, 11:16 AM   #1355
oldman3
oldman3's Avatar
NC, I'm not a great painter, I just take my time, read directions,follow them, and talk to my local guy at the paint store. It's been 9 to 10 yrs since I've painted. My son Mark does all the painting on his projects.
I will get a list and what I did painting my 50 and also Jimbo's 67...Jim
Old 12-21-2017, 01:56 PM   #1356
Indian113
Indian113's Avatar
Looks like your keeping yourself busy Jim! Got any changes planned while you have it tore down? Merry Christmas from The Wife and I, Please give your Beautiful Wife a Christmas Hug from Us.
Indian113 is offline   Reply With Quote
Old 12-22-2017, 12:17 AM   #1357
oldman3
oldman3's Avatar
Ray, yes busy sanding, reminds me I'm old, feel it in my back. No changes just paint and put back together. Merry Christmas to you and Eve, hug on the way...Jim
Old 12-25-2017, 04:51 PM   #1358
oldman3
oldman3's Avatar
Thanks in advance
NC
Nut case, here's my info on primer and paint. Now remember, I'M NOT A PRO PAINTER, just you average joe. I used all PPG products on my truck. Now we use a combination of Shop line and PPG. Shop line is made by PPG, just cost less and not the same kind of warrenty.
PPG products
Exopy primer DP-40LF (comes in several colors)
Hardner DP-402LF
Buff polyester primer MX-245 high build(no longer made)
Primer surfacer K-36
Hardner K-201
Some primers also have a reducer, and I can't find it in my old files.
I used a single stage paint with NO clear.
Acrylic Urethane DCC (47100 was my color)
Urethane reducer DT 870
Urethane hardner DU5
Shop line products
Epoxy primer JP-371
Hardner JH-3770
High build primer filler JP209
uses same hardner and reducer at primer sufacer
Primer surfacer JP202
Hardner JH301
Reducer JR 506
We ONLY have PPG dealer in my town. You may have a different paint company. I've been using PPG since the late 70's, before that I use DuPont on my 56 chevy, but like PPG better.
You best bet is to get to know your paint person, that can help guide you through just about everything. You can even stop at body shops and ask them what primers, etc. they use.
Paint guns are really hard to say. My truck was painted with a Walmart HVLP gun and the paint came out fine. Now days they want a different tip for solids and clear. Also some high build primers need a 2.0 tip. East wood has some good guns for a fair price.
Which ever product you buy, get the product or data sheets, it tell how to mix, flash time, etc.
Sand paper is ????, each person does it different. I use 180 to 220 dry for my primers, when I'm sure body work is done, by final primer, is done with 400 or 600 wet paper.
Cutting and buffing the paint is again up to each person, I normally start with 1500, then 2500 wet paper then 5000 with palm sander. Then buff.
Hope this helps...Jim
Old 12-26-2017, 05:12 AM   #1359
Nut Case
Nut Case's Avatar
Thanks a bunch, the info is fandamtastic, goin to study it closely.
What gun do you use for primer, and for paint?
Filters and such?
Air pressures and such?
Thanks again
Nut Case
Old 12-26-2017, 09:12 AM   #1360
reaper71
reaper71's Avatar
Nut Case this is Mark (oldman3 son)
As for the gun I have been using the 3M Accuspray it has removable tips 1.3,1.4,1.5,1.8 and 2.0 You use 1 Gun and only change the tips for different materials. Check into it. the pressure it sprays at will be stated from manufacturer and the Data sheets.
Mark
reaper71 is offline   Reply With Quote
Old 12-26-2017, 09:46 AM   #1361
gigamanx
PPG products
Hardner DP-402LF
Hardner K-201
Shop line products
Epoxy primer JP-371
Hardner JH-3770
Hardner JH301
Reducer JR 506
This is awesome. We might need a paint thread sticky sometime. I have no idea what I'm doing and just need someone to say...this works but won't break the bank.
Old 12-26-2017, 10:40 AM   #1362
oldman3
oldman3's Avatar
Filters and such?
Thanks again
Nut Case
Your welcome, Mark gave info on gun stuff...Jim
Mark
Thanks son.
Thank you, painting is a tricky subject, what works for one person, may not for another. Paint products are constanly changing, so knowing your paint person, can help keep you informed.
You can practice when spraying primer, getting the pattern right, air pressure, distant, ect., it helps, so you feel more confident by the time your ready for paint...Jim
Old 01-15-2018, 01:18 AM   #1363
joedoh
joedoh's Avatar
hey jim look what I found!
http://www.nextechclassifieds.com/listings/1241161/
cant be more than a couple convertible 3100s out there?
Old 01-15-2018, 02:15 AM   #1364
nuke1
nuke1's Avatar
That must have been tough to sell the old rod to fund this build at first. Kudos to you for doing that. And great work so far!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-15-2018, 10:46 AM   #1365
oldman3
oldman3's Avatar
Thanks joedoh, nice looking truck, looks like it is a true roadster, no side windows. Counting this one, I've seen about 6 total, some weren't the best in how that did the work, but some may say the same about mine...Jim
Old 01-15-2018, 10:48 AM   #1366
oldman3
oldman3's Avatar
Thanks nuke1. My kids thought I would never sell it, but it was time for a change. Thanks for the kind words...Jim
Old 01-15-2018, 10:55 AM   #1367
oldman3
oldman3's Avatar
Well I wasn't going to say anything about this, but I should update everyone.
Day after Christmas I couldn't hardly get out of bed. Long story short, I've been layed up since then. Doctors say it's two things. My sciatica, and also bursitis in the left hip. It could take up to 8 weeks to clear itself up, so I haven't done anything since working on the hood. I'm getting around OK, but just have to take it easy and work this out.
As soon as I'm able I'll post on the repair work...Jim
Old 01-15-2018, 11:02 AM   #1368
OutlawDrifter
Rest and heal up! Health is more important than updates on the pickup!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-15-2018, 11:08 AM   #1369
Indian113
Indian113's Avatar
Take your time and heal up. I think our age has made us a more aware of pain. Be careful walking around if you get any Ice in your area.
Old 01-15-2018, 08:19 PM   #1370
oldman3
oldman3's Avatar
Thanks Outlaw and Ray, I am resting, and taking care. Doc says it could take up to 8 weeks. Doing stretching execise, etc. Just bored out of my mind...Jim
Old 01-15-2018, 10:05 PM   #1371
lower50's
lower50's's Avatar
Take it easy Jim the truck will be there when you are all better, no need to rush.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-16-2018, 12:23 AM   #1372
oldman3
oldman3's Avatar
Thanks Bob, yes it will, I'm following orders...Jim
Old 01-16-2018, 02:56 AM   #1373
Advanced Design
Advanced Design's Avatar
Sorry to hear this Jim. Prayers for a speedy recovery!
Advanced Design is offline   Reply With Quote
Old 01-16-2018, 08:02 AM   #1374
mongocanfly
mongocanfly's Avatar
ditto on the fast recovery
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-16-2018, 11:09 AM   #1375
oldman3
oldman3's Avatar
Thanks Doug and mongo...Jim
