Old 11-04-2016, 12:46 AM   #851
TJ's Chevy
TJ's Chevy's Avatar
Re: Tricked-out Chevy six cylinder engines
Looks good man! Love me some hopped up 6 bangers!
Old 12-24-2016, 01:16 AM   #852
GMDad
GMDad's Avatar
Long read thru 35 pages but lots of neat motors. I am also starting on a new 292 for my 65 pickup. Just pulling the shortblock apart now to check it out. Cylinder head work was done in the summer time. Lump ports, new springs and the larger valves and a little porting. The machinist was very impressed with the flow numbers this head flowed as high as the V8 Vortec heads do. Now to read a couple more chapters in Leo's book.
GMDad is offline   Reply With Quote
Old 10-18-2017, 09:57 AM   #853
lowslow64
lowslow64's Avatar
1967 GM 292 bored 60 with Nitrous
lowslow64 is offline   Reply With Quote
Old 10-18-2017, 10:50 AM   #854
TJ's Chevy
TJ's Chevy's Avatar
That is sweet man! Been awhile since I posted mine.
Old 10-18-2017, 02:41 PM   #855
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice eye candy, TJ. Not green or orange like all the rest, but it's your engine in your truck.
Where's the fuel pump? I see a block-off plate where a mech pump goes, and a steel fuel line coming from over the transmission hump.
Looks like you have plumbed the in/out of the Clifford intake carb heat by bypassing the bypass hose elbow.
Is that a 3-Bbl'd Demon carb?
Who's Shorty headers?
Strange things.
'68OrangeSunshine is online now   Reply With Quote
Old 10-18-2017, 07:31 PM   #856
67pete300
Wish I could have this one back for my C10. Built it for my no options 67 Chevelle 300 years ago. Lump port head with split exhaust, HEI and lumpy cam.
67pete300 is offline   Reply With Quote
Old 10-18-2017, 09:18 PM   #857
T and S
T and S's Avatar
Just sent my 250 out for rebuild - will have Offenhauser intake, 390 cfm Holley carb, 292 exhaust manifold, cam. Shooting for 9:1 compression. Builder is Baldwin Racing Engines in Friedheim, Mo.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 10-19-2017, 08:41 PM   #858
TJ's Chevy
TJ's Chevy's Avatar
Strange things.
Fuel pump is mounted on the frame next to the rear mount fuel tank. Thermostat housing I have does not have a bypass anymore.
4 barrel 625 cfm demon. Am considering a 3 barrel conversion though but would need a bigger carb I believe. Probably a 750.
Clifford shorty headers.
Old 12-17-2017, 10:23 PM   #859
sixtyeightchevykid
sixtyeightchevykid's Avatar
what trans do you have bolted to this?
1968 chevy c10 lwb, 250 inline6, 4 speed,
sixtyeightchevykid is offline   Reply With Quote
Old 12-17-2017, 11:02 PM   #860
raidmagic
raidmagic's Avatar
Here's mine. 250. cam, split header, 4 barrel. It will stay for a bit but it will be replaced and used in another car I have. Fun to drive though. Right now there is a 3 on the tree behind it but I'm going to swap in a 4 speed I have.
Here's a short clip of it running.
https://youtu.be/xEJjbPWQvZU
raidmagic is offline   Reply With Quote
Old 12-19-2017, 02:02 PM   #861
rvrfoot
Wow, Like the return spring bracket.
rvrfoot is offline   Reply With Quote
Old 12-19-2017, 08:14 PM   #862
raidmagic
raidmagic's Avatar
Classy isn't it? Just one of the many things to do from the previous owner
Old 12-19-2017, 09:19 PM   #863
The Rocknrod
Moderator
The Rocknrod's Avatar
You know after looking at this thread I might go back and do another one.
Old 12-19-2017, 09:25 PM   #864
IRQVET
IRQVET's Avatar
I love the rugged simplicity of the inline 6's. So if you build another one, keep us posted . . . Just remember!
1998 Chevy Tahoe 2D
1949 Willys CJ2A
1967 C-20 Flatbed (Sold)
IRQVET is offline   Reply With Quote
Old 12-19-2017, 11:39 PM   #865
TJ's Chevy
TJ's Chevy's Avatar
tko600
Old 12-20-2017, 01:05 PM   #866
raidmagic
raidmagic's Avatar
Is it an illusion or did you build out the firewall?
Old 12-20-2017, 01:45 PM   #867
The Rocknrod
Moderator
I's a 48/53 Custom GMC Panel - see in my signature.
Old 12-20-2017, 07:13 PM   #868
raidmagic
raidmagic's Avatar
Ahh. 10-4 thanks
Old 12-21-2017, 01:01 AM   #869
shp4man
shp4man's Avatar
OK, not a tricked out motor, but a very dependable, and in some rpm ranges, torquey as hell 250 inch motor. Damn thing loves to climb hills. It's in a '65, but as near as I can tell, it's about a '69 or '70 motor by the casting numbers.
This was in my truck when I got it. When I replaced the valve cover gasket, was amazed by how clean it was inside- no sludge at all. It may be a Jasper motor ( a motor rebuilding company) , don't know, but it uses no oil at all.
I've grown to really like it, especially the sound.
Some day I'll doll it all up.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 12-21-2017, 01:37 AM   #870
'68OrangeSunshine
I see you have the rebuildable fuel pump. Is it easy to rebuild them? Can you still get the kit? Most '67s and -later L6s were issued with the disposable [solid yellow anodized can] fuel pumps. Easier to to replace than the SBCs which have that whole song-and-dance about the cam push rod.
Old 12-21-2017, 01:32 PM   #871
shp4man
shp4man's Avatar
Kits are still available, but looks like they cost more than a new, non-rebuildable pump. Figures.
Old 12-27-2017, 05:01 PM   #872
botoepfer
botoepfer's Avatar
here is my 63 on its way to be tricked,, and the pending 292 to be freshened up
botoepfer is offline   Reply With Quote
Old 12-27-2017, 07:35 PM   #873
rvrfoot
You already trick you your fuel line. lol
Old 12-27-2017, 09:42 PM   #874
botoepfer
botoepfer's Avatar
indeed I got after the funky stock air box to !
Old 12-27-2017, 10:17 PM   #875
'68OrangeSunshine
Yeah, that is some fancy jet-engine type plumbing just to a one-barrel.
