12-30-2017, 06:20 PM | #1 |
66 c10 Rear Cross Sill
Does anyone know where the spot welds should go on the rear cross sill?
12-31-2017, 02:00 PM | #2 |
Re: 66 c10 Rear Cross Sill
Mine was welded on each bed side. did not re-weld when i put the bed back together. This was a fleetside. Others have said no need. Heavy loads probably.
1961 chevy K10 my build is------------61K10 build |
01-01-2018, 04:16 PM | #3 |
Fleetside rear bed crossmembers were welded to the bedsides. Like 61K10 said, really no reason to weld them unless doing a 100% factory restoration.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
01-01-2018, 09:05 PM | #4 |
Bolts should be tight or the sides will drift out of square, mine did
05-25-2020, 11:52 PM | #5 |
But Found Her 25yrs Later!
Somewhat related question, how hard was it to remove the rear cross sill from the bedsides?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by The Rocknrod; 05-26-2020 at 01:07 PM. |
05-26-2020, 01:08 PM | #6 |
Moderator
Step-side?
05-26-2020, 03:58 PM | #7 |
Fleetside
05-26-2020, 06:16 PM | #8 |
One foot in front of the other
My experience is there is a weld across here that can be a pain to get to.
04-04-2022, 09:59 PM | #9 |
I'm not sure how i forgot about this thread. Thanks for the reply. I'll get the bolts out and then cut away at the weld. i'll try to take some pics.
