Old 04-28-2017, 10:06 PM   #151
ScottH
ScottH's Avatar
Re: The Doc & Kim 69 build
Hey Jess, just found this thread, looks like u r making some real progress.
Still have the other toys?
BTW, don't ever grow up......
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 04-30-2017, 10:26 AM   #152
zicc1835
zicc1835's Avatar
hey Scott, hope you are well, all i need is more time ....I'm still business traveling a lot. I'm having fun with the powder coating, going to start to reassemble the frame soon. Then things will slow again with pool opening and summer stuff. Still have the other toys and as long as my wife puts up with my adolescence tendencies ill keep getting /feeling younger . I will text u next couple weeks would like to stop by catch up with you on your projects
Jess
zicc1835 is offline   Reply With Quote
Old 12-29-2017, 11:45 PM   #153
zicc1835
zicc1835's Avatar
getting the rear ready.... finally found a little time
Old 01-03-2018, 02:23 AM   #154
zicc1835
zicc1835's Avatar
sent the rear off to the sand blaster today , ordered the axles from mosner the rear disk conv. from auto city classics and the fronts from khoult .....brown truck visit soon
Old 01-06-2018, 12:27 AM   #155
zicc1835
zicc1835's Avatar
brown truck dropped these off today
Old 01-06-2018, 11:21 PM   #156
zicc1835
zicc1835's Avatar
rear disc brake kit showed up today ....
Old 01-10-2018, 09:12 PM   #157
GR8-68
GR8-68's Avatar
Very nice, looks like you are about to make some progress
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-11-2018, 05:18 PM   #158
zicc1835
zicc1835's Avatar
yes things have slowed a little with business travel gathering all the suspension componets good to hear from you ,hope things are getting better for you
Old 01-14-2018, 12:05 AM   #159
zicc1835
zicc1835's Avatar
got this motor running sat for a long time supposedly under 60k on rebuild brought up to temp saw no leaks front or rear main... sounds good no smoke
https://www.youtube.com/watch?v=Bw4B...&feature=share
Old 01-14-2018, 10:46 PM   #160
zicc1835
zicc1835's Avatar
got her up to temp again today loosened the exhaust mani bolts while she was warm compression test today all good 135+ on all dismantled that contraption set the engine asisde for now..... I have KBS motor coater kit coming
Old 01-14-2018, 10:57 PM   #161
zicc1835
zicc1835's Avatar
now back to reassembling this frame... been almost a year since I have had a chance to get at this tommorow ill begin to get the engine cradle in then the rest of the C members will follow............
Old 01-18-2018, 12:10 AM   #162
zicc1835
zicc1835's Avatar
staying with this while Im not travling, keeping warm in my garage, getting a little done every night
Old 01-18-2018, 12:17 AM   #163
zicc1835
zicc1835's Avatar
little bling for Larry GR-8 68 ... replacing the rivets with stainless hex heads
Old 01-18-2018, 05:26 PM   #164
yj4000
yj4000's Avatar
Very nice touch! Keep up the good work.
yj4000 is offline   Reply With Quote
Old 01-18-2018, 10:56 PM   #165
zicc1835
zicc1835's Avatar
thanks for the kind words..... couple bolts in the engine cradle tonight
Old 01-19-2018, 11:25 PM   #166
zicc1835
zicc1835's Avatar
bothe sides cab mounts secured ill get some more of the front end together this weekend
Old 01-24-2018, 12:22 AM   #167
zicc1835
zicc1835's Avatar
this back from blasting pinion seal installed
Old 01-24-2018, 12:32 AM   #168
zicc1835
zicc1835's Avatar
tonight i was able to button up the passenger side lower control arm ill get the other side tomorrow and then drop motor an trans on it for some weight to get the springs in
Old 01-24-2018, 02:39 PM   #169
yj4000
yj4000's Avatar
Nice! Movin' right along.
Old 01-25-2018, 11:53 PM   #170
zicc1835
zicc1835's Avatar
thanks couple hours a night till the wife starts busting my nuggets
Old 01-25-2018, 11:59 PM   #171
zicc1835
zicc1835's Avatar
two hours to install the shock relo C-member and gussets then the panhard bar c-member they were both a PIA ill button them down tomorrow
Old 01-26-2018, 10:57 PM   #172
zicc1835
zicc1835's Avatar
outside for the night
Old 01-26-2018, 10:59 PM   #173
zicc1835
zicc1835's Avatar
so i can paint this in the morning
Old 01-28-2018, 08:56 PM   #174
zicc1835
zicc1835's Avatar
one coat epoxy primer one coat chassis satin
Old 01-28-2018, 09:14 PM   #175
zicc1835
zicc1835's Avatar
had these trailing arms stich welded and powder coated last year ... I put the new new bushings and installed them on the frame today......i f wasnt traveling this week I would have the rear in and rolling
