Old 01-22-2018, 12:22 PM   #1
nrpolo
Heater Fan Switch
I am trying to get the interior sorted on my 1970 GMC stepside and have a question regarding the heater switch. My truck had a three position switch mounted with two unoriginal screws in the hole to the right of the controls, I believe it should have a cigarette lighter there. From my searches here I can not figure out where the switch was originally mounted. Does anyone know or have a picture of a dash with the correct setup. Thanks and sorry for the stock photos as I have everything apart and in boxes.
nrpolo is offline   Reply With Quote
Old 01-22-2018, 02:36 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Heater Fan Switch
I'm not sure what you are asking here. The heater control uses the 2 holes in the bottom mount to mount to the dash.
This is my 71 with AC controller but it mounts the same way as yours. Your fan switch goes on the back side and the lever operates it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-22-2018, 03:16 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
The switch mounts on the right side of the heater control unit and the arm attaches to the center slide arm.. There should be two holes in the pot metal on the frame of the unit and a hole in the center arm.
LockDoc
Leon
Old 01-22-2018, 03:30 PM   #4
nrpolo
Thanks Guys! That make sense. Andy4639 I should have stated that my truck is non-ac so it doesn't have the switch on the left side of the controls. Someone broke the middle lever and rigged a flat piece of metal in it's place. I guess that is why they screwed the lo med high switch in the lighter hole. I will have to buy a kit with the new levers and put it back to original. Thanks Again!
Old 01-22-2018, 03:37 PM   #5
LockDoc
LockDoc's Avatar
No problem. The repair kit I bought had steel arms and worked out really good.....
LockDoc
Leon
Old 01-22-2018, 04:39 PM   #6
nrpolo
LocDoc Would you happen to remember where you got it?
Old 01-22-2018, 05:20 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heater Fan Switch
I understood it was non AC. That's why I was stating it hooks to the lever behind the controller.
https://www.classicindustries.com/sh...ater/controls/
Old 01-22-2018, 09:34 PM   #8
LockDoc
LockDoc's Avatar
I have a local supplier I buy my stuff from. I'm sure he got it from Here..... He gets 90% of his parts from Classic.
https://www.classicparts.com/1967-19...departments/7/
LockDoc
Leon
Old 01-22-2018, 11:19 PM   #9
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Here ya go
towbar is offline   Reply With Quote
Old 01-22-2018, 11:19 PM   #10
HO455
HO455's Avatar
Here are a couple photos of my crusty spare. They may help.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 01-23-2018, 07:08 AM   #11
Andy4639
Old member
Andy4639's Avatar
I spent 20 minutes googling for a picture like yours. Thanks for posting. I'll save these for the next time.
