03-06-2018, 10:00 AM | #1 |
69 Burb speaker/amp/sub suggestions needed
I have a RetroSound2 stereo head unit in my burb and am happy with all the features that it offers.
https://www.retromanufacturing.com/p...nt=28568817347 I am currently in the process of finishing the interior and would like to add some decent speakers/amp. What I'm currently planning is four 6.5s, 2 in the kick panel and 2 between the 2nd and 3rd row seat. I also plan on mounting a 10 to 12" sub in the spare tire compartment just behind the 3rd row seat. Thoughts on this setup? Any suggestions to include speaker brands, components or any other recommendations. I haven't bought anything but the head unit, so I'm open for other ideas as long as they don't get outrageous, . I'm just looking for some good sound quality and am not interested in winning any stereo contests, . Here are some pictures of the rear compartment. Thanks in advance!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-07-2018, 12:24 AM | #2 |
Re: 69 Burb speaker/amp/sub suggestions needed
You have so many different options, it is hard to recommend a specific setup. If you're not into winning a contest, don't want to mess with tuning, and just want good solid sound, you're on the right track. The retrosound has good basic tuning functions and can support 5 channel output.
A solid option (entry level) would be a 5 channel amp, front/rear component speakers, and (1) 10" or 12" sub. Everyone has their favorite brands in audio. I spent quite a bit of time researching and wandering around: http://www.diymobileaudio.com/forum/ Here's a few that get solid reviews on the forums, at entry level prices when this gets asked: Amps: NVX JAD900.5 amp $220. Zapco ST-X series ($250-$400). Alpine PDX-V9 $700. Components, is where you want to do your research and spend your money. It wouldn't be hard to spend about $250+ per pair. JL Audio, Image Dynamics, Focal, Morel, and Audiofrog ($$$$); all have multiple options and budgets. For subs, there are a LOT to choose from mild to wild. Image Dynamics IDQ10 or IDQ12 gets great reviews in small sealed enclosures without breaking the bank. Dig around on the audio forum, and you will find lots of reviews on many subs. Hope this helps to get you started. |
03-07-2018, 04:22 PM | #3 | |
Thanks for all of the info!! .
03-07-2018, 04:30 PM | #4 | |
https://www.sonicelectronix.com/item...-JAD900.5.html For front and rears? https://www.sonicelectronix.com/item...io-C2-650.html https://www.sonicelectronix.com/item...12-D2-V.4.html https://www.sonicelectronix.com/checkout/express
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-07-2018 at 04:41 PM. |
03-07-2018, 09:26 PM | #5 |
Sounds solid. Nice 'burban, by the way.
Not sure what you had in mind for budget, but I hope that fit the bill. ONE minor change, though. IMO, to get peak power available to run a 12" sub, you need to run 2 ohm. That means a dual coil 4 ohm, or a single coil 2 ohm speaker. It is always a good idea to have max power available, and turn it down, than to not have enough power and push an amp to its limits. Dual 4 ohm version: (wired parallel = 2 ohm) https://www.sonicelectronix.com/item...12-D4-V.4.html Just to throw a curve ball out there, JL W3 series get good recommendations for small enclosures. However, they are single coil, so you would need the 2 ohm version: https://www.sonicelectronix.com/item...-12W3v3-2.html I don't have an opinion either way, you'd probably get 50 different opinions on which one and it probably comes down to brand loyalty. JL components are a solid choice. Rears are typically for rear seat listeners. If you just want them for hearing music behind you, you can save a couple $ by going coaxial such as JL c2-650x @ $130. Neither choice is wrong, but definitely go components in the front. Good luck! |
03-08-2018, 11:37 AM | #6 | |
I can change to 10" sub, it should suit my needs. Also, I looks like the kickpanel speaker pods are limited to a 6.25" round by 1.77" depth. https://www.retromanufacturing.com/p...ry#prettyPhoto Any Suggestions?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-08-2018 at 06:28 PM. |
03-08-2018, 10:05 PM | #7 |
That 1.77 spec is for their entry level supplied speaker, not the depth of the pod. Their deluxe is 2.1. The JL's are 2.44. I don't think it will be a problem. If it is, then you can use a .5" spacer ring to move the speaker out.
IMO, the 10" is a better match for that amp. However, after looking over the spec sheet again, the coils are way less resistance than advertised. The D4 would end up @ 1.45 ohm, instead of 2 ohm. A lot of amps are not stable down to 1 ohm. This is out of my comfort zone for giving advice without consulting the manufacturer. Therefore, the IDQ10-D2 wired series is 1.85 ohm x2= 3.7 ohm. This would be the safer option. Image Dynamics recommends 250w RMS for the IDQ10. The NVX amp advertises 220-300w @ 4 ohm. The extra "horsepower" at 2 ohm would be nice, but I think 4 ohm would be adequate. We're kind of splitting hairs here. I could ask this question on the audio forum if you're interested in squeezing the extra power out of the amp. Which, I think would be needed if running the 12". |
03-09-2018, 09:58 AM | #8 | |
03-09-2018, 05:05 PM | #9 |
Looks like a nice setup. I've never hear of the amp before, but that might not be saying much.
I'm with BIGlaSS on running components up front and coaxial in the rear. I do that on most of my setups. Also I agree, its awfully hard to beat a JL subwoofer. I like the Retro Component Kick Panels but I don't see where you can buy them unloaded.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
03-09-2018, 06:26 PM | #10 | |
Bend the parking brake.
It looks like you can buy the "blank" kick panels directly from Retro. I also have the Retro2 and all Image Dynamics speakers for my 57 pickup, but haven't installed yet. Hopefully soon. In a 2 seater, I would skip the rear speakers and spend the money on a DSP (digital signal processer). A DSP will correct the imaging to put you right in the sound stage. No need for rears. |
03-09-2018, 07:30 PM | #11 | |
I agree rears in a truck isn't necessary. The seat kind of kills the sound quality. I like the idea of components due to lack of angle of coaxials won't give you the proper soundstage.
03-09-2018, 08:58 PM | #12 | |||
https://www.summitracing.com/parts/res-kp-c59-6772 Quote:
To both of you, sorry for all of the questions, but I'm stereo illiterate...
03-12-2018, 12:12 PM | #13 |
Looking at these for the rear:
https://www.sonicelectronix.com/item...-C2-650cw.html or this: https://www.sonicelectronix.com/item...ividually.html
03-12-2018, 03:51 PM | #14 | |
https://www.sonicelectronix.com/item...o-C2-650x.html |
03-13-2018, 08:48 AM | #15 | |
03-13-2018, 10:29 AM | #16 |
Your cart shows empty
03-13-2018, 10:37 AM | #17 |
03-13-2018, 11:12 AM | #18 |
Now I'm a home a/v guy by profession so I don't have to deal with wiring for impedance much. I would personally go with a Dual 4-ohm voice coil (you have selected 2) as I don't see where the amp is 1-ohm stable. biglass may have better input than me.
Also with the box, from the specs of the sub, is a little large (1.25 cu ft.) for the sub (1.0 cu. ft recommended), but should work just fine. Also the cutout diameter of the sub is a little larger than box so you may have to trim it. No big deal, just making you aware. Now I don't don't know anything about the amp, box, and sub so I'm just going off the specs on that site. The JL speakers look good!
03-13-2018, 02:05 PM | #19 | |
03-13-2018, 02:21 PM | #20 |
Looks good.
First off, here is the manufacturer's spec sheet for the subwoofer: http://www.imagedynamicsusa.net/idq-idqs Box volume (sealed) of 1.1 to 1.6 will be perfect. Here is an explanation of dual coil wiring: https://knowledge.sonicelectronix.co...woofer-wiring/ Specifically, Dual 2 to equal 4 ohm: Per the spec sheet of the IDq10 D2: 1.85 * 2 = 3.7 For the D4 version: 2.9 / 2 = 1.45. Therefore, I'm not comfortable recommending it. Can it be done? Probably, but I take no responsibility. This is out of my knowledge. I may be overthinking this, because wiring adds resistance. When looking at other speaker's specs, it is closer to nominal. I'm curious as well, I may ask this on the other forum. You will definitely squeeze more power from the amp with the D4 version. |
03-13-2018, 02:33 PM | #21 |
Yeah I knew you can wire to 4 ohm but saw the amp was 2 ohm stable and thus get more power to the sub (which we all like ). I also didn't take the time to do the math you did
03-13-2018, 02:50 PM | #22 |
I just took a look at that box. It is ported. I would use a sealed box or build your own. A ported box needs to be built to the speaker manufacturer's specs, not something generic. A sealed box will give better results for novice install.
03-13-2018, 02:52 PM | #23 | |
I posted this on the audio forum.. Probably get 50/50 answers. |
03-13-2018, 03:33 PM | #24 | ||
This one should be perfect. https://www.sonicelectronix.com/item...-MDFS1012.html Placing my order tonight. Will touch bases with both of you tomorrow, .
03-13-2018, 03:43 PM | #25 | |
