01-23-2018, 03:06 PM | #51 | |
Re: New replica tow hooks!
01-23-2018, 03:49 PM | #52 |
For all the use I would actually put them through, in all reality (ie zero)....I think I'll just get some pics of some and keep them in the glovebox.
lol Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-23-2018, 04:48 PM | #53 |
I started out with nothing - and I still have most of it |
01-23-2018, 09:45 PM | #54 |
I don't think the issue is as much whether they are less strong or more strong than factory hooks - the issue I have is that they ARE different (one way or the other) yet they are made specifically and on purpose to be indistinguishable from GM hooks (aside from the bogus bend) to include part number. So in the future the third hand buyer will think he has the safety of GM factory hooks. And he might have even more, or he might have much less. I am going to go out on a limb and say that the $50 hooks that more than meet the actual need have been fully proven to actually be that strong. They're just inexpensive because they're not a rare part. Whether originality is important to a specific truck owner is a matter of personal preference and the intended use of the truck. But all that aside, misrepresentation of a GM part (and its inherent strength with the engineering behind it to give you the warm fuzzy that it's "probably pretty strong because GM for dang sure protected itself against liability") is just flat wrong. Given the various reasons we like trucks, I'm not sure there's gonna be a long line of folks to buy hooks with, at the very least, unknown strength. If the background engineering proof were present to claim a certain strength level, then many folks would probably accept these as a substitute that's "good enough" in the looks department. Until that time when the engineering data is shared, the part number is removed, and they are proven to be more than just cosmetic, they are a huge risk to an uninformed buyer that thinks any tow hook "must" be strong if it's being sold to the public"... The seller is taking a pretty big risk too. If they are indeed strong, then the info to prove a product should be included - otherwise, it might as well be plastic.
01-23-2018, 11:04 PM | #55 |
no... the issue is that:
they are not stronger they are castings the cost more they are dangerous it is a deceptive practice. |
03-09-2018, 10:52 PM | #56 |
Are there any good quality aftermarket hooks available? Could've used some last weekend.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
03-10-2018, 10:54 AM | #57 |
03-10-2018, 11:05 AM | #58 |
20' Daredevil (Ret)
Post #49 shows the same type hooks I have used for decades. Cheap and very tough, I have abused them a lot and they just take it, no damage.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-10-2018, 12:52 PM | #59 |
Someone should 3D Print a bunch in black plastic. You'd have the look and no one would try to tow off it, because it'd be obvious once you touched it!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-10-2018, 01:53 PM | #60 |
Except, knowing the human condition, someone would try to use it!
03-11-2018, 11:32 AM | #61 |
...true, but the good news is that the hook would fail before any people or equipment was damaged...which is a good thing.
Sort of a mechanical fuse... Coley
03-11-2018, 11:47 AM | #62 |
Well, I just clicked on the original link, that listing ended but the item was re-listed. Price was dropped to $375 and that listing was sold. So.... we might see a YouTube video shortly of someone attempting to use it!
03-13-2018, 11:49 AM | #63 |
Complete novice on this, but does the "ductile" cast iron make a difference? Is that somehow better than regular cast iron, or is he just adding random words?
"Don't get it right. Get it running." -David Freiburger 2014 GMC Terrain I4 (wife's new ride) 2005 Dodge Magnum 3.5 (wife's old ride) 2003 GMC Sierra 5.3 Extended Cab 1972 Chevy Cheyenne 350 |
03-13-2018, 11:57 AM | #64 | |
in simple terms "ductile" means that the material can bend and flex somewhat without breaking... cast iron cannot bend and flex... neither are as strong as forged steel....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-13-2018, 12:27 PM | #65 | |
The purpose of the recovery hook is to provide a safe and secure point from which to recover a stuck vehicle. The hook should be strong enough to enable the recovery of a stuck vehicle, but more importantly must be designed so that if recovery forces exceed the design forces, it fails in a safe manner. To do so the hook must bend and release the rope. If the hook fails by breaking, the loose metal becomes a potentially lethal missile.
Stan 67 swb BLU MULE posted via flip-fone |
03-13-2018, 12:44 PM | #66 |
Thanks, ya'll makes sense.
03-17-2018, 11:18 AM | #67 |
I think those are interesting. Could you post pictures of where you have them mounted on your truck? Did you have to drill holes in the frame?
03-17-2018, 09:19 PM | #68 | |
20' Daredevil (Ret)
The front hooks are mounted on the bottom of the frame rails, just under the bumper. Had to drill holes in the frame and make a spacer (about 1/4" thick) so they'd clear the bumper. The single rear hook is mounted to the step bumper. If we get this camera business figured out I'll post some pics.
