03-13-2017, 12:38 PM | #176 | |
Re: Pic Request: Rally wheels on a dropped truck
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 03-13-2017 at 12:43 PM. |
03-14-2017, 11:02 AM | #177 |
Here's mine 15"x8" at all four corners
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
03-23-2018, 08:16 PM | #178 |
Hey guys Love the Ralleys.
I have an ECE lowering kit on my truck consisting of 2.5 spindle and a 2 inch drop spring in the front. However when reinstalling the front wheel i noticed the rim hits on the backside of the lower control arm! I didn't see any posts addressing this problem with any of the posts on this thread. i did see other posts saying they used an even lower drop than mine. did people change there lower arms? |
03-23-2018, 08:45 PM | #179 | |
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
03-23-2018, 08:49 PM | #180 |
HAHA your the reason i used ECE. Seen your thread on your truck..good to see you still have it
03-24-2018, 09:43 AM | #181 |
One day.....
You have to notch the lip of the LCA.
DZL1. Bertha build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=733306 '72 C10 short bed. Bessie (traded) '93 C3500 CC Dually. Bertha (traded) ‘96 C1500 ECSB. Black Beauty '89 C1500 RCSB LS swap. Black Bean '06 Silverado CCSB Ghost (Wifes Truck) '12 GMC Terrain V6. Titanium Bling (Wife’s Daily) ‘14 Chevrolet Cruze. Raspberry (Daughters Ride) '99 Jeep Wrangler. Road Hog (Sons Ride) |
03-24-2018, 09:53 AM | #182 |
One day.....
I couldn’t find pics, but basically where your wheel is rubbing your lca when you turn, it will leave a mark. That’s where you know you have to notch the curled lip of the lca. It shouldn’t be a lot at all that you would have to notch.
Hope this helps.
03-24-2018, 12:08 PM | #183 |
so notch it like a side ways triangle?
When i was imagining the wheel turning more and more cutting into the arm that it would be one hell of a notch. I felt that grinding it that much compromise the structures integrity. I would like to see a picture for reference of how much you had to take out. I'm not going to tell you that it bad or anything, just curious that maybe its not that much material that i have to remove. If you cant post a picture that ok maybe a general guess 1/2 inch cut? I appreciate and look forward to your comment. EDIT i just re read your comment if its just curled lip...I can do that Thank you |
03-24-2018, 12:11 PM | #184 |
Grind the LCA or use a 1/4” spacer.
1970 C10 Short Stepper with 71/72 front clip. |
03-24-2018, 12:25 PM | #185 |
One day.....
First off, I might have missed it but how wide are your front rally wheels? 8” or 6.5”? Wider? I know if it’s 8” the grinding is minimal. And trust me, the amount of grinding you have to do won’t compromise the structural integrity of the lca.
BTW, I have a bagged c3500 diesel dually. You should google image the size of notch needed for bag clearance to the frame!
03-24-2018, 12:42 PM | #186 |
Its an 8" rim. out comes my grinder...Thx
I was told i cant use a spacer, not enough stud for the nut to tighten the wheel on properly... |
03-24-2018, 01:42 PM | #187 |
One day.....
Good luck. Let us know how it goes.
03-24-2018, 01:54 PM | #188 |
BigBlockBobby
My 69&71
Rears are 15x12 on Black 69 And 15x10 on Blue 71
Bob Last edited by bobshotrodblazer; 03-24-2018 at 02:58 PM. |
03-24-2018, 02:16 PM | #189 |
Active Member
Nice truck. I need to find me a set of the original 72 truck rally's
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
04-15-2018, 01:02 PM | #190 |
yup i needed to grind a little on the backside an a fair amount on the front side of the lower control arm. I may still need 1/4 inch spacer, i can live with that. thanks for the help guys
02-02-2023, 01:12 AM | #191 | |
Posted via Mobile Device |
02-03-2023, 03:50 PM | #192 |
1968 Chevy C10 SWB |
02-04-2023, 12:37 AM | #193 |
Mine
02-04-2023, 04:20 AM | #194 |
Long gone but not forgotten.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
08-29-2024, 12:57 AM | #195 |
I’ve been gone awhile and I still have not solved this problem. This thread took off!
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears Good judgment comes from experience, and experience, well......that comes from bad judgment. 1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then. |
08-31-2024, 10:35 PM | #196 |
Love this thread...
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
