Old 04-16-2018, 06:49 AM   #1
krue
Designated A-hole!
krue's Avatar
What's the best way to fix
my harness. It's out of a 2003 Savana so it's the Blue/Green PCM with DBC. The previous owner (MDOC) butt spliced a couple of wires from the PCM to the injectors. The coolant temp sensor plug is gone and they spliced in a connector for the camshaft position sensor. I don't see a lot of aftermarket harnesses for my donor and don't mind doing the repairs. I just don't know the best place to get the connectors and terminals. I thought about hitting the pull a parts for a scrap harness and robbing wires from it to repair mine. What say ye?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-16-2018, 07:48 AM   #2
ls1nova71
ls1nova71's Avatar
Re: What's the best way to fix
That's what I would do. Just go to the 0ick a part and get the ends you need, then solder and heat shrink them. Should be perfectly fine if you do a good job.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
