04-16-2018, 05:18 PM | #2926 |
Re: PO has me PO'd
Always welcome Jess, might be some other parts around here you can use,MSC 6A1, FAST Dual Sync distributor
04-18-2018, 10:51 AM | #2927 |
Re: PO has me PO'd
[url=https://flic.kr/p/26e9jkb]20180418_104435
[url=https://flic.kr/p/Ja8hRQ]20180418_104540 sides look alittle bulky, will have to machine some slots or trapazoids
04-18-2018, 12:13 PM | #2928 |
Re: PO has me PO'd
ill give you a warning beforei head out hoping for a nice sunny day......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-18-2018, 04:19 PM | #2929 |
Re: PO has me PO'd
Do you need my cell number?
04-18-2018, 08:48 PM | #2930 |
Re: PO has me PO'd
Thanks Jim.....just looked thru my contacts thought i may have had it from my visit please PM to me ill lock it in and PM mine back....
04-23-2018, 01:30 PM | #2931 |
Re: PO has me PO'd
Started to work on my harness, found out there is a late and early version of harness, so my TPS and IAC connecters are wrong, plus location with in connecters. Wiring diagram shows this.
While I was working on the harness, found out I was putting the seal on wrong, so, I cut the tabs shorter, maybe a 1/16" or 1/8" and wrapped the tabs around the wire, then slid the seal on, much easier then trying to crimp the seal, as I would cut the seal. Having the right crimper also made the job easier. I like to pre-crimp with a larger size and then do a final crimp. I may go back and solder. Also, having the right pin tools, is a must, can't remove without releasing lock on the pins [url=https://flic.kr/p/26oYwbW]20180423_120857 sorry no pics of late style connecter, as I destroyed it on removal
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-23-2018 at 01:37 PM. |
04-23-2018, 01:32 PM | #2932 |
Re: PO has me PO'd
[url=https://flic.kr/p/256HNBz]20180423_121452
[url=https://flic.kr/p/23GQLvN]20180423_125720 [url=https://flic.kr/p/Jk3sgb]20180423_125807 The larger crimp puts a hex crimp but the narrower crimp tool fits better on the pin, and does a factory style crimp
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-23-2018 at 01:42 PM. |
04-24-2018, 10:32 AM | #2933 |
Re: PO has me PO'd
These are the pins and tool that I'm working with. Since all the wires pulled out of the pins, I will solder them
[url=https://flic.kr/p/GQxatM]20180424_102116
04-25-2018, 10:47 AM | #2934 |
Re: PO has me PO'd
Did some soldering of my pins, s/b a better connection, just don't go crazy with solder, I use a very small diameter! Just on the crimp
[url=https://flic.kr/p/25a5mXt]20180425_103313[ While I was researching Jess's Sniper EFI, I found a clamp on O2 senser mount, hope it works as I suck a welding TPS is locked and finished [url=https://flic.kr/p/25a7kYk]20180425_105519
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-25-2018 at 10:58 AM. |
04-25-2018, 01:13 PM | #2935 |
Re: PO has me PO'd
04-26-2018, 10:34 AM | #2936 |
Re: PO has me PO'd
Last conversion from late model to early connecter- MAP
[url=https://flic.kr/p/GUyec2]20180426_094705
05-03-2018, 02:07 PM | #2937 |
Re: PO has me PO'd
managed to read through most of your build thread, you do some fantastic work, on a side note im in the industrial maintenance profession my self, im still green compared to you tho with only about 8 years of experience. looking forward to more updates great work so far
05-03-2018, 11:05 PM | #2938 |
Re: PO has me PO'd
The tool to compress the tangs on the terminal is a pin pusher.
Your crimpers look to be incorrect, sadly there are many kinds. If the wires pull out of the terminal after crimping, the crimper is not the right one, or the crimp was incorrect. Sorry... Ref the pic in post #2933. The crimp of the big end (closest in the pic) is in the insulation to help hold the terminal; the next one is in the bare wire and provides the electrical connection. The crimper should roll the tangs of the terminal in a bit, not just fold them over. If the crimper has U shaped patterns and not rounded W patterns, it aint right. Also, with a less expensive crimper you may need to crimp a few times on the different spots. The next bits sticking up slightly are what hold the terminal in the connector and what the pin pusher releases to allow the terminal to be removed. It might be too late, so if you soldered, make sure to try and minimize vibration, wobbling, movement, whatever at the connection. A soldered joint is brittle and more prone to failure when stressed. A soldered joint also depends on a good mechanical connection; solder is an alloy of lead and tin, neither of which are strong. Sorry if that was TMI. Last edited by franken; 05-03-2018 at 11:16 PM. |
05-04-2018, 09:29 AM | #2939 | |
Re: PO has me PO'd
My career in industrial man. was rewarding and I enjoyed going to work every day. Ya just never knew what fire you would have to put out, on any given day, and that was the interesting part, never boring. Something broke all the time in the factories I've worked at..... Pay was great, and overtime was always there. Papermills were the most fun as everything was HUGE. Pharmicueticals not so much as everything had SOP's Gotta get my spell check working again!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-04-2018 at 10:07 AM. |
05-04-2018, 09:43 AM | #2940 | |
Re: PO has me PO'd
Using the right crimper is also key, as you state , a "W" shape is the one to use of the correct size Information is key, to a buildthread, and I hope it helps young builders in the future, past when I have long gone
05-04-2018, 10:01 AM | #2941 |
Re: PO has me PO'd
Newest adventure, step up resister to crank trigger- 5v-12v across signal and power wire
[url=https://flic.kr/p/26KxEf5]20180504_095233
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-04-2018 at 10:13 AM. |
05-10-2018, 10:42 AM | #2942 |
Re: PO has me PO'd
Ref: post 2896. repin connecters and terminals for FAST to EFI Connections. Connectors from FAST would not fit sensors from EFI, plus terminal locations are in a differant oreintation, with information provided by EFI and the schmatic from FAST, I was able to repin the connectors to plug in to the sensors on the cam and crank with out the jumpers from EFI Connection, SOOOO, wires go in and out the same colors
Terminal release tool goes in the little rectanguler slot at the top of the connecter. First remove white lock on connector, then you are able to remove wires and metal terminals. Don't forget to rebend locking tab up Photos to follow, flickr not working, or operater error
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-10-2018 at 10:55 AM. |
05-10-2018, 11:38 AM | #2943 |
Re: PO has me PO'd
[url=https://flic.kr/p/HmZ71T]20180510_101426
[url=https://flic.kr/p/HmZbNi]20180510_101519 this is the portion of the schmetic I'm working on [url=https://flic.kr/p/25DujVB]20180510_103855
05-11-2018, 07:24 PM | #2944 |
Too Dumb To Know Better
Re: PO has me PO'd
You make it look so easy Jim.
05-12-2018, 07:02 AM | #2945 |
Re: PO has me PO'd
Thanks Doug, but the hard part for me will be having my computer talk to the system, I have no idea how to do that! Lucky for me I've had people to talk to, Jim at TPIS and the techies at FAST, and Chris at EFI Connections, they answered all my dumb questions
Hav'nt seen anyone else on these boards using FAST, so I'm on my own, just me and my computer
05-24-2018, 12:28 PM | #2946 |
Re: PO has me PO'd
Just picked this up from E-bay for 25.00 or 30.00. Thanks to the heads up from long standing member John H. Great forum when guys look out for one another
[url=https://flic.kr/p/27u8n1e]20180524_121406 This thing looks brand new, date on box says 1995, so I hope it's not for a newer truck, guess I'll have to wait and see
05-25-2018, 12:23 PM | #2947 |
Re: PO has me PO'd
Jim,
Great buy! Here are some older gauges and boxes with same part numbers on the box and the gauge. |
05-29-2018, 07:54 AM | #2948 | |
Re: PO has me PO'd
06-07-2018, 10:32 AM | #2949 |
Re: PO has me PO'd
It's alive and well, buddy came over to help figure out 2 phase
[url=https://flic.kr/p/26QMHWN]20180606_114651
07-17-2018, 09:08 AM | #2950 |
Re: PO has me PO'd
[url=https://flic.kr/p/299Mhsf]20180717_085848[
ANyone know size of these four bolts?????????????? Putting A/C in a non A/c truck, bezel to nice not to use
