04-09-2018, 10:37 PM | #1 |
Kel's '50 GMC 1/2 ton build
As suggested, starting a build thread. Bought it from a guy in Comanche , Texas. Was asking $1400 with clear title. After seeing several similar trucks that were in worse shape with no title, decided to buy sight unseen. 5 hour drive from Corpus Christi, the guy said next day he'd deliver for $200...I said have you left yet...
Truck shows up 9/24/17. I was still working o the '59 Apache, so didn't touch it for months. Truck was better than expected. Typical cab corner, floor pan repairs needed, but no replacing roof, door skins, fender patches like the '59. Even has the running boards intact, not rusted out or totally missing like most I had see. All the door/window hardware work, just a really solid find.
Kel's 1950 GMC 1/2 ton build |
04-09-2018, 10:49 PM | #2 |
Re: Kel's '50 GMC 1/2 ton build
Disassembly started.
04-09-2018, 10:54 PM | #3 |
Speedway X-member & Mustang II IFS install.
04-09-2018, 11:10 PM | #4 |
More IFS install.
04-09-2018, 11:16 PM | #5 |
My DIY rotisserie. 2 HF engine stands, had to cut neck off and scab pieces in to raise the frame so running board brackets would clear ground/lift.
04-11-2018, 01:02 AM | #6 |
Looking at the pics the bed looks like the longer 87 inch unit. Is that a long wheelbase half ton from the factory? That must be one rare bird if that's the case. Looks like you're motoring right along for just getting started!
Steve weim55 Colorado |
04-11-2018, 01:42 PM | #7 |
Trial fitting LS, 10 bolt rear end that was traded for front axle from this truck, set of Foose wheels/Nitto tires from CL, mocked up rear leaf springs.
04-11-2018, 01:42 PM | #8 |
Springs
04-11-2018, 05:38 PM | #9 | |
welcome to the forum 68blackbird
texas sun is a little rough on paint from what i see, easy on rust too half that truck would be missing up here in michigan Quote:
$4500 rust bucket 'no title' is what i see all over craigslist i call it barrettjacksonitis
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-11-2018, 11:55 PM | #10 | |
For anyone interested, here are my links to some of those builds. Kel https://photos.google.com/album/AF1Q...VlLdWoqF1aemNK https://photos.google.com/share/AF1Q...VkTlBmak5KZmhn
04-12-2018, 12:03 AM | #11 |
Big step tonight, got front end put back together, even got springs in, uncut as Ogre suggested, glad you did man, I was really tempted to cut at least a 1/2 link out just to make it easier. As it was, having the right tool made all the difference. Also got the rear end back from my buddy who installed the new 3.73 gears, and did all that pinion, back lash stuff done. He's done a few 100 of them, so I feel good about that. Have the rear kinda snugged down till tomorrow, hope to get some wheels on it so we can nail down the rear and start on setting the LS in, I'm sure I will be hitting you guys when that time comes...Kel
04-12-2018, 12:06 AM | #12 |
More from tonight...that spring tool was worth its weight in GOLD!!
BTW, open for any and all suggestions on the rear end set up...Kel
04-12-2018, 08:16 PM | #13 |
Rolling chassis, very happy.
04-12-2018, 08:18 PM | #14 |
I guess we need to fit cab on to mock up LS install?
04-20-2018, 05:07 PM | #15 |
More progress...got cab back on to mock up LS motor mounts, started working on fender dents, pulled heads off LS to make sure everything is tidy, looks good so far.
04-20-2018, 05:09 PM | #16 |
Progress pics...
04-20-2018, 05:24 PM | #17 |
looking good ...be sure to use new head bolts...those a tty bolts...
04-20-2018, 06:20 PM | #18 |
Did not know that...many thanks!! Kel
04-22-2018, 11:44 PM | #19 |
Got motor, heads, intake cleaned up and painted.
04-22-2018, 11:46 PM | #20 |
Removed cab to install motor/tranny and mocked up brake booster.
04-22-2018, 11:48 PM | #21 |
LS & tranny bolted in.
04-23-2018, 11:53 AM | #22 |
What brake booster did you go with? What is the clearance to the transmission like? You used the 4l60e right? I am to the point of having to pick and buy brakes.
My 1950 Chevy build |
04-23-2018, 12:09 PM | #23 |
I used the drum/disc combo from Pirate Jack on ebay. I do have the 4l60e, not sure what clearance you mean? Kel
04-23-2018, 12:29 PM | #24 | |
I have never heard of Pirate Jack. I will have to look him up. Thanks.
04-23-2018, 06:42 PM | #25 | |
https://www.ebay.com/itm/1947-54-Che...53.m2749.l2649
