#176 |
Re: 57 GMC, frame swap, 4wd, 454 big block, 4 speed
Thanks, I think it is simple and will work good
My 57 GMC build |
#177 |
I made my exhaust system today. I used dual 2 1/2" tubing into a merge collector to single 3" tubing, through a large straight through chambered Magnaflow muffler, then turned out underneath where the bed step will be. I'll put a nice tip on it after I get the bed mounted. I also put shims in to adjust the pinion angle, and mounted the electric fuel pump in front of the tank and even with the bottom, but I didn't take pics of that. So I did get my goal met this weekend of getting the tank mounted and the exhaust made, and a couple other small things. Maybe one of these years, I'll actually get to drive it! I think my next item to do will be making my fuel lines and brake lines, and get the brakes bled and working.
My 57 GMC build |
#178 |
A couple more...
My 57 GMC build |
#179 |
![]() Join Date: May 2007
nice exhaust, I hope it sounds good
#180 |
Thanks, I hope so. Hopefully it's not too loud. It should be ok since the muffler is a large 3 chamber with mesh packing, and over 40 inches long. I'm hoping it's a fairly mellow tone. One of these days I'll find out.
My 57 GMC build |
#181 |
Nice work! that should flow nice and sound great.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 |
#182 | |
I've had two 454 powered trucks that would consistently get me 12 mpg. One was a bone stock 1994 C3500 with TBI. The other was a 1978 C10 using a 454 I'd built, hooked to a TH-400 automatic and a 3.07 geared rear axle on 31" tall tires. The carb was a Holley 3310 750 CFM vacuum secondary carburetor with the heaviest secondary spring Holley offered to keep the motor as lean as safely possible. The motor was built for torque and towing so it didn't need to spin fast. 4wd may cost you a bit, but the lighter truck body may be enough to offset that, hopefully. It's going to be close. -Joe
#183 | |
My 57 GMC build |
#184 | |
As I recall, the cam was a Comp Cams 268 duration. The heads were 049 castings and the intake was a Performer RPM 2.0. With 4.10 gears and the 1:1 4th gear, you're engine is going to be spinning pretty good at highway speed, even with 33" tires, about 2,700 rpm. When you go to the NV4500, you'll be running at 1,950ish rpm at the same 65 mph. Obviously, the closer you can get your torque peak to cruising speed, the better off you will be for economy. -Joe
#185 |
![]() Join Date: Jul 2009
I'm going sort of the opposite direction as Purcell. I've got 3.08 gears, SM465, NP205 and 33" tires on my truck. It does well enough at speed, but turns are a bit of a problem as you're going a little fast to get down into 2nd, but you are lugging in 3rd.
I am in the process now of swapping the 3.08s out for 4.10s. Initially I'll still have the SM465, so I'll be able to let you know how that goes if you're interested. I've also got an NV4500 I will be swapping in but probably a weekend or two later.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#186 |
Yes, I'd like to hear what you think of it with the 4.10 gears. I'll eventually do the NV4500 trans, but not for quite a while.
My 57 GMC build |
#187 | |
-Joe
#188 |
I got a couple more parts in. The hub dials are custom made by GMCGrim here on the forum. They are machined out of aluminum and anodized blue, and will replace the stock plastic dials in the big hub Dana axle. I also got my gas pedal and cable. Hopefully I'll have some time soon to get the hub dials and pedal/cable installed. I'm also planning to make my brake lines and fuel lines when I can work on it again. I need to get all of my window and door seals ordered. I'm trying to find the door seals from Soft Seal, but they're out of stock. I'll keep looking for those.
My 57 GMC build |
#189 | |
I can't wait to see your build when it is completed. -Joe
#190 |
The plastic hub dials are the one bad thing about these stock hubs, so I'm glad to get these custom made aluminum dials. I wish I had the time to jump in and finish the truck, but I don't have much free time. One of these days I'll hopefully have it on the road.
My 57 GMC build |
#191 |
I got a really nice front bumper for the truck. It'll be getting powder coated the cream color like the wheels and grill. My boy helped get the cab masked off and sanded to get it ready to paint the interior. Hopefully I can get that done tomorrow. Once that is done, I can finish wiring all of my dash switches and gauges.
My 57 GMC build |
#192 | |
#193 |
Yes joedoh, I was glad to have the help.
This morning had another step forward. We wiped down the interior one last time and sprayed it in antique white, then pulled off all of the masking. I'm looking forward to seeing the dash all together with the switches and gauges, and the other parts installed.
My 57 GMC build |
#194 |
This will be (is) amazing!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#195 | ||
I've been driving with the 4.10s, SM465/NP205 and 33" tires for a week or so now. It does great for my normal day to day driving which rarely gets above 50mph. 1st/granny low is useless for me - can't even shift into 1st anyway. 2nd is good for starting off and about the first 50 feet. Also good for crawling through parking garages. 3rd gets you up to speed quick and is perfect for turns. I've got a fairly torquey motor also, and 4th is good for a pretty large range, from sharp curves at ~1500rpm to up to 55-60mph which my tach says is 2500-3000 rpm. I would not be comfortable getting out on the highway where anything less than 70mph is obstructing traffic around here. I've got fairly loud mufflers and an imperfectly balanced drivetrain and driving a sustained 3000+ rpm isn't comfortable due to noise and light vibration. My truck seems to feel most comfortable cruising at around 2000-2500 rpm. I will be attempting to do my NV4500 swap this weekend and I'm looking forward to seeing how that works out. Hope this helps.
#196 | |
As to first gear, it was pretty much unusable unless you had a heavy load that you needed to get rolling or you just wanted to idle along in SoCal rush hour traffic. When I was teaching my kid sister how to drive, I took her out on a hill and let her dump the clutch in first gear, to demonstrate she couldn't stall the truck. With that fear gone, the rest came easy. -Joe
#197 |
olds57
Growing up in Southeastern ID, First gear ( granny or the big hole) and not syncro,,,,, Hauling hay on a single 2 ton flat bed truck we lined the tk straight down the field, grabbed some twin, teeing the steering wheel to the vent window separator . so it would go straight, put it in the big hole the clutch set the throttle what a blast working out gettin good memories Looking good, fun for all. Needs a friend
Been there, wrecked that ![]() |
#198 | |
Thanks for the info, I appreciate it!
My 57 GMC build |
#199 |
Just a couple things to update... I have most of the switches and dash wiring done, and I painted the gauge panel and installed the gauges in it. I should have the dash finished the next chance I have to work on the truck. I also bought a truck bed trailer to use the bed floor. It was a boat trailer with a 73-87 long bed mounted on it. I removed the bed and sold the trailer, so I ended up paying 50 bucks for he bed. I would have used the bed floor from the original 73 donor truck, but it was badly dented and rusted. I'll measure the floor size of my 57 long bed, and cut out this floor to size, then get it installed. It will also use the cross braces, since its going back on a 73-87 frame anyway. I think it will look like it came from the factory with the ribbed floor when its done.
My 57 GMC build |
#200 | |
Thats good memories. My Grandad told me stories like this too.
My 57 GMC build |
