06-14-2018, 03:41 PM | #26 |
Re: Stock 6" 3 nub wheels on 12" CPP disc brakes?
I seen the witness marks. I have a pretty good idea where I'd need to grind. I'm just not sure I really want to do that just yet.
06-14-2018, 11:14 PM | #27 |
How did I get this OLD!
I run 6" 6 lug up front and 8" 6 lug on the rear. I like that look. I found 4-4 nub 6" just in case I decide to up grade to disc brakes. Those 71&up 6" 6-bolt rims are out there and fairly cheap.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
06-15-2018, 01:02 AM | #28 |
you might give these guys a call - no guarantee they have em in stock (lots of things they list aren't in stock), but they do still list 6" wide 6 lug on 5.5 bc 71+ wheels. They do exist, I've been to their warehouse when I lived in CA - for hubcaps. But they do wheels too. Worth a call.
https://www.originalwheels.com/chevr...0rims-1972.php |
06-15-2018, 10:34 PM | #29 |
Thanks guys, very good info. If I can't find them locally I've found them online for around
$50 rash with free shipping, believe it or not. |
08-08-2018, 03:00 PM | #30 | |
Tks Chris
1969 Chev C/10 1972 GMC K2500 Custom |
08-08-2018, 06:17 PM | #31 |
I have 235/75/15 on 6” up front and 275/60/15 on 8” out back.
01-14-2020, 12:24 PM | #32 |
Well? What did you end up doing?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-15-2020, 01:39 PM | #33 |
I know everything is different but I had a similar problem running some Pontiac rally's on my GTO years ago and made some 3/8" spacer plates to move the wheel out so it cleared. That set of wheels got moved to my S10 and the same plates used. By now the wheels and plates have about 250k on them with no problems. The plates cost me $60 to have them made by a local machine shop to be an exact fit on the hub.
I stacked washers on the lug nuts until I got clearance to determine how thick of a spacer I needed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-16-2020, 12:51 AM | #34 |
I would check your local auto salvage place for a mid 70's 4WD K10 truck. I got a set of 4 for $50.
01-17-2020, 07:24 PM | #35 |
Over the Christmas holidays I did install 6 lug disc brakes. The 71-up 6”rims fit flawless. A quick blast and paint and nobody would know there has been an upgrade done.
http://67-72chevytrucks.com/vboard/a...1&d=1579303249
