Old 06-11-2018, 08:03 PM   #1
mkmc69
mkmc69's Avatar
Which intake 7.4L Vortec?
What options for an intake do I have if I want to run a carb, or aftermarket fuel injection on my 7.4L Vortec? I did not get the computer or the wiring harness, or the throttle body for the original set up, so I figured I would either carb it, or maybe install an aftermarket fuel injection set up.
mkmc69 is online now   Reply With Quote
Old 06-15-2018, 08:14 AM   #2
DjS71
Re: Which intake 7.4L Vortec?
Put in a bunch of filters over at Summit
if its a Vortec 7.4 its a mark VI, the filters i have are for carburated dual plane intakes. You didn't list your cyl head port configuration, so you can narrow it down some more. (or less by deselecting things). I'm sure others will chime in, but it'd be easier to advise if we knew your goals (racing, towing, 4x4 etc.)
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 06-15-2018, 04:40 PM   #3
mkmc69
mkmc69's Avatar
Thank you for your response. It's a Vortec motor, so it has the oval port vortec heads. Just wanting a driver. Not a race truck, or anything like that. The motor will be a stock vortec big block, just won't have the factory induction system on it. Maybe down the road, once it is up and running, I would think about upgrades to the motor. I will check out Summit, and see what they have to say too.
Old 06-19-2018, 01:32 AM   #4
Fullpower
Edelbrock, and Whipple each make a kit, belt driven any where from 6 to 14 pounds manifold pressure, depends on pulleys, exhaust restriction, air temp, etc.
Fullpower is offline   Reply With Quote
