06-23-2018, 09:28 AM | #176 |
Re: Sparky's 1978 Silverado Build "Addiction"
Thanks fella’s!! I need to clean my garage, get a pile of boxes recycled, then head to the landfill with other “stuff!”
Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
06-23-2018, 06:07 PM | #177 |
Well, started to clean the garage after going to the landfill, however, I got distracted with other things.
Pictures: 1. Put the wheels and caps on...distraction number one..cascaded from there!! 2. Got a little ambitious and hooked the LS to the picker!! 3. Installation went smoothly when I got the boy involved. 4. Fits well. 5. Checking driveshaft. The truck spent a lot of time out in the elements with the box off, you can see some of the pitting on top of the frame, still sturdy though!! Also replaced the camaro exhaust manifolds with Hooker exhaust manifolds, then installed Hooker's down-tube thingy's with the bung for the O2 sensors. The left air bag is leaking....I believe I didn't push the tubing into the fitting all the way when I was in a rush, it takes about an hour to deflate the airbag. Gonna have to fix that tomorrow. Gonna head to JaysonB's tonight and run him some parts. Garage aint gonna get cleaned today. Lol!! Thanks Mike
06-25-2018, 09:08 AM | #178 |
I'm just glad to be here!
Looks good. Does the panhard bar clear the rear end pumpkin when the suspension is completely air'd out?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-25-2018, 11:14 AM | #179 |
Karl, as it is now, no. I will have to adjust the panhard bar at some point. The bracket holding the bar will have to be moved inward toward the pumpkin about 1/2 an inch and point a little skyward in order to clear the pumpkin when the truck is air'd out. Thanks Mike
06-26-2018, 11:55 AM | #180 |
Had to do something last night so I put some epoxy on a couple bed pieces that had been blasted and picked up on Friday. I’m waiting on some upper air bag brackets that are being fabricated for me so I can finish the rear of the frame. Thanks Mike
06-27-2018, 09:57 PM | #181 |
Always have to be doing something truck related!! Tonight I shuffled around the garage. I put the frame aside and will focus on the cab for a few days. I’m still waiting on my two upper brackets for the rear air bags. I found some time to do a little more welding and grinding on the cab. Mike
08-02-2018, 10:14 AM | #182 |
Started to lay out the bed pieces again. I’ll need to get a lot in epoxy primer this weekend.
08-02-2018, 05:41 PM | #183 |
there it is, been waiting on this update!
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
08-02-2018, 06:15 PM | #184 |
I know, I know! More to come!
08-03-2018, 10:19 PM | #185 |
Tonight I put the front steering components together and aligned the tires as close as I could get them until it gets aligned professionally down the road. Mike
08-26-2018, 11:41 PM | #186 |
Kind of jumping around!! Today I worked on the underside of the cab, tediously slow work!
Mike
09-01-2018, 11:20 AM | #187 |
Garage wrench
Looking great!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
09-01-2018, 11:33 AM | #188 |
09-02-2018, 09:41 AM | #189 |
Great progress. So cool that you are building two trucks of this caliber. And one in honor of your Dad. Keep up the good work -- Jayson too! And thanks for showing us the process.
09-02-2018, 11:28 AM | #190 |
Thanks LT7A. I’m running out of time!
09-10-2018, 07:29 PM | #191 |
Sloooooooooow progress! Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 Last edited by Dads79GMC; 09-10-2018 at 09:31 PM. |
09-10-2018, 09:28 PM | #192 |
Got the second coat of epoxy on the bottom of the cab (still wet). Tomorrow I will seam seal, let dry, then undercoat. Looks like I still have some welds to grind down
Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 Last edited by Dads79GMC; 09-10-2018 at 09:38 PM. |
09-10-2018, 11:07 PM | #193 |
Looks good Mike!
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
09-11-2018, 10:47 AM | #194 |
Great work. What are you going to use for undercoating? On my last one, I used black Raptor liner and was very pleased with the results.
09-11-2018, 11:09 AM | #195 |
Thanks aggie91! Sorry for the loss on Saturday, great game! I have some 3M undercoating the bodyshop store here in town recommended. Bottom turned out better than I thought it would, I have a good mentor!! Thanks Mike
09-11-2018, 11:10 AM | #196 |
09-11-2018, 09:06 PM | #197 |
Should be able to flip it upright tomorrow after it dries overnight. It's still a little soft to be pushing around. I'm in a hurry because i think the other one will be coming home soon!!!
Thanks Mike
09-11-2018, 10:33 PM | #198 |
Now that you have all the hard dirty work done, just haul it up with you and we can get it knocked out next!
09-11-2018, 11:49 PM | #199 |
Don’t tempt me!!!!!
09-18-2018, 10:16 AM | #200 |
Last night I was able to put the cab back on the dolly and get it upright. I also removed all the various screws and other fasteners on the firewall. I’m running out of time, need to get this project back on track! Thanks Mike
