07-05-2018, 09:40 AM | #601 | ||
Re: Attempting my first build 72 K5
I sometimes think things happen for a reason. Maybe the engine gods knew I had wished I did the overdrive the first time around and now this is an opportunity to do just that. Another way I'm looking pass this.. is that this K5 deserves a BAD A** motor and not a West Coast Engines.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
08-05-2018, 02:18 PM | #602 |
I decided on doing the 427 stroker and been taking the time to figure out other mods I'll be making.
I'm converting to EFI using the Holley's sniper. Now, there is a few options you have when it comes to running efi. At first, I was going to use FiTech's command center. The command center acts as a remote fuel pump that has to be mounted in the engine bay. This allows you to use your stock tank / existing fuel delivery setup. The second option, drill a hole in my tank and install Holley's retrofit in-tank fuel pump.. I did not like idea of this at all. The third option and the direction I went with was to use Boyd's welding fuel tank (EFI Stealth side fill) This was the only bolt on (sort of) EFI fuel tank ready that I could find out there. All I had to do was a drill a couple holes in the frame and line up the (optional) mounting brackets. The tank comes with an Aeromotive in-tank fuel pump. Aeromotive recommends their wiring kit which I went with as well. Really easy to install. That hardest part was finding a good hiding place for the relay which needs to be near the battery. I mounted it right underneath the battery tray next to the MSD ignition box.
08-05-2018, 02:37 PM | #603 |
The Cam we're using is going to need all the available vacuum so converting to Hydroboost was in order. I used CaptainFabs brackets and then I ordered the hoses in fittings from Summit and made my own lines. I picked up the hydro from a local shop in San Jose (power brake exchange) this particular Hydro came off a P30 Van.
Something else I originally wanted to do was to convert the rear drums to disc. I also used CaptainFabs brackets for this too. I called Moser and ordered a set of custom axles and the rep knew exactly what size I needed for the disc brakes. With the Overdrive from the 4L80e, I decided to switch from the stock 3.07 open carrier to 3.73's with Auburn's electronic posi. For those considering Auburn's electronic locker (Ected). My axle housing required machine work to allow the locker to fit. The guy who is building my transmission did the work on the axle to make it work. This was unexpected because neither of us knew this was needed or else I would have not gone with this unit. Carrier to fit Ring Gear: 0.125 milling to fit. Housing Pumpkin shave 0.040 and Main Cap 0.015
08-05-2018, 02:44 PM | #604 |
Now for the real eye candy! Short block is assembled. We used a solid roller cam for this build. To clear the 4" stroke he had to cut notches in the bores.
08-05-2018, 07:49 PM | #605 |
Proprietor of Dale's Corner
After all the work too. But it will be bad @$$. Can you give some info on your motor build? Block crank etc... This sounds awesome.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-05-2018, 11:17 PM | #606 | |
Crankshaft: 4" Stroke Dart 4340 Forged for Internal Balance Pistons: Mahle Forged Pistons Connecting Rods: 6" SCAT Forged Cam: Custom Grind Solid Roller Rockers: Comp Por Magnum 1.6 Lifters: Comp Sportsman Heads: AFR 210cc (EDIT - 8/14/2018 going with 220cc instead) Intake: Single Plane Edelbrock Super Vic Distributor: MSD Pro Billet Headers: Kooks 1 7/8"
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive Last edited by 72K5CSTDarkOlive; 08-14-2018 at 10:02 AM. |
08-06-2018, 03:46 PM | #607 | |
08-09-2018, 01:07 PM | #608 |
niiiiice mike. more pics as you progress!
08-09-2018, 07:19 PM | #609 |
I can't wait to see how it runs. I used to have a detuned 427 small block out of a sprint car in a 72 K10 and I could pull a house to the nearest gas station. Let alone whoop on myfriends Camaros and Chevelles. Awww the good ol days. I hope this runs like it did and then some.
08-14-2018, 10:05 AM | #610 | |
Chris - What's the latest with yours? Has Ceasar made any more progress?
08-14-2018, 10:08 AM | #611 |
Ask and you shall receive.
Transmission & Tcase is back in the K5.. I had to move the mounting bracket back about 2.5". Now comes the fun part.. routing the wiring harness for the 4L80e.
08-25-2018, 03:29 PM | #612 |
I was just wondering if you still had to use the spacer with the steal wheels to clear the wilwood calipers? I know you had to use them with the rally wheels is it the same for the other wheels as well?
Thank you Chris |
08-28-2018, 08:20 AM | #613 |
Awesome build!!!!
08-28-2018, 12:00 PM | #614 |
I know you have an update. Quit sandbaggin'!
09-05-2018, 12:20 AM | #615 |
I did. The steelies where a little better than the rallys and they just barely rubbed but I had to run the space unfortunately
09-05-2018, 12:41 AM | #616 |
The engine went to Dyno last Monday I spent three 10 hour days at the shop helping with the engine install later that week. Boy did we run into issues.
The headers would not go in from the bottom or the top with the engine mounted. We had to hoist the engine up a few inches to get those 1 7/8 pipes to slide inside the frame rail. I pray I never have to remove the headers ever! I upgraded the PS pump to a Borgessen high pressure with two return lines. The Pump is the press fit style from 75-78 and I needed to use different brackets so I got a set of brackets from Bills hot rod for the PS & Alt. These brackets gave us all sorts of problems. Nothing was lining up and we spent hours fiddling with accessories. In the end we did prevail and we started her up late last night. Here's a link if you want to hear the dyno - https://www.instagram.com/p/BnAOhzvB...y=gromm.racing
01-05-2019, 03:54 PM | #617 |
I'm trying....
As always--way to persevere my friend. Boy--has that pickle ever got some juice! Fantastic work.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-05-2019, 08:21 PM | #618 |
TOTY, seems wried you only have 6 psi of fuel
Iron canine, he may have you beat most beautiful K5
01-05-2019, 09:06 PM | #619 |
01-05-2019, 09:21 PM | #620 |
I'm trying....
Hard to argue Jim...she is a beaut. What is an absolute certainty is that this rig would smoke it off the line.
01-05-2019, 11:18 PM | #621 |
good call, too many whiskeys
01-05-2019, 11:20 PM | #622 | |
But, she doesn't have a book for the coffee table...
01-18-2019, 10:43 PM | #623 | ||
It would be cool to see them side by side together shinning in the sun
03-01-2021, 05:01 PM | #624 |
Great job on this truck and I look forward to reading your next iteration. You were driven to make it happen and I could see how your knowledge and abilities progressed since I read the whole thing in one big chunk. Ordinarily, I'm not a green guy, but that is a great color and goes well with the white top, black interior, and metal and wood trim.
Kind of looks like you might have snagged a cameo of James Hetfield behind your Blazer in this picture. |
