12-13-2017, 06:26 PM | #101 |
Re: slammed 57
cool inners!
05-08-2018, 02:04 PM | #102 |
Re: slammed 57
cleaned up the front grill a bit. just about ready to be sent over to the chrome shop.
will be working on the reverse flip hood next week. Thanks for tuning in. |
05-11-2018, 04:37 PM | #103 |
Re: slammed 57
You're doing amazing body work Mike, gaps look great
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
06-13-2018, 02:30 PM | #104 |
Re: slammed 57
Finally found a good hood , so after I got it on, here is the issue I had and after talking with other forum members heres what i came up to fix it, so I will share in case any others run into this situation thanks to mp&C ,big glass and others for I used a combination of everyones ideas
after putting it on the truck I noticed the outer round edge meets the cowl on the cab would not match up. after talkng with other we all agreed that the hood brace/hood settled int the middle... you can see here heres what i fabricated to help me reshape the hood brace a bit. it bolts to where the factory hinge would be after ,I placed a floor jack with a piece of 2x4 to prevent metal to metal contact and marring the hood brace , starting in the center and every 6" or so move out towards the passenger side . return to the center and then move out toward the driver side I measured before and after to prevent of over stretching and it also prevents of taking the hood on and of several times down to maybe 2-3 times. For my application it needed to be moved up about a 1/4" or so. at the ends where the hood ends meet the fenders , you can put them outwards by hand to match the cab cowl gaps and the end result |
06-14-2018, 03:58 AM | #105 |
Re: slammed 57
Wow great work. I'm putting this in my build book just in case.
What's the plan for stopping this from happening over time? NC
Been there, wrecked that |
06-16-2018, 11:10 AM | #106 |
Re: slammed 57
not sure what caused it.... so it would be hard to figure out how to keep it from happening again.. not really sure.... the hood was in perfect shape... do dings or dents
06-18-2018, 11:01 AM | #107 |
Re: slammed 57
Count me in! Love the truck and amount of detail you are adding!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
06-23-2018, 08:22 PM | #108 |
Re: slammed 57
working on the hood gaps
as you can see the aftermarket front fenders gaps are not even close to the originals... even though the originals are not the greatest either....so lets see what we can do bout getting them up to todays standards about 1/2" gap here and here you can see how they raise more than they should and now the gap is where it should be. as you can see I split the fender , pushed the gap where they should be, I also had to split the side flange where the hood sits down in the fender to bring down the hieght... finish tacking it up, a bit more grinding down the welds , some hammer and dolly... and one less thing to cross off the to do list Last edited by slammed57; 06-23-2018 at 08:30 PM. |
06-23-2018, 11:18 PM | #109 |
Re: slammed 57
Nice work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-24-2018, 03:20 AM | #110 |
Re: slammed 57
Dude
Strong work! nc
07-07-2018, 06:31 PM | #111 |
Re: slammed 57
reverse hood done and working smooth
07-08-2018, 07:32 AM | #112 |
Re: slammed 57
Very cool.
Kim |
07-08-2018, 11:02 PM | #113 |
Re: slammed 57
clever fix on the hood being out of shape!
I love reverse tilt hoods too, I had one once. many people dont know how much work it is to get it to drop in front of the grille like yours does, but I do! great job!
07-09-2018, 09:21 AM | #114 |
Re: slammed 57
Cool
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
08-05-2018, 04:58 PM | #115 |
Re: slammed 57
Awesome work, love the inner fenders and the fix for the hood and props for making the chassis. really nice work.
My taking way longer than expected 58 build |
08-05-2018, 08:39 PM | #116 |
Re: slammed 57
Slammed,
I have been following your build. You do awesome fabrication work and the truck is looking good. I am working on a 56 and have a few questions. That size wheels and tires are you running. What the the ground clearance at the lower lip of the front fender behind the tire. I am at about 4" and wondering if that is going to be too low for a truck without airbags.
56 Chevy Truck project... https://www.dropbox.com/sh/p4lmbnnen..._HBbGxJ0a?dl=0 Plastic project... https://www.dropbox.com/sh/axc8ksw3l...1K4pvR1na?dl=0 |
08-06-2018, 09:03 AM | #117 |
Re: slammed 57
thanks, bud I appreciate it
08-06-2018, 09:28 AM | #118 | |
Re: slammed 57
08-07-2018, 07:45 PM | #119 |
Re: slammed 57
Mike - WOW! really coming along nicely there! you are really kickin it now. Keep up the good work.
Been puttin some miles on my rig. Just playin around with it mostly.
My Build: 57 Chevy Pro-Street |
08-07-2018, 09:38 PM | #120 |
Re: slammed 57
HEY ptc, how you been? sorry I had to go back and edit that post... that blue truck was my old one that I was shown with a static drop not air ride.... LOL I wish i was that far along... Hows your truck been doin? any bugs you had to work out? or had it been all good?
08-09-2018, 10:01 PM | #121 | |
Re: slammed 57
What size are those rear wheels and tires?
08-10-2018, 12:54 PM | #122 |
Re: slammed 57
same exact set up I have now, 20x15 wheels with mickey thomsons .. Off the top of my head the tires are 29x17x20
08-10-2018, 01:56 PM | #123 | |
Re: slammed 57
The body work may not get done for another year or so, so Im just gonna play.
08-11-2018, 09:35 AM | #124 |
Re: slammed 57
What did you use to have that floating grill? I like it!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
08-11-2018, 09:40 AM | #125 |
