#1451 |
Re: My 50 roadster pickup build
8man start off by spraying primer to get the technique down, then try with a practice fender etc. to get comfortable.
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1452 |
![]() Join Date: Sep 2017
Reaper, I was thinking about trying some primer. I can always sand it back down to metal and try again. Good advice. I'll do that since I have plenty of parts to prime right now.
#1453 |
![]() Join Date: Mar 2011
OK, it's been ten days since I said we were ready for paint. What has slowed us up was having problems with the paint. For some reason we were getting little blue spots in the paint, as if it wasn't mixed good enough. So I took it back to the paint store, showed them what was happening,(pics on cell phone and I can't get them to down load, will show later if I can) they sent their paint pro out to look at the panels. He used his Ultra-violet light, etc to check, the spots were flat, not something that fell into the paint. After a while he ask if I had tried to wet sand out the spots. I hadn't, so I got water and 600 paper and kept wet sanding until it disappeared. Now, my hood had about 20 of these spots, which I sanded out. My question was, why it happened, and how to keep it from happening again. Both the fenders and doors also had these spots, which I sanded out.
The paint store called the main supplier to check on mixing of the paint, which they said was all new products, and they thought it was in my prep work. My paint store knows me and knows how cautions I am about prep work, and keeping a fairly clean paint area. After waiting for 4 or 5 days, I told them to shake the s**t out of both cans of my paint. I took it home and poured both gallon cans into a new bucket. The gallon can we had been using showed this blue in the bottom, that wasn't mixing correct. We mixed the paint in the bucket by hand and then strained that mixed paint back into the gallon cans. Couldn't see anything in the strainers, so we will use it as is and see how it works. The reason I'm telling about this is, everyone can run into problems with paint, it's never 100%, but you try and do the best you can. I've never had this happen before, and hope I never do again. To end this lengthing story, we painted on Wednesday and today, and it was fine, no problems. So I'll close this part and show some pics...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 08-10-2018 at 09:07 PM. |
#1454 |
Here's before and after pics of the hood, with it's final paint.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1455 |
Pass. fender before and after.
#1456 |
Drivers fender before and after, thank you Doug for the fender..Jim
#1457 |
![]() Join Date: May 2007
stunning!
#1458 |
![]() Join Date: Jul 2012
Too bad about the paint problems. Looks really good Jim. Cindy and I had a great time running it over...and we still chuckle about our gift giving.
#1459 |
Thank you
I think we were both pleased, but it was funny, and meeting both of you was the best part...Jim
#1460 |
![]() ![]() Join Date: May 2015
looking good again Jim
#1461 |
Won't be very long and that beautiful Truck will be back on the Road! The Paint sure looks Nice.
#1462 |
Good job to you and your son. The paint looks great.
#1463 | |
#1464 |
OK, Mark got a couple pics loaded from my cell phone. This is only a few in the pics, but it was all over the hood...Jim
#1465 |
Today, Mark and I took the fenders to the basement, brought up the doors. I wet sanded both doors to remove any blue dots. We swipe, vacuumed, and mopped the floor. Hung the doors and Mark painted, here's the pics...Jim
#1466 |
![]() Join Date: Sep 2016
Fascinated by the painting process in the garage. I am about a year out on blowing my truck apart for paint. This winter I have some other goals first.
Your work looks pretty amazing. Wondering how you keep the color consistent when doing the painting in parts as opposed to all at once when the truck is together? I'm thinking different temps, different humidity, different cans of paint might make one panel ever so slightly different than the one beside it. Second question...why is the floor not covered? You mentioned mopping and vacuuming it. Did you put a sealer or something on the garage floor when building the paint booth? Thanks and awesome work on the paint job!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#1467 | |
Cans of paint. I buy my paint at a regular auto paint store. Their mix is very close, but I will normally take the cans of paint, pour into a new clean bucket, mix it all together, then pour back into each can. This gives a better chance of color being the same. This works great for non-metallic colors. Metallic colors are the ones that air pressure, distance from surface, speed, etc., that will make the colors seem to not match. Another thing is always paint the part as it will mount on the vehicle. I DON'T have a paint booth, just a 30X40 shop, we seal off half the shop with plastic to keep it as clean as possible. Floor had a sealer put on 20 years ago, but with all the work, etc. it has worn off. We clean the floor each time to help with dust, etc. Hope this helped...Jim
#1468 |
Nice work. The blue dots are really strange, I didn't think that could happen. If you tried to do the dot technique I bet you couldn't lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1469 |
Lower, you got that right...Jim
#1470 |
Good to see you going forward Jim.
Never saw those blue dots in paint....it’s pure magic!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1471 | |
#1472 |
Jim, did you figure out what caused the Blue Dots? Looks like Mark worked around it and finished the job pretty good.
#1473 |
![]() ![]() Join Date: Nov 2008
Everything’s looking SO good, Jim. Congrats.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#1474 | |
Thanks Dan, should start on the cab cowl section soon...Jim
#1475 |
did you have ac in the shop? maybe see if the blue fluoresces under a black light. a friend of mine had funny blue dots on his paint after driving downtown and was screaming conspiracy theories (marking his car for surveillance, etc) till another friend, an HVAC tech, said it was spots of the dye they use in HVAC systems to find leaks, and sometimes a leak at the compressor gets pumped in the air all over in very small quantities.
not saying thats what it is, but if you have heard of the most interesting man in the world, my friend is probably the LEAST interesting man in the world and someone having him under surveillance was hilarious and outrageous, I was glad to hear he was wrong. truck is looking amazing jim!
