09-15-2018, 02:39 PM | #76 |
I'm trying....
Re: 1946 B.F. Avery Model A Tractor Restoration
She's finally a runner....and don't worry I'm not going to leave those ugly clamps on the top radiator hose. I've got some wire ones that just need a bit of paint:
http://vimeo.com/290059752
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-15-2018, 05:30 PM | #77 |
MAN....that thing sounds so SWEET...!!!!....congrats on having a runner...
09-16-2018, 10:30 AM | #78 |
I'm trying....
Thanks. It took a few days to sort it through, but I'm tickled about it.
09-16-2018, 11:47 AM | #79 |
Proprietor of Dale's Corner
It sounds great.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-17-2018, 06:51 PM | #80 |
What a sweet sound!
09-17-2018, 09:41 PM | #81 |
I'm trying....
Thanks guys.
...well I thought she'd be moving under her own power today...but the machine shop can't seem to get my drive shaft yokes drilled correctly. The closest replacement U-joint that I could find had cups that were about 3 or 4 thousandths too big (hence the machining). I went by to pick them up today...3 were too tight and 1 was too lose. Luckily I had spares. Hopefully by week's end she pulls her own weight. Since no new pics and just in case all that's missing from your life is a 90% complete tractor not moving but running video, here you go: http://vimeo.com/290399238
09-29-2018, 09:04 PM | #82 |
I'm trying....
We have done our best to preserve and restore anything and everything original to the tractor. The dash assembly was no different. We were very lucky just to have a complete dash assembly. These are usually rusted out or gone. The key was long since gone, but board member LockDoc was able to restore and re-key the ignition switch. The gauges were sent off for restoration and the light and starter switch were simply cleaned up.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 09-30-2018 at 09:35 PM. |
09-29-2018, 09:13 PM | #83 |
Dang, that dash looks great...
09-29-2018, 09:15 PM | #84 |
I'm trying....
09-29-2018, 09:24 PM | #85 |
I'm trying....
The grille emblem was in a sorry state. I sent it to El Paso Electroplating and got it re-chromed. Then Eric hit it with several coats of paint and polished it back.
09-29-2018, 09:38 PM | #86 |
I'm trying....
The driveshaft ended up being a very sticky wicket. I procured what I thought were appropriately sized U-joints. Turns out the cups were .004 too big. Which turns out to be a problem. When I tried to press them in, I squeezed a yoke. I was able, with difficulty, to procure a replacement. I thought I could open up that small amount with a brake hone, but I was wrong. So I decided to just take them to a machine shop, but they seemed to have more trouble than I did. Long story short, a second replacement yoke had to be procured and the machine shop sent me home with a big bill, one yoke done, and reamer to get the rest done myself -which I did.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 10-11-2018 at 08:09 PM. |
09-29-2018, 09:51 PM | #87 |
I'm trying....
Decals were a challenge too. The hood decal that is reproduced for sale is -surprise,surprise- incorrect. Luckily we had the originals to copy. The same folks that made the decals for my Blazer helped get these correct. The factory originals were, I assume a water transfer. I preferred individual cut letters, but that was not practical for the small lettering. So we segregated those elements. I was very happy with the Vortox decal and was lucky to find it. I got a Fram decal from the same guy-but it was of poor quality. I found a very nice reproduction of the Fram decal from a nice gentleman in Maryland who had reproduced it for a military truck that he had restored. The battery decal was the easiest. I just called Mustangs Unlimited right down the road
09-29-2018, 09:55 PM | #88 |
I'm trying....
Even though our original engine tag was in really great shape, it wasn't perfect- and had to be removed anyway when the block got machined-so we got a new tag.
09-29-2018, 10:02 PM | #89 |
I'm trying....
So we finished up today and brought her home. The last two lines on our to-do list were to put on the hood decals and finish the light assembly. I had ordered some new light lens gaskets, but they weren't just right. So we cut gaskets. Eric did a great job polishing out the stainless rings. Hard to believe these are original glass and bulbs.
09-29-2018, 10:03 PM | #90 |
Very nice decal and tag work! Impressive!
09-29-2018, 10:06 PM | #91 |
I'm trying....
Here are a few after pics...
09-29-2018, 10:09 PM | #92 |
I'm trying....
09-29-2018, 10:21 PM | #93 |
I'm trying....
I am very happy with how this project has turned out, and I'll post some more outside pics or from shows in the future. But I want to thank everyone who worked on or helped with this project:
LockDoc Shuman Towing Athens Commercial Tire Brad's Auto Machine OliverCrawlers.com (Chris) Steiner Tractor AKO Signs Advanced Electrical Rebuilders Brillman Bill Williams Sims Radiator Service First Quality Machine Shop AutoZone OReillys Napa Paper Pulleys El Paso Electroplating Doyle Hill My Lovely Wife ... of course Eric (OldYellow), for painting this tractor so well it wouldn't crank.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 10-03-2018 at 05:08 PM. |
09-29-2018, 10:21 PM | #94 |
I'm trying....
09-29-2018, 10:58 PM | #95 |
Congrats on a restoration done well...it is sweet...
Curious though...in the old ad pic..is that a hydralic control/cylinder hanging on the side ?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-29-2018 at 11:51 PM. |
09-29-2018, 11:32 PM | #96 |
Fantastic attention to detail from beginning to end, well done!
09-30-2018, 08:28 AM | #97 |
Equal opportunity joke ofender
Beautiful work!!
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
09-30-2018, 12:30 PM | #98 |
Very very nice
09-30-2018, 09:26 PM | #99 |
I'm trying....
Yes it is. It is a reservoir and "actuator" for the integral lift system. If you'll take a gander back at post #5, you'll see the one that came on this tractor. I elected not to restore the lift, because #1-I didn't want one more thing that could leak #2-I'd have to come up with more parts, this one had been modified- and finally #3-I think it is a bit of an eye sore and breaks up some pretty nice lines for a tractor.
09-30-2018, 09:27 PM | #100 | |
I'm trying....
Tags |
bf avery, ixb3, model a, restoration, tractor |
