09-20-2018, 03:22 PM | #1 |
"Helper leaf spring setup and factory (used) A/C Vents.
Hello for sale i have:
1. 1970 c10 "Helper" leaf spring setup including Leaf Springs x 2 Both Brackets that go to the frame, and all hardware. All has been sand blasted and primed and now painted but the pic only shows primed. SOLD EDIT: Bill pointed out to me via P.M. that I was missing the brackets where the rubber piece is mounted that the overload springs hit on the axle when they are "Overloaded". I actually DO have them too thought that was part of the axle bracket. They are included but not blasted. This will complete the overload spring setup and im still Asking $150.00 plus shipping. This is an AZ truck and they are in GREAT shape. 2. Used A/C Vents Including the brackets to the Dash, the Ball Vents, and the Holders that the hoses hook up to and the center vent but no screws. they will need to be cleaned up and new felts put on. Asking $30.00 plus shipping. SOLD Last edited by elorenzof; 09-25-2018 at 05:38 PM. Reason: added in sold status |
09-20-2018, 09:46 PM | #2 |
Re: "Helper leaf spring setup and factory (used) A/C Vents.
if the center vent is metal not plastic ill take the AC vents shipped 07981
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
09-21-2018, 08:48 AM | #3 | |
PM me your info and I'll ship em out today! My PayPal is e.lorenzo.foster@gmail.com Thank you |
09-22-2018, 05:05 PM | #4 |
How did you get that main bolt off that attaches the spring to the rear bracket? That thing felt like it was welded in place. Then again, I gave up real quickly...
Very nice set of Overload Springs! Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-22-2018, 06:19 PM | #5 |
I used a rust penetrant for two or three days before I tried to remove them but it was still pretty tough...
09-23-2018, 08:07 AM | #6 |
“On The Hunt”
I’ll take the helper spring setup if it will work on a 72 c10
09-23-2018, 01:06 PM | #7 |
Hello!
Look and see if you have the holes in the frame by the rear bumper mounts. There will be 4 kinda close to each other and horizontal but kinda not exactly level horizontally. Slanted down toward the rear. Text me and I'll send you a picture or two. 480-688-3098. - Lorenzo |
09-23-2018, 10:22 PM | #8 |
Put me 2nd in line for the helper springs. I will take them if Njeiv does not.
09-24-2018, 04:11 AM | #9 |
“On The Hunt”
Payment sent for the helper leaf setup.
09-24-2018, 07:13 AM | #10 |
In line on the vents
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-24-2018, 11:38 AM | #11 |
09-24-2018, 11:40 AM | #12 |
09-24-2018, 12:45 PM | #13 |
Thanks for letting me know
09-24-2018, 06:01 PM | #14 |
Hello sir,
Zicc1835 has paid for the vents FYI. ~ Lorenzo Last edited by elorenzof; 09-25-2018 at 05:39 PM. |
09-24-2018, 09:51 PM | #15 |
pm on its way I will take the vents..... i didnt see your responce on the middle vent until tonight thanks for giving me time to respond
Jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 09-24-2018 at 09:56 PM. Reason: more |
09-25-2018, 11:30 PM | #16 |
No problem. Thanks for letting me know. I won't be using them right away anyway. Still gathering parts for a stock AC system.
Tags |
ac vents, helper leaf spring |
