10-12-2018, 12:12 AM | #1 |
Still livin the "dream" in '54
GMC 270 engine mystery.
I have a '48 GMC 300 series truck. The
motor has been replaced with a 270. GMC engine serial numbers are hard to come by/interpret. Here is the only block number I can find. Can anyone help ID so I can maybe figure out what parts I need to order. Thanks. From what I have read, they made a couple of different types of 270's over the years.
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
10-12-2018, 07:58 AM | #2 | ||
Re: GMC 270 engine mystery.
I've never searched for an old GMC engine number before. It looks like the first three digits designate the engine as a 270. I believe the second three digits are a serial number. I believe I 4 I would be where a date code is found, and that the format should follow the same format as the casting date codes. If so, that the second I should be a number.
My suggestion is to look for the casting dates on the block and head using the following reference: Quote:
10-12-2018, 04:59 PM | #3 |
There is a GMC old trucks web site that can help you with identify of your block.
10-12-2018, 05:50 PM | #4 |
The Old GMC site doesn't show engine numbers that I can find. http://www.oldgmctrucks.com/index.html
I did find this with casting numbers http://home.znet.com/c1937/Cast.htm
