10-12-2018, 12:03 PM | #26 | |
Re: Major brake issues, help please
Remove the nuts that secure the master cylinder to the booster. Then slowly push the master cylinder along the mounting studs until it's seated properly in the booster. If you feel any pressure at all the pushrod is either too long or not fully seated within the booster. |
10-12-2018, 01:40 PM | #27 |
Mike,
I did check that depth. I used depth gauges and a micrometer, I also used the putty idea and it checks out to spec that wilwood requires. Really appreciate the idea though. |
10-12-2018, 08:53 PM | #28 |
I appreciate what you're saying but having done it several times I've found it almost impossible to "measure" the length since the master cylinder recesses into the booster by about a half an inch. Feel is a more reliable indicator. This may be one of the only times where "you can be too short but can't be too long."
10-12-2018, 09:23 PM | #29 |
Moderator
This might be a silly question...but have you screwed down the knob on the proportioning valve prior to bleeding the rears?
Rotate the knob clockwise at least ten turns, then try bleeding the system again... Also, I assume you are using the old "have a buddy press the pedal down then crack open a bleeder" technique? I stopped doing that a while back...I now use a power bleeder with a plate attachment that covers both master cylinder reservoirs....pump it up with a full load of fluid, then starting at rear open each bleeder until a full stream of fluid comes out. Makes bleeding a one man process... If this gets your brakes functional, back off the proportioning valve knob conterclockwise 8 turns...then give it a little test drive.... To increase rear brake pressure turn the knob clockwise until the rears lock up a little too easy, then back it out one turn at a times until it feels good for your driving style.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-13-2018, 02:16 PM | #30 | |
I understand your concern about the pin being recessed into the booster. I took a machinist flat ruler and laid it against the booster wall, then took a depth measurement to head of pin from a the flat surface of the booster, then did the opposite (sort of) to the MC. Did a little math and have 1/8th inch gap. Then I tested this with the clay on the booster pin and attached the MC fully, it too showed about 1/8" gap. With your idea of the washers doing what it did makes me think it is ok. What you think? What I'm feeling at the pedal what it should be if it is done correctly? |
10-13-2018, 02:18 PM | #31 | |
I have the adj. Prop valve all the way open. I know this is open because i used a pressure gauge 1st on the MC, each port, then on the prop. Valve and both had same # of about 1000lbs without vacuum ti the booster. |
10-13-2018, 03:05 PM | #32 |
with 1000 to 1500 psi at the rear brakes you should have plenty of brake. is it possible you have mounted the calipers upside down, ie the left caliper on the right side & the right caliper on the left side this would put the bleeders on the bottom. the bleeders must be at the top of the caliper
10-13-2018, 03:11 PM | #33 | |
10-13-2018, 04:45 PM | #34 |
What parts have you not changed since you started? I couldn't see where you changed the rear hose since you started the thread. You said it was new and you inspected it, but have you done your pressure test at both ends of the hose? Yours wouldn't be the first new part to be defective. I have seen hoses that work when straight or at low pressure, but kink up internally under pressure or bending.
Good troubleshooting isolates the problem area. Define the problem. Verify the source as pass or fail. Then spilt the system in half and verify pass or fail. Keep dividing the system until you have isolated the failure point. Don't assume any part is good until you test it under load. So you have good pressure at the caliper. FALSE You have good pressure at the master cylinder. TRUE You have good pressure at the outlet from the proportioning valve. TRUE Next step is go to a convenient pressure test point between the proportioning valve and the caliper. Like the hose connection to the hard line at the frame. Or at the axle end of the hose. Or at the double male connection under the passenger seat floorboard. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-13-2018, 11:20 PM | #35 | |
There are a lot of different MC lid adapters available and you can buy a kit with the one you need.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 |
10-14-2018, 12:17 PM | #36 | |
>>88Stanger #33
'67 GMC 2500, 292, 4spd, AC |
10-14-2018, 04:59 PM | #37 |
No photos of rear caliper yet, but every post is good information. As a retired ASE Master tech, I grew in the age or rebuilding components, not opening boxes.
When it comes to rear disc w/E-brake, the piston screws in for new pads or out for service. Working the lever to advance the piston(s) toward the rotor is required. Yes, it take a long time to get all of the air out the line to both rear calipers, but you indicated 1000 - 1500 lbs. with little fluid. You will not get as much as front in normal conditions, but you have all aftermarket components with a knob on the proportioning valve. You're on your own there with customer service on speed dial. I don't know what the answer is for your magical mystery tour of 2018's winner of the most expensive/longest brake job... and still no rear brakes. Your pressure should work and the rears take little volume to move the piston(s). Pressure bleeder, yes! Buddy pumping the pedal, press twice, then hold. Open blender screw, pedal drops. Repeat until no more bubbles. Easy right? In short, everything should work! I know as well as anyone, that to go fast, you need to stop very well. But WoW, surrr do look perrrty! Glad I used all GM parts to get disc brakes on my 1967 C10.
Removed |
10-16-2018, 01:43 PM | #38 |
10-16-2018, 01:59 PM | #39 | |
After all this, not sure who was the first to mention it, but I believe the issue wuth the original GM stuff is as you said adjusting the rear caliper piston, of which I did not do, nor did the instructions I got did not mention doing this and I have never really worked with this type of caliper before. Oh well, the new Wilwoods look nice and are rebuild able. Not that this justifies getting the Wilwoods, but I like them. I'll post how the new Wilwoods work. Lol now I'll have a full rear conversion to sell. Lol Last edited by 88Stanger; 10-16-2018 at 02:04 PM. |
