K20 brake hoses
Anyone point me in the right direction to buying front brake hoses for my 68 K20? Stores keep giving me k10 ones .
Knuckle size is the problem between the two.. Posted via Mobile Device |
Re: K20 brake hoses
The brake book I have shows from '68-70 K10-K20 use the same brake hose. But from your picture I can tell that isn't the stock axle that came on the front of a '68 K20, from the 4 bolt steering arm, it looks more like a dana 60 vs the dana 44 that came in the K20. You may want to start looking for K30 parts vs K20. I would for sure look into seeing what axle that is and go from there.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
#3 | |
All about them K’s
![]() Join Date: Jun 2014
Re: K20 brake hoses
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Re: K20 brake hoses
No its a 44. Just bigger knuckle And hubs.. the 1/2 ton line wont clear the 3/4 ton knuckle thats why the metal lines to wc. As for the 4 bolt steering arm. Both my k10/20 have them. Neither truck has had any rears changed..
![]() Join Date: Oct 2009
Re: K20 brake hoses
Inline tube might be able to make custom lengths - if you run out of options, might call them and ask. I know they made e-brake cables for me once, but I seem to recall hoses coming up in the conversation also. It was quite a few years ago, so not certain, but they had the capability to do some custom work.
#6 | |
Re: K20 brake hoses
You might try Rockauto, take some measurements and check the spec,s .. good luck.
Re: K20 brake hoses
How long are the rubber hoses, both female ends?... what size are they...3/16"....and or 1/4".?
#10 | |
Re: K20 brake hoses
I believe all your metal lines in 68 should be 1/4, not 3/16.
