01-16-2019, 04:45 AM | #1 | |
Re: Convert 4x4 to 2 wheel drive
Transmission I think you can use the existing but will need the 2wd tail shaft. I'm not 100% on this but I believe that is really all you need Shackles you can use the 4x if you want but they will sit high in the rear. The difference is that the 4x shackles hang lower where the 2x shackles are more even with the frame. Steering sorry can't help there I converted to a Mustang rack on mine Brake Line routing I believe is the same. Not 100% on this but I believe it is the same. I can't remember if it needed to be changed or not. Mine was originally a 2x that had a bent frame and I swapped it for what I could find which was a 4x. |
01-16-2019, 07:44 AM | #2 |
BaggedRanger Thanks for the quick reply. It looks like we are going to remove the partially installed front cross member and disassemble it so it is easier to handle. Also we did keep the frame from the doner truck but it was from right behind the shock mounts forward. We will see what we can get to match up for mounting holes. I will post more pictures as I get them. Thanks again
01-26-2019, 12:43 AM | #3 |
Here are some pictures of what has been accomplished so far. We got the front cross member aligned, drilled and bolted in. Added a flip kit to the rear.
We are waiting on new front brake lines (metal and rubber) to run those. We also still need to reinstall the doghouse |
01-26-2019, 12:45 AM | #4 |
more pictures
01-26-2019, 12:46 AM | #5 |
Annnnnnd more
01-26-2019, 12:48 AM | #6 |
Even moooooore
01-26-2019, 12:50 AM | #7 |
More
