Old 01-22-2019, 08:48 PM   #1
Jason 56
My 56 build
I started this thread by accident in the general forum, so I decided to move it here as this is where it should be. The first pictures I took with my phone had the wrong orientation. Sideways... so I’m only including a few of how the truck started! It came with a 350 /700R4 combo, which I’m replacing with an LS. I haven’t obtained one yet, but have lots to do in the meantime!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 01-22-2019, 09:04 PM   #2
Jason 56
Re: My 56 build
Enough of the sideway pics I purchased the truck in August. Someone actually attempted to modify the tri five frame to bolt in a newer Camaro front end. It didn’t go so well so I started by building a new frame out of 1/8” 2x6 square stock. Bought a helix mustang II front end and a triangulated 4 link rear end. The pictures show the 4th time I redid the front cross member and the second time I did the rear. I wasn’t happy with my original ride height! I initially built the frame with the stock axle notch. The 4th pic is the tracing of my ne notches
Old 01-22-2019, 09:19 PM   #3
Jason 56
Re: My 56 build
This is how the c-notch ended up. And I built the shock mounts. The 3rd pic is where my final ride height should fall in the rear. I also added some 45 degree braces on a downward angle to prevent any frame flexing. Also notched them so I can still fish any brake and fuel lines down the frame. Then I c-notched the front for the rack and pinion
Old 01-22-2019, 09:31 PM   #4
Jason 56
Re: My 56 build
Now That i have the frame to my liking I began sheet metal work. I don’t mind the sheet metal work, but don’t really care for the finish work. I’m too much of a perfectionist I started by removing the fiberglass that the previous owner put on the floor. Underneath I found Swiss cheese which lead me to brace up the cab and begin removing the firewall and half the floor! I was planning on the firewall anyway as the previous owner got a little carried away with a hole saw. Not to mention that there is about 40 holes from the factory.
Old 01-22-2019, 09:40 PM   #5
Jason 56
Re: My 56 build
Here are some of the problems I have to fix! Thanks to others on this forum I decided to be more adventurous and build some of the cowl panels that needed to be replaced! So after lots of pounding n shaping I came up with new lower cowls and kick panels
Old 01-22-2019, 09:52 PM   #6
Jason 56
Re: My 56 build
After further review of the cab I decided I needed to brace the door openings as well. I had to completey remove the a post from the step and replace the lower. I ordered a bunch of new sheet metal parts including new front cab supports. Had to build a frame to support the front of the cab using the cowl. Also cut out my new firewall. I left the hinge mounts in place so I wouldn’t have to relocate them! At this point I could finally start putting everything back tighter!
Old 01-22-2019, 10:01 PM   #7
Jason 56
Re: My 56 build
This is where I am at currently. Just finished up the left front of the cab and am waiting for a lower a post to be delivered ( thought I was going to be able to salvage the original... wrong) her are the pictures or the left side complete. After I finish the right hand side and replace the floor I’m also going to redo the steps!
Old 01-23-2019, 05:20 PM   #8
dsraven
Re: My 56 build
i really recommend to hang a door to check gaps and general fit. it's better to find a fitment issue sooner than later when the panels are already welded in. it will set the gap below the door as well. also remove the striker plate so it doesn't affect the fit by pulling the door up or down.
just a thought
Old 01-23-2019, 11:58 PM   #9
Jason 56
Re: My 56 build
just a thought
Good call! I was thinking the same thing. Looks like I should order my hinges sooner than later. Anyone know if I’d be better rebuilding my old ones or are the replacements decent? I have definitely noticed that the aftermarket quality is far from original!
Old 01-24-2019, 12:09 AM   #10
mongocanfly
mongocanfly's Avatar
Re: My 56 build
id use original ...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-24-2019, 12:15 AM   #11
Advanced Design
Advanced Design's Avatar
Re: My 56 build
I vote original as well. Nice fab work!
Advanced Design is offline   Reply With Quote
Old 02-03-2019, 12:44 AM   #12
Jason 56
Re: My 56 build
Have made some more progress. Finished the right a-post, kick panel and cowl. Now onto the floor pan and firewall. Spent most of the day fitting the floor pan. I also tore into my original hinges and there really worn! One pin was already replaced with a 3/8” bolt and another has a replacement hinge pin. The hinge with the new pin is still really bad Not sure I’ll be able to rebuild them. Was also wondering what others are doing for the cup washers that mount in the floor pan as the cab mounts. I can’t seem to find any. This is currently keeping me from installing the floor. Any info would be appreciated thanks
Old 02-04-2019, 12:40 AM   #13
Jason 56
Re: My 56 build
After sleeping on the cup washer idea I decided to just make them. Was really simple. A washer and a piece or pipe. Got the floor welded in and the firewall tacked in place. Slowly making progress! Had to get creative with the ratchet strap to straighten the firewall! Next I’m going to replace the steps then order hinges and fit doors. I’m not going to weld the center of the floor together yet. Figure I might have to move it to adjust door gaps. We’ll see
Old 02-04-2019, 01:15 AM   #14
dsraven
Re: My 56 build
if anybody else is wondering about those cupped washers, I have used the washers from newer cars with strut suspension. they use a washer similar to that on the struts. beware of the springs in there when undoing nuts though.
Old 02-17-2019, 11:02 PM   #15
Jason 56
Re: My 56 build
Over the last two week I’ve managed to remove both steps. Found rust holes filled with mud in both lower b-posts. Ordered new for each side along with the step supports. Just cut my own steps. Plan on covering them with a piece of stainless... so flat works better. Also finish welded the firewall in place. Came out pretty good, but I’m a perfectionist
Old 02-17-2019, 11:27 PM   #16
Jason 56
Re: My 56 build
I’ve spent a lot of my last two weeks battling Mother Nature... won’t quit snowing! Today I replaced the drivers cab corner. The passenger side was already done! Once I’ve replaced both lower b-posts the whole lower 12” of the cab will be new! Minus the rear half of the floor I also plan on welding the old rocker panels back on. They’re in good shape. Received my new hinges last week n began fitting the doors. I see what others are saying on their posts. They are going to be a pain in the ass to fit It’s hard to tell in the picture, the gap is coming out as I hoped. Decent on the top and widens as you follow the door down. Should work well, as I’m going to pull the a & b post together to fix the gap. Then fit the steps in and weld everything in place. Now I have to remove all my bracing so I can move things... We’ll see
Old 02-18-2019, 12:01 AM   #17
dsraven
Re: My 56 build
nice.
do yourself a favor and cover up that glass, welding and grinding sparks will melt in and your glass will be toast.
Old 02-18-2019, 12:24 AM   #18
Jason 56
Re: My 56 build
It’s already cracked n needs to be replaced
Old 03-17-2019, 09:51 PM   #19
Jason 56
Re: My 56 build
I managed to get a couple days of work done on the truck this weekend! I haven’t been able to do anything to it due to snow removal... it’s finally warming up some this far north! When I bought the truck the right hand cab corner was already replaced so I figured I wouldn’t need to fix that corner. Couldn’t of been more wrong! I could see a patch panel on the inside of the corner, but didn’t expect 1/4” of bondo covering up crappy sheet metal work. See picture #3 of the piece I cut out. So a weekend of patching the corner back together. Had to make a 2” filler panel to make up for the crap I had to cut out. Last thing I did today was cut out all the bracing n began fitting doors. The center of the floor n the step still aren’t welded in. This leaves the bottom half of the cab still adjustable! So far the 1st door looks good. Once both doors are fitted I’ll weld everything together. Cab is almost done
Old 05-14-2019, 10:58 PM   #20
Jason 56
Re: My 56 build
Got the truck pushed out of the garage so I can see the stance. I got the doors fitted n the cab floor welded back together. The steps are in place and the door gaps look good. I had to make a cut parallel to the passenger side door to fix that gap. I see that’s quite common from other posts. Now onto the front fenders. I was pretty bummed to find that they were in worse shape than they looked. Going to order half fenders for each side. Also the piece over the headlight on the right side. I have to reinstall my rocker panels, but noticed they don’t line up with the front fenders. I put the fenders on so I could make sure they would line up before I weld them back on. Is this a common problem on these trucks. If so what’s the best way to fix it?
Old 05-21-2019, 04:23 PM   #21
youngrodder
youngrodder's Avatar
Re: My 56 build
Nice fab work....from one Michigander ( SW Lower MI) to another...
Keep it up....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-21-2019, 07:41 PM   #22
slammed57
slammed57's Avatar
Re: My 56 build
lookin good bud
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 05-22-2019, 08:19 AM   #23
71'tahoe
71'tahoe's Avatar
Re: My 56 build
Cool project and great job on the chassis and body work!
71'tahoe is offline   Reply With Quote
Old 05-23-2019, 12:13 AM   #24
Jason 56
Re: My 56 build
Thanks guys... it’s supposed to be nice this weekend so I can roll her out n get some pictures of the stance. I’ll post them asap
Old 06-10-2019, 12:07 AM   #25
Jason 56
Re: My 56 build
Here’s some pictures of the stance. Apparently my dog is photogenic she photobombed nearly every pic! Ordered my fender halves today. Hopefully they’ll be here in the next week. Have a week off coming up n I hope to do the fenders n finish stripping the paint to see how much more work I have.
