Old 02-14-2019, 11:35 AM   #576
60-66
60-66's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by pimpston65 View Post
I have a 292. should I keep the 4 blade fan? or switch to a 5 blade?
1966 292 AC truck , has the fixed 5 blade fan.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-16-2019, 10:50 PM   #577
forestb
forestb's Avatar
Tried to install my new kicker audio stereo and realized that I am not smart enough to install it but I am smart enough not to try��
I don't know why this got posted here. It was supposed to go to the what did you do to your truck today thread.
forestb is offline   Reply With Quote
Old 02-22-2019, 07:55 AM   #578
corvettejim1968
corvettejim1968's Avatar
Originally Posted by LT1 Burb View Post
Here is a couple of pics of it., Can't have a picture of AC stuff without the ashtray. Also Factory AC should have 5 bladed fan, heavy duty radiator, shroud etc.
hate to point this out but the center A/C vent is installed backwards
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 02-22-2019, 11:02 AM   #579
damnyankee36
damnyankee36's Avatar
LT1, do you have the correct nuts that mount the AC box to the firewall?
Could you show me what they look like? I have two styles on mine and can't tell if either one is correct. This pic of yours shows which ones I am referring to.
Thanks!
damnyankee36 is offline   Reply With Quote
Old 02-23-2019, 11:25 AM   #580
LT1 Burb
LT1 Burb's Avatar
Thanks!
Jon(60-66) would be the guy to answer this, he has an NOS AC kit and will have all the hardware with it new.
LT1 Burb is offline   Reply With Quote
Old 02-23-2019, 12:06 PM   #581
damnyankee36
I did look at his "Dealer Installed A/C" thread earlier. No pics of the nuts, but the diagram, along with the AIM, shows what looks like a flange/washer nut. The nuts previously installed were this type of nut and a stamped, (for emblems?) type nut.
I just went to Lowe's and found a couple of free-spinning flange nuts.
Old 02-23-2019, 12:08 PM   #582
pimpston65
pimpston65's Avatar
Nice
pimpston65 is offline   Reply With Quote
Old 02-23-2019, 12:14 PM   #583
pimpston65
pimpston65's Avatar
try the local smaller harware stores they may have the correct items, found a set on a pick the other day.
Old 02-23-2019, 12:15 PM   #584
damnyankee36
You're saying this is the correct nut?
Old 02-23-2019, 12:28 PM   #585
pimpston65
pimpston65's Avatar
yes it came off a heater box from a 66 C10 i always take bolts screws and washers from trucks when i pull parts, in order to have the correct one and if one is missing then i got to the hardware to match it.
Old 02-23-2019, 12:33 PM   #586
damnyankee36
Hmmm, I was gonna assume that this type of nut wouldn't be to bolt on something that heavy. Emblems, maybe.
Guess I'll rethink this again. They are easy to find, however.
Thanks for the tip.
Old 02-23-2019, 01:05 PM   #587
60-66
60-66's Avatar
Winston is correct about the nut. Its more about sealing force than supporting weight since the weight is carried by the studs. Theres also support from the bracket to the dash. Lowes nuts are all wrong for this.
Thanks for the tip.
Old 02-23-2019, 01:10 PM   #588
pimpston65
pimpston65's Avatar
these hold the box on the engine side
Old 02-23-2019, 01:33 PM   #589
damnyankee36
Close enough for me. Sometimes you have to decide when to draw the line...
I bet if you could find them repro'd they wouldn't be much better!
Thanks for all the info.
Old 02-23-2019, 02:08 PM   #590
pimpston65
pimpston65's Avatar
you just made what i call a "work around". finding a product thats available now to meet the same goal and look almost like the original. nice...
Old 02-23-2019, 02:13 PM   #591
pimpston65
pimpston65's Avatar
i think its more on this thread to find the factory correct item, because i have a work around. i just like pulling parts and get the item as it came.
Old 02-23-2019, 03:47 PM   #592
60-66
60-66's Avatar
Well , that's why I have "parts trucks" I rarely if ever use store bought fasteners when putting one of these back together in "original" form. I Reuse many original nuts and bolts with the correct head markings and size and simply clean and replate them. Makes a BIG difference when you see any restoration done. My biggest turn off is seeing a restoration and every nut and bolt was bought at the local hardware store , all of your local hardware is now Chinese and is NOT the same thread pitch or diameter most the time. Theres a company that actually makes most of these fasteners exact. Pretty big catalog selection right down the the head markings and GM part numbers if you needed something speciphic. I will try to get that info and post it later. If you're doing a restoration , its worth it , resto mod or modified , who cares.
Old 02-23-2019, 03:50 PM   #593
damnyankee36
AMK?
http://amkproducts.com/
Old 02-23-2019, 03:54 PM   #594
pimpston65
pimpston65's Avatar
My parts trucks are bone yards close that still has originals no one cares bought other then me, I been pulling parts at this one spot for 3 yrs and there’s still more there.
Old 02-23-2019, 04:25 PM   #595
60-66
60-66's Avatar
Yes , was just going to post it. Stamped nuts are what they call those.
http://www.amkproducts.com/Catalog_PDF/56-73.pdf
Old 03-04-2019, 02:59 AM   #596
Submariner616
Active Member
On my 1965 K20, listed next to "Paint" on the kick panel plate are the numbers 80-72367 and 96890. Does anyone know what these numbers mean?
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 03-04-2019, 08:54 PM   #597
Submariner616
Active Member
I have searched the numbers and have tried to find a match on every 65 Chevy paint color sheet I could find with no luck.
Submariner616
Old 03-05-2019, 10:19 PM   #598
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Usually codes like that are a FLEET color or Government issue . state rescue and such not. What original color is on the truck now?
Old 03-06-2019, 12:58 AM   #599
sirJim
There wouldent happen to be a round inside cargo lamp lens? I broke mine from my 62 suburban.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 03-06-2019, 02:02 AM   #600
Submariner616
Active Member
Exterior is a very rough cream white. Firewall is blue and I see some blue under the white around the cowl. Interior is a gold-ish tan color. Here is a picture of the firewall with the original markings. You can see a little of the white up on the cowl. VIN is K2535S124324
Submariner616
