Old 02-12-2019, 09:33 PM   #801
renegade6
Re: Vintage 4wd Pictures:Other Makes
They aren't as bad as a 2 1/2 ton, but still kind of loud. Tinnitus is no fun. Ideal solution would be an intercom with headsets.
Originally Posted by jeffahart View Post
Do you need to wear ear plugs when you drive those?
j
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 02-12-2019, 10:18 PM   #802
sweetk30
sweetk30's Avatar
Too many pics to scab and post. Check out this M934 camper. Do you need to wear ear plugs when you drive those?
http://www.axialracing.com/blog_posts/1073915233
j
if you pull the muffler behind the safety cage and straight pipe it yes . . . but you uncork them for power then .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-13-2019, 09:05 AM   #803
Early Marmon-Herringtons
Old 02-13-2019, 05:36 PM   #804
Dooley
Dooley's Avatar
The M934 isn't too bad. Much quieter than the deuce's especially the ones with the C turbo.
My M925A2 has the newer 8.3 Cummins and is even quieter. Also I can run with the windows up in warm temps because it has a Red Dot air conditioner installed!
Dooley is offline   Reply With Quote
Old 02-13-2019, 07:58 PM   #805
jeffahart
jeffahart's Avatar
I've driven the deuces off highway quite a bit in the army. But I only road marched one once. It started raining real bad. It got so loud in that thing. Oh, and the wiper on the driver side went out. If I remember it was an air pressured wiper setup. My TC wouldn't let me pull over and try to fix it. I remember all the maintenance 5ton drivers wore ear protection. But the grunts in the line units driving the deuces just toughed it out and went deaf. Because you never knew when you were going to get yanked and put behind the wheel. That's why the army is for the young guys! Oh, and troops are the worst cargo. You should hear them b ithc, every little bump. If you're a bad driver you're in for some $hit when you stop.
j
White K20
jeffahart is offline   Reply With Quote
Old 02-16-2019, 04:03 AM   #806
Dooley
Dooley's Avatar
j
The 5 tons have the electric wipers.
I have an electric kit I want to install in one of the deuces.
Been more than a few times I worked the drivers side manually when it stopped working. In the pic below I ran the wipers in an effort to see in a snow storm at -4 degrees temp. It got so cold that day I stopped after moisture in the air lines froze and locked the brakes up and I had to get a heater to thaw them out on the side of the road.
Old 02-16-2019, 07:59 AM   #807
It's called Timber Rat
Old 02-16-2019, 09:25 PM   #808
mud.man.rj
mud.man.rj's Avatar
Timber Rat looks like a Vega Rat Rod's truck.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 02-16-2019, 10:04 PM   #809
renegade6
A0 models (ones with duals and non-turbo Cummins) still had air operated wipers.
Brandon
Old 02-17-2019, 04:32 AM   #810
Dooley
Dooley's Avatar
My 1970 XM818 with a Cummins has electric wipers. Bought it from the government that way.
Old 02-17-2019, 09:37 PM   #811
renegade6
Thumbs up Re: Vintage 4wd Pictures:Other Makes
Learn something new everyday. The air powered ones are a PITA
Brandon
Old 02-18-2019, 02:32 PM   #812
jeffahart
jeffahart's Avatar
I remember in the winter in Germany cold starting tracked vehicles was a detail like guard duty. A complete pain in the butt. Each company had a man staring the big diesels at the motor pool to keep them warm 24/7, no block heaters. I mostly drove a quarter ton, got hot quick and you could dry your boots in a half hour, those things had hurricane fans. Glad you still have your feet! It was worse for the deuce drivers in the combat trains. They got screwed because they couldn't sit idling because of heat signature. The inside of a cold deuce beats laying in a hasty fighting position all day though!
j
White K20
Old 02-18-2019, 07:59 PM   #813
Dooley
Dooley's Avatar
j
I did suffer minor effects from frostbite that trip and still have problems with my feet to this day.
Old 02-18-2019, 09:02 PM   #814
dozerbill72
dozerbill72's Avatar
We use this weekly for firewood or dirt duties. It's '69 Kaiser. Have a hoist that I hope to getting around to putting under it soon, will make it way handier being able to dump.
dozerbill72 is offline   Reply With Quote
Old 02-18-2019, 10:54 PM   #815
GSP7
GSP7's Avatar
52 FORD F3 Marmon Herrington
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 02-19-2019, 03:41 PM   #816
Dooley
Dooley's Avatar
Ran across these pictures the other day (slow day at work) Not "Other makes" but very different with right hand drive and obviously British design influences.
Chevrolet Canadian Military Pattern C8 / C15 / C30 / C60 No.13 cab trucks. A couple of links and pictures. The last one is my favorite.
https://en.wikipedia.org/wiki/Canadi..._Pattern_truck
https://www.trucksplanet.com/catalog/model.php?id=1336
Although A Canadian Chevrolet, your post inspired me to post these 2 pics from when I was in Toronto recently. The Artillery Quad and 25 pounder were beautifully restored and in complete working order.
Old 04-06-2019, 12:33 PM   #817
Js
Old 04-06-2019, 09:31 PM   #818
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Js
Those are some good looking rigs.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is online now   Reply With Quote
Old 04-07-2019, 06:01 AM   #819
dieseldawg142
dieseldawg142's Avatar
ya, some nice jeeps.
third truck in my life was this old Glad, owned in the early '80's as a snot nose teen. pic of the only polaroid i have of it
few yrs ago at a quad run up at Larson Hill on the Coquihalla, this beast showed up (and no, i have no clue who she is...)
liking that front plate...lol
dieseldawg142 is offline   Reply With Quote
Old 04-12-2019, 02:45 AM   #820
68GMC2500
My first truck and my brother-in law's truck in 79.
68GMC2500 is offline   Reply With Quote
Old 04-12-2019, 07:50 PM   #821
CG
BlahBlahBlah
I think these are four wheelers
Old 04-12-2019, 10:18 PM   #822
Ol Blue K20
Some good pics....
Dale
Old 04-12-2019, 10:52 PM   #823
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dodge commercial for 1978 Ram Charger - contrasts w Blazer and Bronco
Old 04-13-2019, 01:01 PM   #824
HO455
HO455's Avatar
It would be so cool to be able to see those up close, sit in them, crawl underneath them.
RIP Bob Parks.
Old 04-13-2019, 01:48 PM   #825
A better shot of the 73 El Coolmino
